容器日志:
I0106 05:45:47.128103 1 docker.go:506] Using locally available image “dockerhub.example.com/kubesphere/java-8-centos7:v2.1.0”
I0106 05:45:47.131624 1 docker.go:506] Using locally available image “dockerhub.example.com/kubesphere/java-8-centos7:v2.1.0”
I0106 05:45:47.136625 1 docker.go:506] Using locally available image “dockerhub.example.com/kubesphere/java-8-centos7:v2.1.0”
I0106 05:45:47.136651 1 docker.go:800] Image sha256:2c6e739c0ca5119ad46d44d307970d32d19ef3766230077580ef774da5feadc6 contains scripts-url set to “image:///usr/local/s2i”
I0106 05:45:47.137867 1 docker.go:506] Using locally available image “dockerhub.example.com/kubesphere/java-8-runtime:v2.1.0”
I0106 05:45:47.137903 1 docker.go:800] Image sha256:ac3c7f3ffb7bc3a3aba93510a1d948a2a33970a1947b80122db92b810df39423 contains scripts-url set to “image:///usr/local/s2i”
I0106 05:45:47.137951 1 sti.go:205] Preparing to build IP:30402/enegry-tool/t2:latest
I0106 05:45:47.139519 1 docker.go:506] Using locally available image “dockerhub.example.com/kubesphere/java-8-runtime:v2.1.0”
I0106 05:45:47.141082 1 download.go:31] Start Download Binary register-center-aim.jar
I0106 05:46:17.141587 1 cleanup.go:33] Removing temporary directory /tmp/s2i810750182
I0106 05:46:17.141664 1 fs.go:302] Removing directory ‘/tmp/s2i810750182’
I0106 05:46:17.142297 1 s2i.go:75] Build failed
E0106 05:46:17.142363 1 errors.go:307] An error occurred: Get http://ks-apiserver.kubesphere-system.svc/kapis/devops.kubesphere.io/v1alpha2/namespaces/enegry-tool/s2ibinaries/register-center-aim-jar597m/file/register-center-aim.jar: dial tcp: i/o timeout
截图:
