host集群ks-apiserver上有token超时的错误
2020/12/18 19:50:02 http: proxy error: context canceled
2020/12/18 20:02:21 http: proxy error: context canceled
2020/12/18 20:12:29 http: proxy error: context canceled
2020/12/18 20:12:30 http: proxy error: context canceled
2020/12/18 20:12:37 http: proxy error: context canceled
E1218 20:25:08.219883 1 ldap_provider.go:101] LDAP Result Code 49 "Invalid Credentials":
E1218 20:25:08.219999 1 authenticator.go:108] LDAP Result Code 49 "Invalid Credentials":
E1218 20:25:08.220015 1 handler.go:275] incorrect password
E1218 20:25:08.222138 1 login_recoder.go:75] LoginRecord.iam.kubesphere.io "A0041454-7tjl7" is invalid: [metadata.generateName: Invalid value: "A0041454-": a DNS-1123 subdomain must consist of lower case alphanumeric characters, '-' or '.', and must start and end with an alphanumeric character (e.g. 'example.com', regex used for validation is '[a-z0-9]([-a-z0-9]*[a-z0-9])?(\.[a-z0-9]([-a-z0-9]*[a-z0-9])?)*'), metadata.name: Invalid value: "A0041454-7tjl7": a DNS-1123 subdomain must consist of lower case alphanumeric characters, '-' or '.', and must start and end with an alphanumeric character (e.g. 'example.com', regex used for validation is '[a-z0-9]([-a-z0-9]*[a-z0-9])?(\.[a-z0-9]([-a-z0-9]*[a-z0-9])?)*')]
E1218 20:25:08.222163 1 handler.go:279] LoginRecord.iam.kubesphere.io "A0041454-7tjl7" is invalid: [metadata.generateName: Invalid value: "A0041454-": a DNS-1123 subdomain must consist of lower case alphanumeric characters, '-' or '.', and must start and end with an alphanumeric character (e.g. 'example.com', regex used for validation is '[a-z0-9]([-a-z0-9]*[a-z0-9])?(\.[a-z0-9]([-a-z0-9]*[a-z0-9])?)*'), metadata.name: Invalid value: "A0041454-7tjl7": a DNS-1123 subdomain must consist of lower case alphanumeric characters, '-' or '.', and must start and end with an alphanumeric character (e.g. 'example.com', regex used for validation is '[a-z0-9]([-a-z0-9]*[a-z0-9])?(\.[a-z0-9]([-a-z0-9]*[a-z0-9])?)*')]
I1218 20:25:08.222186 1 apiserver.go:539] 100.77.248.93 - "POST /oauth/token HTTP/1.1" 500 697 6ms
E1218 20:44:16.565604 1 ldap_provider.go:101] LDAP Result Code 49 "Invalid Credentials":
E1218 20:44:16.565727 1 authenticator.go:108] LDAP Result Code 49 "Invalid Credentials":
E1218 20:44:16.565743 1 handler.go:275] incorrect password
I1218 20:44:16.569795 1 apiserver.go:539] 100.77.248.93 - "POST /oauth/token HTTP/1.1" 401 32 31ms
2020/12/18 20:45:17 http: proxy error: context canceled
E1218 20:48:05.008286 1 jwt.go:51] token is expired by 5s
E1218 20:48:05.008315 1 token.go:57] token is expired by 5s
E1218 20:48:05.008326 1 jwt_token.go:45] token is expired by 5s
E1218 20:48:05.008338 1 authentication.go:60] Unable to authenticate the request due to error: token is expired by 5s
E1218 20:48:05.062430 1 jwt.go:51] token is expired by 5s
E1218 20:48:05.062457 1 token.go:57] token is expired by 5s
E1218 20:48:05.062472 1 jwt_token.go:45] token is expired by 5s
E1218 20:48:05.062484 1 authentication.go:60] Unable to authenticate the request due to error: token is expired by 5s
