查看脚本ansible报错如下:
`TASK [metrics-server : Metrics-Server | Installing metrics-server] *************
fatal: [localhost]: FAILED! => {“changed”: true, “cmd”: “/usr/local/bin/helm upgrade –install metrics-server /kubesphere/kubesphere/metrics-server –namespace kube-system\n”, “delta”: “0:00:01.869310”, “end”: “2021-03-18 23:38:19.860493”, “msg”: “non-zero return code”, “rc”: 1, “start”: “2021-03-18 23:38:17.991183”, “stderr”: "Error: rendered manifests contain a resource that already exists. Unable to continue with install: ServiceAccount \“metrics-server\” in namespace \“kube-system\” exists and cannot be imported into the current release: invalid ownership metadata; label validation error: missing key \“app.kubernetes.io/managed-by\”: must be set to \“Helm\”; annotation validation error: missing key \“meta.helm.sh/release-name\”: must be set to \“metrics-server\”; annotation validation error: missing key \“meta.helm.sh/release-namespace\”: must be set to \“kube-system\”", “stderr_lines”: ["Error: rendered manifests contain a resource that already exists. Unable to continue with install: ServiceAccount \“metrics-server\” in namespace \“kube-system\” exists and cannot be imported into the current release: invalid ownership metadata; label validation error: missing key \“app.kubernetes.io/managed-by\”: must be set to \“Helm\”; annotation validation error: missing key \“meta.helm.sh/release-name\”: must be set to \“metrics-server\”; annotation validation error: missing key \“meta.helm.sh/release-namespace\”: must be set to \“kube-system\”"], “stdout”: "Release \“metrics-server\” does not exist. Installing it now.", “stdout_lines”: ["Release \“metrics-server\” does not exist. Installing it now."]}
…ignoring
TASK [metrics-server : Metrics-Server | Installing metrics-server retry] *******
fatal: [localhost]: FAILED! => {“changed”: true, “cmd”: “/usr/local/bin/helm del metrics-server -n kube-system && sleep 5 && /usr/local/bin/helm upgrade –install metrics-server /kubesphere/kubesphere/metrics-server –namespacekube-system\n”, “delta”: “0:00:00.106813”, “end”: “2021-03-18 23:38:20.446524”, “msg”: “non-zero return code”, “rc”: 1, “start”: “2021-03-18 23:38:20.339711”, “stderr”: “Error: uninstall: Release not loaded: metrics-server: release: not found”, “stderr_lines”: [“Error: uninstall: Release not loaded: metrics-server: release: not found”], “stdout”: "", “stdout_lines”: []}
localhost : ok=7 changed=5 unreachable=0 failed=1 skipped=4 rescued=0 ![ignored=2`]
请问应该怎么解决?
    zaker
    如果集群里已经有metrics-server,可以把metrics-server关闭
    可以kubectl get apiservice检查下。
      6 天 后
      Cauchy
      你好,那怎么才能从kubesphere的界面上进行hpa的可视化管理?
