kubesphere-system 下 的ks-controller-manager 运行不正常,pod s显示CrashLoopBackOff. 查看日志 显示如下:
![W0113] 19:49:02.867681 1 client_config.go:543] Neither –kubeconfig nor –master was specified. Using the inClusterConfig. This might not work.
E0113 19:49:02.889944 1 server.go:81] failed to connect to ldap service, please check ldap status, error: factory is not able to fill the pool: LDAP Result Code 200 “Network Error”: dial tcp: lookup openldap.kubesphere-system.svc on 10.233.0.10:53: no such host
请问大家有遇到过这种问题吗?有什么好的解决方法吗?
