Task 'monitoring' failed:
"counter": 62,
"created": "2019-12-11T03:24:53.367978",
"end_line": 60,
"event": "runner_on_failed",
"event_data": {
"event_loop": null,
"host": "localhost",
"ignore_errors": null,
"play": "localhost",
"play_pattern": "localhost",
"play_uuid": "0255ac10-0063-ec0c-88fd-000000000005",
"playbook": "/kubesphere/playbooks/monitoring.yaml",
"playbook_uuid": "a0a078e3-cf18-40f8-90e7-516a802644cd",
"remote_addr": "127.0.0.1",
"res": {
"changed": true,
"msg": "All items completed",
"results": [
"_ansible_item_label": "sources",
"_ansible_no_log": false,
"ansible_loop_var": "item",
"attempts": 5,
"changed": true,
"cmd": "/usr/local/bin/kubectl apply -f /etc/kubesphere/prometheus/sources",
"delta": "0:00:01.820096",
"end": "2019-12-11 03:24:25.696958",
"failed": true,
"failed_when_result": true,
"invocation": {
"module_args": {
"_raw_params": "/usr/local/bin/kubectl apply -f /etc/kubesphere/prometheus/sources",
"_uses_shell": true,
"argv": null,
"chdir": null,
"creates": null,
"executable": null,
"removes": null,
"stdin": null,
"stdin_add_newline": true,
"strip_empty_ends": true,
"warn": true
"item": "sources",
"rc": 1,
"start": "2019-12-11 03:24:23.876862",
"stderr": "Error from server (Invalid): error when applying patch:\n{\"spec\":{\"template\":{\"spec\":{\"$setElementOrder/containers\":[{\"name\":\"node-exporter\"},{\"name\":\"kube-rbac-proxy\"}],\"containers\":[{\"$setElementOrder/volumeMounts\":[{\"mountPath\":\"/host/proc\"},{\"mountPath\":\"/host/sys\"},{\"mountPath\":\"/host/root\"}],\"args\":[\"--web.listen-address=127.0.0.1:9100\",\"--path.procfs=/host/proc\",\"--path.sysfs=/host/sys\",\"--collector.filesystem.ignored-mount-points=^/(dev|proc|sys|var/lib/docker/.+)($|/)\",\"--collector.filesystem.ignored-fs-types=^(autofs|binfmt_misc|cgroup|configfs|debugfs|devpts|devtmpfs|fusectl|hugetlbfs|mqueue|overlay|proc|procfs|pstore|rpc_pipefs|securityfs|sysfs|tracefs)$\"],\"name\":\"node-exporter\",\"volumeMounts\":[{\"mountPath\":\"/host/proc\",\"readOnly\":false},{\"mountPath\":\"/host/sys\",\"readOnly\":false}]},{\"$setElementOrder/ports\":[{\"containerPort\":9100}],\"args\":[\"--secure-listen-address=$(IP):9100\",\"--upstream=http://127.0.0.1:9100/\"],\"name\":\"kube-rbac-proxy\",\"ports\":[{\"containerPort\":9100,\"hostPort\":9100,\"name\":\"https\"}]}],\"nodeSelector\":{\"beta.kubernetes.io/os\":\"linux\"},\"tolerations\":[{\"effect\":\"NoSchedule\",\"key\":\"node-role.kubernetes.io/master\"},{\"key\":\"dedicated\",\"operator\":\"Exists\"}]}}}}\nto:\nResource: \"apps/v1beta2, Resource=daemonsets\", GroupVersionKind: \"apps/v1beta2, Kind=DaemonSet\"\nName: \"node-exporter\", Namespace: \"kubesphere-monitoring-system\"\nObject: &{map[\"status\":map[\"numberReady\":'\\x06' \"observedGeneration\":'\\x04' \"updatedNumberScheduled\":'\\x06' \"numberAvailable\":'\\x06' \"currentNumberScheduled\":'\\x06' \"numberMisscheduled\":'\\x00' \"desiredNumberScheduled\":'\\x06'] \"kind\":\"DaemonSet\" \"apiVersion\":\"apps/v1beta2\" \"metadata\":map[\"selfLink\":\"/apis/apps/v1beta2/namespaces/kubesphere-monitoring-system/daemonsets/node-exporter\" \"uid\":\"b851174e-1bba-11ea-abb4-fa163ec5aba4\" \"resourceVersion\":\"45042072\" \"name\":\"node-exporter\" \"generation\":'\\x04' \"creationTimestamp\":\"2019-12-11T02:05:35Z\" \"labels\":map[\"app\":\"node-exporter\"] \"annotations\":map[\"deprecated.daemonset.template.generation\":\"4\" \"kubectl.kubernetes.io/last-applied-configuration\":\"{\\\"apiVersion\\\":\\\"apps/v1beta2\\\",\\\"kind\\\":\\\"DaemonSet\\\",\\\"metadata\\\":{\\\"annotations\\\":{},\\\"labels\\\":{\\\"app\\\":\\\"node-exporter\\\"},\\\"name\\\":\\\"node-exporter\\\",\\\"namespace\\\":\\\"kubesphere-monitoring-system\\\"},\\\"spec\\\":{\\\"selector\\\":{\\\"matchLabels\\\":{\\\"app\\\":\\\"node-exporter\\\"}},\\\"template\\\":{\\\"metadata\\\":{\\\"labels\\\":{\\\"app\\\":\\\"node-exporter\\\"}},\\\"spec\\\":{\\\"containers\\\":[{\\\"args\\\":[\\\"--web.listen-address=127.0.0.1:9100\\\",\\\"--path.procfs=/host/proc\\\",\\\"--path.sysfs=/host/sys\\\",\\\"--collector.filesystem.ignored-mount-points=^/(dev|proc|sys|var/lib/docker/.+)($|/)\\\",\\\"--collector.filesystem.ignored-fs-types=^(autofs|binfmt_misc|cgroup|configfs|debugfs|devpts|devtmpfs|fusectl|hugetlbfs|mqueue|overlay|proc|procfs|pstore|rpc_pipefs|securityfs|sysfs|tracefs)$\\\"],\\\"image\\\":\\\"kubesphere/node-exporter:ks-v0.16.0\\\",\\\"name\\\":\\\"node-exporter\\\",\\\"resources\\\":{\\\"limits\\\":{\\\"cpu\\\":\\\"250m\\\",\\\"memory\\\":\\\"180Mi\\\"},\\\"requests\\\":{\\\"cpu\\\":\\\"10m\\\",\\\"memory\\\":\\\"180Mi\\\"}},\\\"volumeMounts\\\":[{\\\"mountPath\\\":\\\"/host/proc\\\",\\\"name\\\":\\\"proc\\\",\\\"readOnly\\\":false},{\\\"mountPath\\\":\\\"/host/sys\\\",\\\"name\\\":\\\"sys\\\",\\\"readOnly\\\":false},{\\\"mountPath\\\":\\\"/host/root\\\",\\\"mountPropagation\\\":\\\"HostToContainer\\\",\\\"name\\\":\\\"root\\\",\\\"readOnly\\\":true}]},{\\\"args\\\":[\\\"--secure-listen-address=$(IP):9100\\\",\\\"--upstream=http://127.0.0.1:9100/\\\"],\\\"env\\\":[{\\\"name\\\":\\\"IP\\\",\\\"valueFrom\\\":{\\\"fieldRef\\\":{\\\"fieldPath\\\":\\\"status.podIP\\\"}}}],\\\"image\\\":\\\"kubesphere/kube-rbac-proxy:v0.4.1\\\",\\\"name\\\":\\\"kube-rbac-proxy\\\",\\\"ports\\\":[{\\\"containerPort\\\":9100,\\\"hostPort\\\":9100,\\\"name\\\":\\\"https\\\"}],\\\"resources\\\":{\\\"limits\\\":{\\\"cpu\\\":\\\"20m\\\",\\\"memory\\\":\\\"40Mi\\\"},\\\"requests\\\":{\\\"cpu\\\":\\\"10m\\\",\\\"memory\\\":\\\"20Mi\\\"}}}],\\\"hostNetwork\\\":true,\\\"hostPID\\\":true,\\\"imagePullSecrets\\\":[{\\\"name\\\":\\\"qingcloud\\\"}],\\\"nodeSelector\\\":{\\\"beta.kubernetes.io/os\\\":\\\"linux\\\"},\\\"securityContext\\\":{\\\"runAsNonRoot\\\":true,\\\"runAsUser\\\":65534},\\\"serviceAccountName\\\":\\\"node-exporter\\\",\\\"tolerations\\\":[{\\\"effect\\\":\\\"NoSchedule\\\",\\\"key\\\":\\\"node-role.kubernetes.io/master\\\"},{\\\"key\\\":\\\"dedicated\\\",\\\"operator\\\":\\\"Exists\\\"}],\\\"volumes\\\":[{\\\"hostPath\\\":{\\\"path\\\":\\\"/proc\\\"},\\\"name\\\":\\\"proc\\\"},{\\\"hostPath\\\":{\\\"path\\\":\\\"/sys\\\"},\\\"name\\\":\\\"sys\\\"},{\\\"hostPath\\\":{\\\"path\\\":\\\"/\\\"},\\\"name\\\":\\\"root\\\"}]}}}}\\n\"] \"namespace\":\"kubesphere-monitoring-system\"] \"spec\":map[\"selector\":map[\"matchLabels\":map[\"app\":\"node-exporter\"]] \"template\":map[\"metadata\":map[\"creationTimestamp\":<nil> \"labels\":map[\"app\":\"node-exporter\"]] \"spec\":map[\"terminationGracePeriodSeconds\":'\\x1e' \"serviceAccountName\":\"node-exporter\" \"hostPID\":%!q(bool=true) \"securityContext\":map[\"runAsUser\":'\\ufffe' \"runAsNonRoot\":%!q(bool=true)] \"tolerations\":[map[\"operator\":\"Exists\" \"effect\":\"NoSchedule\"]] \"containers\":[map[\"volumeMounts\":[map[\"name\":\"proc\" \"mountPath\":\"/host/proc\"] map[\"name\":\"sys\" \"mountPath\":\"/host/sys\"] map[\"readOnly\":%!q(bool=true) \"mountPath\":\"/host/root\" \"mountPropagation\":\"HostToContainer\" \"name\":\"root\"]] \"terminationMessagePath\":\"/dev/termination-log\" \"terminationMessagePolicy\":\"File\" \"imagePullPolicy\":\"IfNotPresent\" \"name\":\"node-exporter\" \"image\":\"kubesphere/node-exporter:ks-v0.16.0\" \"args\":[\"--web.listen-address=127.0.0.1:9101\" \"--path.procfs=/host/proc\" \"--path.sysfs=/host/sys\" \"--collector.filesystem.ignored-mount-points=^/(dev|proc|sys|var/lib/docker/.+)($|/)\" \"--collector.filesystem.ignored-fs-types=^(autofs|binfmt_misc|cgroup|configfs|debugfs|devpts|devtmpfs|fusectl|hugetlbfs|mqueue|overlay|proc|procfs|pstore|rpc_pipefs|securityfs|sysfs|tracefs)$\"] \"resources\":map[\"limits\":map[\"cpu\":\"250m\" \"memory\":\"180Mi\"] \"requests\":map[\"cpu\":\"10m\" \"memory\":\"180Mi\"]]] map[\"terminationMessagePolicy\":\"File\" \"image\":\"kubesphere/kube-rbac-proxy:v0.4.1\" \"args\":[\"--secure-listen-address=$(IP):9101\" \"--upstream=http://127.0.0.1:9101/\"] \"ports\":[map[\"name\":\"https\" \"hostPort\":'\\u238d' \"containerPort\":'\\u238d' \"protocol\":\"TCP\"]] \"env\":[map[\"name\":\"IP\" \"valueFrom\":map[\"fieldRef\":map[\"apiVersion\":\"v1\" \"fieldPath\":\"status.podIP\"]]]] \"resources\":map[\"limits\":map[\"cpu\":\"20m\" \"memory\":\"40Mi\"] \"requests\":map[\"cpu\":\"10m\" \"memory\":\"20Mi\"]] \"name\":\"kube-rbac-proxy\" \"terminationMessagePath\":\"/dev/termination-log\" \"imagePullPolicy\":\"IfNotPresent\"]] \"restartPolicy\":\"Always\" \"serviceAccount\":\"node-exporter\" \"hostNetwork\":%!q(bool=true) \"imagePullSecrets\":[map[\"name\":\"qingcloud\"]] \"schedulerName\":\"default-scheduler\" \"volumes\":[map[\"name\":\"proc\" \"hostPath\":map[\"path\":\"/proc\" \"type\":\"\"]] map[\"name\":\"sys\" \"hostPath\":map[\"type\":\"\" \"path\":\"/sys\"]] map[\"name\":\"root\" \"hostPath\":map[\"path\":\"/\" \"type\":\"\"]]] \"dnsPolicy\":\"ClusterFirst\"]] \"updateStrategy\":map[\"type\":\"RollingUpdate\" \"rollingUpdate\":map[\"maxUnavailable\":'\\x01']] \"revisionHistoryLimit\":'\\n']]}\nfor: \"/etc/kubesphere/prometheus/sources/node-exporter-daemonset.yaml\": DaemonSet.apps \"node-exporter\" is invalid: spec.template.spec.containers[1].ports[1].name: Duplicate value: \"https\"\nError from server (InternalError): error when creating \"/etc/kubesphere/prometheus/sources/prometheus-rules.yaml\": Internal error occurred: failed calling webhook \"prometheusrulemutate.monitoring.coreos.com\": Post https://prometheus-prometheus-oper-operator.monitoring.svc:443/admission-prometheusrules/mutate?timeout=30s: dial tcp 10.247.69.235:443: connect: connection refused",
"stderr_lines": [
"Error from server (Invalid): error when applying patch:",
"{\"spec\":{\"template\":{\"spec\":{\"$setElementOrder/containers\":[{\"name\":\"node-exporter\"},{\"name\":\"kube-rbac-proxy\"}],\"containers\":[{\"$setElementOrder/volumeMounts\":[{\"mountPath\":\"/host/proc\"},{\"mountPath\":\"/host/sys\"},{\"mountPath\":\"/host/root\"}],\"args\":[\"--web.listen-address=127.0.0.1:9100\",\"--path.procfs=/host/proc\",\"--path.sysfs=/host/sys\",\"--collector.filesystem.ignored-mount-points=^/(dev|proc|sys|var/lib/docker/.+)($|/)\",\"--collector.filesystem.ignored-fs-types=^(autofs|binfmt_misc|cgroup|configfs|debugfs|devpts|devtmpfs|fusectl|hugetlbfs|mqueue|overlay|proc|procfs|pstore|rpc_pipefs|securityfs|sysfs|tracefs)$\"],\"name\":\"node-exporter\",\"volumeMounts\":[{\"mountPath\":\"/host/proc\",\"readOnly\":false},{\"mountPath\":\"/host/sys\",\"readOnly\":false}]},{\"$setElementOrder/ports\":[{\"containerPort\":9100}],\"args\":[\"--secure-listen-address=$(IP):9100\",\"--upstream=http://127.0.0.1:9100/\"],\"name\":\"kube-rbac-proxy\",\"ports\":[{\"containerPort\":9100,\"hostPort\":9100,\"name\":\"https\"}]}],\"nodeSelector\":{\"beta.kubernetes.io/os\":\"linux\"},\"tolerations\":[{\"effect\":\"NoSchedule\",\"key\":\"node-role.kubernetes.io/master\"},{\"key\":\"dedicated\",\"operator\":\"Exists\"}]}}}}",
"to:",
"Resource: \"apps/v1beta2, Resource=daemonsets\", GroupVersionKind: \"apps/v1beta2, Kind=DaemonSet\"",
"Name: \"node-exporter\", Namespace: \"kubesphere-monitoring-system\"",
"Object: &{map[\"status\":map[\"numberReady\":'\\x06' \"observedGeneration\":'\\x04' \"updatedNumberScheduled\":'\\x06' \"numberAvailable\":'\\x06' \"currentNumberScheduled\":'\\x06' \"numberMisscheduled\":'\\x00' \"desiredNumberScheduled\":'\\x06'] \"kind\":\"DaemonSet\" \"apiVersion\":\"apps/v1beta2\" \"metadata\":map[\"selfLink\":\"/apis/apps/v1beta2/namespaces/kubesphere-monitoring-system/daemonsets/node-exporter\" \"uid\":\"b851174e-1bba-11ea-abb4-fa163ec5aba4\" \"resourceVersion\":\"45042072\" \"name\":\"node-exporter\" \"generation\":'\\x04' \"creationTimestamp\":\"2019-12-11T02:05:35Z\" \"labels\":map[\"app\":\"node-exporter\"] \"annotations\":map[\"deprecated.daemonset.template.generation\":\"4\" \"kubectl.kubernetes.io/last-applied-configuration\":\"{\\\"apiVersion\\\":\\\"apps/v1beta2\\\",\\\"kind\\\":\\\"DaemonSet\\\",\\\"metadata\\\":{\\\"annotations\\\":{},\\\"labels\\\":{\\\"app\\\":\\\"node-exporter\\\"},\\\"name\\\":\\\"node-exporter\\\",\\\"namespace\\\":\\\"kubesphere-monitoring-system\\\"},\\\"spec\\\":{\\\"selector\\\":{\\\"matchLabels\\\":{\\\"app\\\":\\\"node-exporter\\\"}},\\\"template\\\":{\\\"metadata\\\":{\\\"labels\\\":{\\\"app\\\":\\\"node-exporter\\\"}},\\\"spec\\\":{\\\"containers\\\":[{\\\"args\\\":[\\\"--web.listen-address=127.0.0.1:9100\\\",\\\"--path.procfs=/host/proc\\\",\\\"--path.sysfs=/host/sys\\\",\\\"--collector.filesystem.ignored-mount-points=^/(dev|proc|sys|var/lib/docker/.+)($|/)\\\",\\\"--collector.filesystem.ignored-fs-types=^(autofs|binfmt_misc|cgroup|configfs|debugfs|devpts|devtmpfs|fusectl|hugetlbfs|mqueue|overlay|proc|procfs|pstore|rpc_pipefs|securityfs|sysfs|tracefs)$\\\"],\\\"image\\\":\\\"kubesphere/node-exporter:ks-v0.16.0\\\",\\\"name\\\":\\\"node-exporter\\\",\\\"resources\\\":{\\\"limits\\\":{\\\"cpu\\\":\\\"250m\\\",\\\"memory\\\":\\\"180Mi\\\"},\\\"requests\\\":{\\\"cpu\\\":\\\"10m\\\",\\\"memory\\\":\\\"180Mi\\\"}},\\\"volumeMounts\\\":[{\\\"mountPath\\\":\\\"/host/proc\\\",\\\"name\\\":\\\"proc\\\",\\\"readOnly\\\":false},{\\\"mountPath\\\":\\\"/host/sys\\\",\\\"name\\\":\\\"sys\\\",\\\"readOnly\\\":false},{\\\"mountPath\\\":\\\"/host/root\\\",\\\"mountPropagation\\\":\\\"HostToContainer\\\",\\\"name\\\":\\\"root\\\",\\\"readOnly\\\":true}]},{\\\"args\\\":[\\\"--secure-listen-address=$(IP):9100\\\",\\\"--upstream=http://127.0.0.1:9100/\\\"],\\\"env\\\":[{\\\"name\\\":\\\"IP\\\",\\\"valueFrom\\\":{\\\"fieldRef\\\":{\\\"fieldPath\\\":\\\"status.podIP\\\"}}}],\\\"image\\\":\\\"kubesphere/kube-rbac-proxy:v0.4.1\\\",\\\"name\\\":\\\"kube-rbac-proxy\\\",\\\"ports\\\":[{\\\"containerPort\\\":9100,\\\"hostPort\\\":9100,\\\"name\\\":\\\"https\\\"}],\\\"resources\\\":{\\\"limits\\\":{\\\"cpu\\\":\\\"20m\\\",\\\"memory\\\":\\\"40Mi\\\"},\\\"requests\\\":{\\\"cpu\\\":\\\"10m\\\",\\\"memory\\\":\\\"20Mi\\\"}}}],\\\"hostNetwork\\\":true,\\\"hostPID\\\":true,\\\"imagePullSecrets\\\":[{\\\"name\\\":\\\"qingcloud\\\"}],\\\"nodeSelector\\\":{\\\"beta.kubernetes.io/os\\\":\\\"linux\\\"},\\\"securityContext\\\":{\\\"runAsNonRoot\\\":true,\\\"runAsUser\\\":65534},\\\"serviceAccountName\\\":\\\"node-exporter\\\",\\\"tolerations\\\":[{\\\"effect\\\":\\\"NoSchedule\\\",\\\"key\\\":\\\"node-role.kubernetes.io/master\\\"},{\\\"key\\\":\\\"dedicated\\\",\\\"operator\\\":\\\"Exists\\\"}],\\\"volumes\\\":[{\\\"hostPath\\\":{\\\"path\\\":\\\"/proc\\\"},\\\"name\\\":\\\"proc\\\"},{\\\"hostPath\\\":{\\\"path\\\":\\\"/sys\\\"},\\\"name\\\":\\\"sys\\\"},{\\\"hostPath\\\":{\\\"path\\\":\\\"/\\\"},\\\"name\\\":\\\"root\\\"}]}}}}\\n\"] \"namespace\":\"kubesphere-monitoring-system\"] \"spec\":map[\"selector\":map[\"matchLabels\":map[\"app\":\"node-exporter\"]] \"template\":map[\"metadata\":map[\"creationTimestamp\":<nil> \"labels\":map[\"app\":\"node-exporter\"]] \"spec\":map[\"terminationGracePeriodSeconds\":'\\x1e' \"serviceAccountName\":\"node-exporter\" \"hostPID\":%!q(bool=true) \"securityContext\":map[\"runAsUser\":'\\ufffe' \"runAsNonRoot\":%!q(bool=true)] \"tolerations\":[map[\"operator\":\"Exists\" \"effect\":\"NoSchedule\"]] \"containers\":[map[\"volumeMounts\":[map[\"name\":\"proc\" \"mountPath\":\"/host/proc\"] map[\"name\":\"sys\" \"mountPath\":\"/host/sys\"] map[\"readOnly\":%!q(bool=true) \"mountPath\":\"/host/root\" \"mountPropagation\":\"HostToContainer\" \"name\":\"root\"]] \"terminationMessagePath\":\"/dev/termination-log\" \"terminationMessagePolicy\":\"File\" \"imagePullPolicy\":\"IfNotPresent\" \"name\":\"node-exporter\" \"image\":\"kubesphere/node-exporter:ks-v0.16.0\" \"args\":[\"--web.listen-address=127.0.0.1:9101\" \"--path.procfs=/host/proc\" \"--path.sysfs=/host/sys\" \"--collector.filesystem.ignored-mount-points=^/(dev|proc|sys|var/lib/docker/.+)($|/)\" \"--collector.filesystem.ignored-fs-types=^(autofs|binfmt_misc|cgroup|configfs|debugfs|devpts|devtmpfs|fusectl|hugetlbfs|mqueue|overlay|proc|procfs|pstore|rpc_pipefs|securityfs|sysfs|tracefs)$\"] \"resources\":map[\"limits\":map[\"cpu\":\"250m\" \"memory\":\"180Mi\"] \"requests\":map[\"cpu\":\"10m\" \"memory\":\"180Mi\"]]] map[\"terminationMessagePolicy\":\"File\" \"image\":\"kubesphere/kube-rbac-proxy:v0.4.1\" \"args\":[\"--secure-listen-address=$(IP):9101\" \"--upstream=http://127.0.0.1:9101/\"] \"ports\":[map[\"name\":\"https\" \"hostPort\":'\\u238d' \"containerPort\":'\\u238d' \"protocol\":\"TCP\"]] \"env\":[map[\"name\":\"IP\" \"valueFrom\":map[\"fieldRef\":map[\"apiVersion\":\"v1\" \"fieldPath\":\"status.podIP\"]]]] \"resources\":map[\"limits\":map[\"cpu\":\"20m\" \"memory\":\"40Mi\"] \"requests\":map[\"cpu\":\"10m\" \"memory\":\"20Mi\"]] \"name\":\"kube-rbac-proxy\" \"terminationMessagePath\":\"/dev/termination-log\" \"imagePullPolicy\":\"IfNotPresent\"]] \"restartPolicy\":\"Always\" \"serviceAccount\":\"node-exporter\" \"hostNetwork\":%!q(bool=true) \"imagePullSecrets\":[map[\"name\":\"qingcloud\"]] \"schedulerName\":\"default-scheduler\" \"volumes\":[map[\"name\":\"proc\" \"hostPath\":map[\"path\":\"/proc\" \"type\":\"\"]] map[\"name\":\"sys\" \"hostPath\":map[\"type\":\"\" \"path\":\"/sys\"]] map[\"name\":\"root\" \"hostPath\":map[\"path\":\"/\" \"type\":\"\"]]] \"dnsPolicy\":\"ClusterFirst\"]] \"updateStrategy\":map[\"type\":\"RollingUpdate\" \"rollingUpdate\":map[\"maxUnavailable\":'\\x01']] \"revisionHistoryLimit\":'\\n']]}",
"for: \"/etc/kubesphere/prometheus/sources/node-exporter-daemonset.yaml\": DaemonSet.apps \"node-exporter\" is invalid: spec.template.spec.containers[1].ports[1].name: Duplicate value: \"https\"",
"Error from server (InternalError): error when creating \"/etc/kubesphere/prometheus/sources/prometheus-rules.yaml\": Internal error occurred: failed calling webhook \"prometheusrulemutate.monitoring.coreos.com\": Post https://prometheus-prometheus-oper-operator.monitoring.svc:443/admission-prometheusrules/mutate?timeout=30s: dial tcp 10.247.69.235:443: connect: connection refused"
"stdout": "secret/additional-scrape-configs unchanged\nclusterrole.rbac.authorization.k8s.io/kube-state-metrics unchanged\nclusterrolebinding.rbac.authorization.k8s.io/kube-state-metrics unchanged\ndeployment.apps/kube-state-metrics configured\nrole.rbac.authorization.k8s.io/kube-state-metrics unchanged\nrolebinding.rbac.authorization.k8s.io/kube-state-metrics unchanged\nservice/kube-state-metrics unchanged\nserviceaccount/kube-state-metrics unchanged\nservicemonitor.monitoring.coreos.com/kube-state-metrics unchanged\nclusterrole.rbac.authorization.k8s.io/node-exporter unchanged\nclusterrolebinding.rbac.authorization.k8s.io/node-exporter unchanged\nservice/node-exporter unchanged\nserviceaccount/node-exporter unchanged\nservicemonitor.monitoring.coreos.com/node-exporter unchanged\nclusterrole.rbac.authorization.k8s.io/prometheus-k8s unchanged\nclusterrolebinding.rbac.authorization.k8s.io/prometheus-k8s unchanged\nprometheus.monitoring.coreos.com/k8s unchanged\nprometheus.monitoring.coreos.com/k8s-system unchanged\nrolebinding.rbac.authorization.k8s.io/prometheus-k8s-config unchanged\nrole.rbac.authorization.k8s.io/prometheus-k8s-config unchanged\nservice/prometheus-k8s unchanged\nserviceaccount/prometheus-k8s unchanged\nservice/kube-controller-manager-headless unchanged\nservice/kube-scheduler-headless unchanged\nservicemonitor.monitoring.coreos.com/prometheus unchanged\nservicemonitor.monitoring.coreos.com/kube-apiserver unchanged\nservicemonitor.monitoring.coreos.com/coredns unchanged\nservicemonitor.monitoring.coreos.com/kube-controller-manager unchanged\nservicemonitor.monitoring.coreos.com/kube-scheduler unchanged\nservicemonitor.monitoring.coreos.com/kubelet unchanged\nservicemonitor.monitoring.coreos.com/prometheus-system unchanged\nservice/prometheus-k8s-system unchanged",
"stdout_lines": [
"secret/additional-scrape-configs unchanged",
"clusterrole.rbac.authorization.k8s.io/kube-state-metrics unchanged",
"clusterrolebinding.rbac.authorization.k8s.io/kube-state-metrics unchanged",
"deployment.apps/kube-state-metrics configured",
"role.rbac.authorization.k8s.io/kube-state-metrics unchanged",
"rolebinding.rbac.authorization.k8s.io/kube-state-metrics unchanged",
"service/kube-state-metrics unchanged",
"serviceaccount/kube-state-metrics unchanged",
"servicemonitor.monitoring.coreos.com/kube-state-metrics unchanged",
"clusterrole.rbac.authorization.k8s.io/node-exporter unchanged",
"clusterrolebinding.rbac.authorization.k8s.io/node-exporter unchanged",
"service/node-exporter unchanged",
"serviceaccount/node-exporter unchanged",
"servicemonitor.monitoring.coreos.com/node-exporter unchanged",
"clusterrole.rbac.authorization.k8s.io/prometheus-k8s unchanged",
"clusterrolebinding.rbac.authorization.k8s.io/prometheus-k8s unchanged",
"prometheus.monitoring.coreos.com/k8s unchanged",
"prometheus.monitoring.coreos.com/k8s-system unchanged",
"rolebinding.rbac.authorization.k8s.io/prometheus-k8s-config unchanged",
"role.rbac.authorization.k8s.io/prometheus-k8s-config unchanged",
"service/prometheus-k8s unchanged",
"serviceaccount/prometheus-k8s unchanged",
"service/kube-controller-manager-headless unchanged",
"service/kube-scheduler-headless unchanged",
"servicemonitor.monitoring.coreos.com/prometheus unchanged",
"servicemonitor.monitoring.coreos.com/kube-apiserver unchanged",
"servicemonitor.monitoring.coreos.com/coredns unchanged",
"servicemonitor.monitoring.coreos.com/kube-controller-manager unchanged",
"servicemonitor.monitoring.coreos.com/kube-scheduler unchanged",
"servicemonitor.monitoring.coreos.com/kubelet unchanged",
"servicemonitor.monitoring.coreos.com/prometheus-system unchanged",
"service/prometheus-k8s-system unchanged"
"attempts": 5,
"changed": true,
"delta": "0:00:01.959622",
"end": "2019-12-11 03:24:53.335803",
"failed": true,
"invocation": {
"module_args": {
"argv": null,
"chdir": null,
"creates": null,
"executable": null,
"removes": null,
"stdin": null,
"warn": true
"item": "sources",
"rc": 1,
"start": "2019-12-11 03:24:51.376181",
"stderr": "Error from server (Invalid): error when applying patch:\n{\"spec\":{\"template\":{\"spec\":{\"$setElementOrder/containers\":[{\"name\":\"node-exporter\"},{\"name\":\"kube-rbac-proxy\"}],\"containers\":[{\"$setElementOrder/volumeMounts\":[{\"mountPath\":\"/host/proc\"},{\"mountPath\":\"/host/sys\"},{\"mountPath\":\"/host/root\"}],\"args\":[\"--web.listen-address=127.0.0.1:9100\",\"--path.procfs=/host/proc\",\"--path.sysfs=/host/sys\",\"--collector.filesystem.ignored-mount-points=^/(dev|proc|sys|var/lib/docker/.+)($|/)\",\"--collector.filesystem.ignored-fs-types=^(autofs|binfmt_misc|cgroup|configfs|debugfs|devpts|devtmpfs|fusectl|hugetlbfs|mqueue|overlay|proc|procfs|pstore|rpc_pipefs|securityfs|sysfs|tracefs)$\"],\"name\":\"node-exporter\",\"volumeMounts\":[{\"mountPath\":\"/host/proc\",\"readOnly\":false},{\"mountPath\":\"/host/sys\",\"readOnly\":false}]},{\"$setElementOrder/ports\":[{\"containerPort\":9100}],\"args\":[\"--secure-listen-address=$(IP):9100\",\"--upstream=http://127.0.0.1:9100/\"],\"name\":\"kube-rbac-proxy\",\"ports\":[{\"containerPort\":9100,\"hostPort\":9100,\"name\":\"https\"}]}],\"nodeSelector\":{\"beta.kubernetes.io/os\":\"linux\"},\"tolerations\":[{\"effect\":\"NoSchedule\",\"key\":\"node-role.kubernetes.io/master\"},{\"key\":\"dedicated\",\"operator\":\"Exists\"}]}}}}\nto:\nResource: \"apps/v1beta2, Resource=daemonsets\", GroupVersionKind: \"apps/v1beta2, Kind=DaemonSet\"\nName: \"node-exporter\", Namespace: \"kubesphere-monitoring-system\"\nObject: &{map[\"kind\":\"DaemonSet\" \"apiVersion\":\"apps/v1beta2\" \"metadata\":map[\"annotations\":map[\"deprecated.daemonset.template.generation\":\"4\" \"kubectl.kubernetes.io/last-applied-configuration\":\"{\\\"apiVersion\\\":\\\"apps/v1beta2\\\",\\\"kind\\\":\\\"DaemonSet\\\",\\\"metadata\\\":{\\\"annotations\\\":{},\\\"labels\\\":{\\\"app\\\":\\\"node-exporter\\\"},\\\"name\\\":\\\"node-exporter\\\",\\\"namespace\\\":\\\"kubesphere-monitoring-system\\\"},\\\"spec\\\":{\\\"selector\\\":{\\\"matchLabels\\\":{\\\"app\\\":\\\"node-exporter\\\"}},\\\"template\\\":{\\\"metadata\\\":{\\\"labels\\\":{\\\"app\\\":\\\"node-exporter\\\"}},\\\"spec\\\":{\\\"containers\\\":[{\\\"args\\\":[\\\"--web.listen-address=127.0.0.1:9100\\\",\\\"--path.procfs=/host/proc\\\",\\\"--path.sysfs=/host/sys\\\",\\\"--collector.filesystem.ignored-mount-points=^/(dev|proc|sys|var/lib/docker/.+)($|/)\\\",\\\"--collector.filesystem.ignored-fs-types=^(autofs|binfmt_misc|cgroup|configfs|debugfs|devpts|devtmpfs|fusectl|hugetlbfs|mqueue|overlay|proc|procfs|pstore|rpc_pipefs|securityfs|sysfs|tracefs)$\\\"],\\\"image\\\":\\\"kubesphere/node-exporter:ks-v0.16.0\\\",\\\"name\\\":\\\"node-exporter\\\",\\\"resources\\\":{\\\"limits\\\":{\\\"cpu\\\":\\\"250m\\\",\\\"memory\\\":\\\"180Mi\\\"},\\\"requests\\\":{\\\"cpu\\\":\\\"10m\\\",\\\"memory\\\":\\\"180Mi\\\"}},\\\"volumeMounts\\\":[{\\\"mountPath\\\":\\\"/host/proc\\\",\\\"name\\\":\\\"proc\\\",\\\"readOnly\\\":false},{\\\"mountPath\\\":\\\"/host/sys\\\",\\\"name\\\":\\\"sys\\\",\\\"readOnly\\\":false},{\\\"mountPath\\\":\\\"/host/root\\\",\\\"mountPropagation\\\":\\\"HostToContainer\\\",\\\"name\\\":\\\"root\\\",\\\"readOnly\\\":true}]},{\\\"args\\\":[\\\"--secure-listen-address=$(IP):9100\\\",\\\"--upstream=http://127.0.0.1:9100/\\\"],\\\"env\\\":[{\\\"name\\\":\\\"IP\\\",\\\"valueFrom\\\":{\\\"fieldRef\\\":{\\\"fieldPath\\\":\\\"status.podIP\\\"}}}],\\\"image\\\":\\\"kubesphere/kube-rbac-proxy:v0.4.1\\\",\\\"name\\\":\\\"kube-rbac-proxy\\\",\\\"ports\\\":[{\\\"containerPort\\\":9100,\\\"hostPort\\\":9100,\\\"name\\\":\\\"https\\\"}],\\\"resources\\\":{\\\"limits\\\":{\\\"cpu\\\":\\\"20m\\\",\\\"memory\\\":\\\"40Mi\\\"},\\\"requests\\\":{\\\"cpu\\\":\\\"10m\\\",\\\"memory\\\":\\\"20Mi\\\"}}}],\\\"hostNetwork\\\":true,\\\"hostPID\\\":true,\\\"imagePullSecrets\\\":[{\\\"name\\\":\\\"qingcloud\\\"}],\\\"nodeSelector\\\":{\\\"beta.kubernetes.io/os\\\":\\\"linux\\\"},\\\"securityContext\\\":{\\\"runAsNonRoot\\\":true,\\\"runAsUser\\\":65534},\\\"serviceAccountName\\\":\\\"node-exporter\\\",\\\"tolerations\\\":[{\\\"effect\\\":\\\"NoSchedule\\\",\\\"key\\\":\\\"node-role.kubernetes.io/master\\\"},{\\\"key\\\":\\\"dedicated\\\",\\\"operator\\\":\\\"Exists\\\"}],\\\"volumes\\\":[{\\\"hostPath\\\":{\\\"path\\\":\\\"/proc\\\"},\\\"name\\\":\\\"proc\\\"},{\\\"hostPath\\\":{\\\"path\\\":\\\"/sys\\\"},\\\"name\\\":\\\"sys\\\"},{\\\"hostPath\\\":{\\\"path\\\":\\\"/\\\"},\\\"name\\\":\\\"root\\\"}]}}}}\\n\"] \"name\":\"node-exporter\" \"namespace\":\"kubesphere-monitoring-system\" \"selfLink\":\"/apis/apps/v1beta2/namespaces/kubesphere-monitoring-system/daemonsets/node-exporter\" \"uid\":\"b851174e-1bba-11ea-abb4-fa163ec5aba4\" \"resourceVersion\":\"45042072\" \"labels\":map[\"app\":\"node-exporter\"] \"generation\":'\\x04' \"creationTimestamp\":\"2019-12-11T02:05:35Z\"] \"spec\":map[\"selector\":map[\"matchLabels\":map[\"app\":\"node-exporter\"]] \"template\":map[\"metadata\":map[\"creationTimestamp\":<nil> \"labels\":map[\"app\":\"node-exporter\"]] \"spec\":map[\"containers\":[map[\"args\":[\"--web.listen-address=127.0.0.1:9101\" \"--path.procfs=/host/proc\" \"--path.sysfs=/host/sys\" \"--collector.filesystem.ignored-mount-points=^/(dev|proc|sys|var/lib/docker/.+)($|/)\" \"--collector.filesystem.ignored-fs-types=^(autofs|binfmt_misc|cgroup|configfs|debugfs|devpts|devtmpfs|fusectl|hugetlbfs|mqueue|overlay|proc|procfs|pstore|rpc_pipefs|securityfs|sysfs|tracefs)$\"] \"resources\":map[\"limits\":map[\"cpu\":\"250m\" \"memory\":\"180Mi\"] \"requests\":map[\"cpu\":\"10m\" \"memory\":\"180Mi\"]] \"volumeMounts\":[map[\"name\":\"proc\" \"mountPath\":\"/host/proc\"] map[\"name\":\"sys\" \"mountPath\":\"/host/sys\"] map[\"mountPath\":\"/host/root\" \"mountPropagation\":\"HostToContainer\" \"name\":\"root\" \"readOnly\":%!q(bool=true)]] \"terminationMessagePath\":\"/dev/termination-log\" \"terminationMessagePolicy\":\"File\" \"imagePullPolicy\":\"IfNotPresent\" \"name\":\"node-exporter\" \"image\":\"kubesphere/node-exporter:ks-v0.16.0\"] map[\"name\":\"kube-rbac-proxy\" \"resources\":map[\"limits\":map[\"cpu\":\"20m\" \"memory\":\"40Mi\"] \"requests\":map[\"cpu\":\"10m\" \"memory\":\"20Mi\"]] \"terminationMessagePath\":\"/dev/termination-log\" \"terminationMessagePolicy\":\"File\" \"image\":\"kubesphere/kube-rbac-proxy:v0.4.1\" \"args\":[\"--secure-listen-address=$(IP):9101\" \"--upstream=http://127.0.0.1:9101/\"] \"ports\":[map[\"name\":\"https\" \"hostPort\":'\\u238d' \"containerPort\":'\\u238d' \"protocol\":\"TCP\"]] \"env\":[map[\"name\":\"IP\" \"valueFrom\":map[\"fieldRef\":map[\"fieldPath\":\"status.podIP\" \"apiVersion\":\"v1\"]]]] \"imagePullPolicy\":\"IfNotPresent\"]] \"terminationGracePeriodSeconds\":'\\x1e' \"serviceAccountName\":\"node-exporter\" \"serviceAccount\":\"node-exporter\" \"hostNetwork\":%!q(bool=true) \"securityContext\":map[\"runAsUser\":'\\ufffe' \"runAsNonRoot\":%!q(bool=true)] \"volumes\":[map[\"name\":\"proc\" \"hostPath\":map[\"path\":\"/proc\" \"type\":\"\"]] map[\"name\":\"sys\" \"hostPath\":map[\"type\":\"\" \"path\":\"/sys\"]] map[\"name\":\"root\" \"hostPath\":map[\"path\":\"/\" \"type\":\"\"]]] \"dnsPolicy\":\"ClusterFirst\" \"hostPID\":%!q(bool=true) \"imagePullSecrets\":[map[\"name\":\"qingcloud\"]] \"schedulerName\":\"default-scheduler\" \"tolerations\":[map[\"operator\":\"Exists\" \"effect\":\"NoSchedule\"]] \"restartPolicy\":\"Always\"]] \"updateStrategy\":map[\"type\":\"RollingUpdate\" \"rollingUpdate\":map[\"maxUnavailable\":'\\x01']] \"revisionHistoryLimit\":'\\n'] \"status\":map[\"desiredNumberScheduled\":'\\x06' \"numberReady\":'\\x06' \"observedGeneration\":'\\x04' \"updatedNumberScheduled\":'\\x06' \"numberAvailable\":'\\x06' \"currentNumberScheduled\":'\\x06' \"numberMisscheduled\":'\\x00']]}\nfor: \"/etc/kubesphere/prometheus/sources/node-exporter-daemonset.yaml\": DaemonSet.apps \"node-exporter\" is invalid: spec.template.spec.containers[1].ports[1].name: Duplicate value: \"https\"\nError from server (InternalError): error when creating \"/etc/kubesphere/prometheus/sources/prometheus-rules.yaml\": Internal error occurred: failed calling webhook \"prometheusrulemutate.monitoring.coreos.com\": Post https://prometheus-prometheus-oper-operator.monitoring.svc:443/admission-prometheusrules/mutate?timeout=30s: dial tcp 10.247.69.235:443: connect: connection refused",
"stderr_lines": [
"to:",
"Object: &{map[\"kind\":\"DaemonSet\" \"apiVersion\":\"apps/v1beta2\" \"metadata\":map[\"annotations\":map[\"deprecated.daemonset.template.generation\":\"4\" \"kubectl.kubernetes.io/last-applied-configuration\":\"{\\\"apiVersion\\\":\\\"apps/v1beta2\\\",\\\"kind\\\":\\\"DaemonSet\\\",\\\"metadata\\\":{\\\"annotations\\\":{},\\\"labels\\\":{\\\"app\\\":\\\"node-exporter\\\"},\\\"name\\\":\\\"node-exporter\\\",\\\"namespace\\\":\\\"kubesphere-monitoring-system\\\"},\\\"spec\\\":{\\\"selector\\\":{\\\"matchLabels\\\":{\\\"app\\\":\\\"node-exporter\\\"}},\\\"template\\\":{\\\"metadata\\\":{\\\"labels\\\":{\\\"app\\\":\\\"node-exporter\\\"}},\\\"spec\\\":{\\\"containers\\\":[{\\\"args\\\":[\\\"--web.listen-address=127.0.0.1:9100\\\",\\\"--path.procfs=/host/proc\\\",\\\"--path.sysfs=/host/sys\\\",\\\"--collector.filesystem.ignored-mount-points=^/(dev|proc|sys|var/lib/docker/.+)($|/)\\\",\\\"--collector.filesystem.ignored-fs-types=^(autofs|binfmt_misc|cgroup|configfs|debugfs|devpts|devtmpfs|fusectl|hugetlbfs|mqueue|overlay|proc|procfs|pstore|rpc_pipefs|securityfs|sysfs|tracefs)$\\\"],\\\"image\\\":\\\"kubesphere/node-exporter:ks-v0.16.0\\\",\\\"name\\\":\\\"node-exporter\\\",\\\"resources\\\":{\\\"limits\\\":{\\\"cpu\\\":\\\"250m\\\",\\\"memory\\\":\\\"180Mi\\\"},\\\"requests\\\":{\\\"cpu\\\":\\\"10m\\\",\\\"memory\\\":\\\"180Mi\\\"}},\\\"volumeMounts\\\":[{\\\"mountPath\\\":\\\"/host/proc\\\",\\\"name\\\":\\\"proc\\\",\\\"readOnly\\\":false},{\\\"mountPath\\\":\\\"/host/sys\\\",\\\"name\\\":\\\"sys\\\",\\\"readOnly\\\":false},{\\\"mountPath\\\":\\\"/host/root\\\",\\\"mountPropagation\\\":\\\"HostToContainer\\\",\\\"name\\\":\\\"root\\\",\\\"readOnly\\\":true}]},{\\\"args\\\":[\\\"--secure-listen-address=$(IP):9100\\\",\\\"--upstream=http://127.0.0.1:9100/\\\"],\\\"env\\\":[{\\\"name\\\":\\\"IP\\\",\\\"valueFrom\\\":{\\\"fieldRef\\\":{\\\"fieldPath\\\":\\\"status.podIP\\\"}}}],\\\"image\\\":\\\"kubesphere/kube-rbac-proxy:v0.4.1\\\",\\\"name\\\":\\\"kube-rbac-proxy\\\",\\\"ports\\\":[{\\\"containerPort\\\":9100,\\\"hostPort\\\":9100,\\\"name\\\":\\\"https\\\"}],\\\"resources\\\":{\\\"limits\\\":{\\\"cpu\\\":\\\"20m\\\",\\\"memory\\\":\\\"40Mi\\\"},\\\"requests\\\":{\\\"cpu\\\":\\\"10m\\\",\\\"memory\\\":\\\"20Mi\\\"}}}],\\\"hostNetwork\\\":true,\\\"hostPID\\\":true,\\\"imagePullSecrets\\\":[{\\\"name\\\":\\\"qingcloud\\\"}],\\\"nodeSelector\\\":{\\\"beta.kubernetes.io/os\\\":\\\"linux\\\"},\\\"securityContext\\\":{\\\"runAsNonRoot\\\":true,\\\"runAsUser\\\":65534},\\\"serviceAccountName\\\":\\\"node-exporter\\\",\\\"tolerations\\\":[{\\\"effect\\\":\\\"NoSchedule\\\",\\\"key\\\":\\\"node-role.kubernetes.io/master\\\"},{\\\"key\\\":\\\"dedicated\\\",\\\"operator\\\":\\\"Exists\\\"}],\\\"volumes\\\":[{\\\"hostPath\\\":{\\\"path\\\":\\\"/proc\\\"},\\\"name\\\":\\\"proc\\\"},{\\\"hostPath\\\":{\\\"path\\\":\\\"/sys\\\"},\\\"name\\\":\\\"sys\\\"},{\\\"hostPath\\\":{\\\"path\\\":\\\"/\\\"},\\\"name\\\":\\\"root\\\"}]}}}}\\n\"] \"name\":\"node-exporter\" \"namespace\":\"kubesphere-monitoring-system\" \"selfLink\":\"/apis/apps/v1beta2/namespaces/kubesphere-monitoring-system/daemonsets/node-exporter\" \"uid\":\"b851174e-1bba-11ea-abb4-fa163ec5aba4\" \"resourceVersion\":\"45042072\" \"labels\":map[\"app\":\"node-exporter\"] \"generation\":'\\x04' \"creationTimestamp\":\"2019-12-11T02:05:35Z\"] \"spec\":map[\"selector\":map[\"matchLabels\":map[\"app\":\"node-exporter\"]] \"template\":map[\"metadata\":map[\"creationTimestamp\":<nil> \"labels\":map[\"app\":\"node-exporter\"]] \"spec\":map[\"containers\":[map[\"args\":[\"--web.listen-address=127.0.0.1:9101\" \"--path.procfs=/host/proc\" \"--path.sysfs=/host/sys\" \"--collector.filesystem.ignored-mount-points=^/(dev|proc|sys|var/lib/docker/.+)($|/)\" \"--collector.filesystem.ignored-fs-types=^(autofs|binfmt_misc|cgroup|configfs|debugfs|devpts|devtmpfs|fusectl|hugetlbfs|mqueue|overlay|proc|procfs|pstore|rpc_pipefs|securityfs|sysfs|tracefs)$\"] \"resources\":map[\"limits\":map[\"cpu\":\"250m\" \"memory\":\"180Mi\"] \"requests\":map[\"cpu\":\"10m\" \"memory\":\"180Mi\"]] \"volumeMounts\":[map[\"name\":\"proc\" \"mountPath\":\"/host/proc\"] map[\"name\":\"sys\" \"mountPath\":\"/host/sys\"] map[\"mountPath\":\"/host/root\" \"mountPropagation\":\"HostToContainer\" \"name\":\"root\" \"readOnly\":%!q(bool=true)]] \"terminationMessagePath\":\"/dev/termination-log\" \"terminationMessagePolicy\":\"File\" \"imagePullPolicy\":\"IfNotPresent\" \"name\":\"node-exporter\" \"image\":\"kubesphere/node-exporter:ks-v0.16.0\"] map[\"name\":\"kube-rbac-proxy\" \"resources\":map[\"limits\":map[\"cpu\":\"20m\" \"memory\":\"40Mi\"] \"requests\":map[\"cpu\":\"10m\" \"memory\":\"20Mi\"]] \"terminationMessagePath\":\"/dev/termination-log\" \"terminationMessagePolicy\":\"File\" \"image\":\"kubesphere/kube-rbac-proxy:v0.4.1\" \"args\":[\"--secure-listen-address=$(IP):9101\" \"--upstream=http://127.0.0.1:9101/\"] \"ports\":[map[\"name\":\"https\" \"hostPort\":'\\u238d' \"containerPort\":'\\u238d' \"protocol\":\"TCP\"]] \"env\":[map[\"name\":\"IP\" \"valueFrom\":map[\"fieldRef\":map[\"fieldPath\":\"status.podIP\" \"apiVersion\":\"v1\"]]]] \"imagePullPolicy\":\"IfNotPresent\"]] \"terminationGracePeriodSeconds\":'\\x1e' \"serviceAccountName\":\"node-exporter\" \"serviceAccount\":\"node-exporter\" \"hostNetwork\":%!q(bool=true) \"securityContext\":map[\"runAsUser\":'\\ufffe' \"runAsNonRoot\":%!q(bool=true)] \"volumes\":[map[\"name\":\"proc\" \"hostPath\":map[\"path\":\"/proc\" \"type\":\"\"]] map[\"name\":\"sys\" \"hostPath\":map[\"type\":\"\" \"path\":\"/sys\"]] map[\"name\":\"root\" \"hostPath\":map[\"path\":\"/\" \"type\":\"\"]]] \"dnsPolicy\":\"ClusterFirst\" \"hostPID\":%!q(bool=true) \"imagePullSecrets\":[map[\"name\":\"qingcloud\"]] \"schedulerName\":\"default-scheduler\" \"tolerations\":[map[\"operator\":\"Exists\" \"effect\":\"NoSchedule\"]] \"restartPolicy\":\"Always\"]] \"updateStrategy\":map[\"type\":\"RollingUpdate\" \"rollingUpdate\":map[\"maxUnavailable\":'\\x01']] \"revisionHistoryLimit\":'\\n'] \"status\":map[\"desiredNumberScheduled\":'\\x06' \"numberReady\":'\\x06' \"observedGeneration\":'\\x04' \"updatedNumberScheduled\":'\\x06' \"numberAvailable\":'\\x06' \"currentNumberScheduled\":'\\x06' \"numberMisscheduled\":'\\x00']]}",
"stdout": "secret/additional-scrape-configs unchanged\nclusterrole.rbac.authorization.k8s.io/kube-state-metrics unchanged\nclusterrolebinding.rbac.authorization.k8s.io/kube-state-metrics unchanged\ndeployment.apps/kube-state-metrics unchanged\nrole.rbac.authorization.k8s.io/kube-state-metrics unchanged\nrolebinding.rbac.authorization.k8s.io/kube-state-metrics unchanged\nservice/kube-state-metrics unchanged\nserviceaccount/kube-state-metrics unchanged\nservicemonitor.monitoring.coreos.com/kube-state-metrics unchanged\nclusterrole.rbac.authorization.k8s.io/node-exporter unchanged\nclusterrolebinding.rbac.authorization.k8s.io/node-exporter unchanged\nservice/node-exporter unchanged\nserviceaccount/node-exporter unchanged\nservicemonitor.monitoring.coreos.com/node-exporter unchanged\nclusterrole.rbac.authorization.k8s.io/prometheus-k8s unchanged\nclusterrolebinding.rbac.authorization.k8s.io/prometheus-k8s unchanged\nprometheus.monitoring.coreos.com/k8s unchanged\nprometheus.monitoring.coreos.com/k8s-system unchanged\nrolebinding.rbac.authorization.k8s.io/prometheus-k8s-config unchanged\nrole.rbac.authorization.k8s.io/prometheus-k8s-config unchanged\nservice/prometheus-k8s unchanged\nserviceaccount/prometheus-k8s unchanged\nservice/kube-controller-manager-headless unchanged\nservice/kube-scheduler-headless unchanged\nservicemonitor.monitoring.coreos.com/prometheus unchanged\nservicemonitor.monitoring.coreos.com/kube-apiserver unchanged\nservicemonitor.monitoring.coreos.com/coredns unchanged\nservicemonitor.monitoring.coreos.com/kube-controller-manager unchanged\nservicemonitor.monitoring.coreos.com/kube-scheduler unchanged\nservicemonitor.monitoring.coreos.com/kubelet unchanged\nservicemonitor.monitoring.coreos.com/prometheus-system unchanged\nservice/prometheus-k8s-system unchanged",
"stdout_lines": [
"deployment.apps/kube-state-metrics unchanged",
"role": "ks-monitor",
"task": "ks-monitor | Installing prometheus-operator",
"task_action": "shell",
"task_args": "",
"task_path": "/kubesphere/installer/roles/ks-monitor/tasks/main.yaml:65",
"task_uuid": "0255ac10-0063-ec0c-88fd-00000000001d",
"uuid": "bc4698fb-e727-49f8-9a70-43b28c035965"
"parent_uuid": "0255ac10-0063-ec0c-88fd-00000000001d",
"pid": 891,
"runner_ident": "monitoring",
"start_line": 60,
"stdout": "",
