手动执行了
sudo pip install –ignore-installed netaddr –no-index –find-links=/kubeinstaller/pip_repo/pip27/iso
sudo pip install –ignore-installed requests –no-index –find-links=/kubeinstaller/pip_repo/pip27/iso
又从网上下载了python_dateutil-2.8.0-py2.py3-none-any.whl和botocore-1.6.8-py2.py3-none-any.whl
sudo pip install python_dateutil-2.8.0-py2.py3-none-any.whl
sudo pip install botocore-1.6.8-py2.py3-none-any.whl
然后就提示:
Please ensure that your environment has met the above requirements (yes/no) yes
- Initiating Environment
ERROR! Unexpected Exception, this is probably a bug: name ‘platform_system’ is not defined
the full traceback was:
Traceback (most recent call last):
File “/usr/bin/ansible-playbook”, line 97, in <module>
mycli = getattr(import(“ansible.cli.%s” % sub, fromlist=[myclass]), myclass)
File “/usr/lib/python2.7/site-packages/ansible/cli/init.py”, line 38, in <module>
from ansible.inventory.manager import InventoryManager
File “/usr/lib/python2.7/site-packages/ansible/inventory/manager.py”, line 38, in <module>
from ansible.plugins.loader import inventory_loader
File “/usr/lib/python2.7/site-packages/ansible/plugins/loader.py”, line 22, in <module>
from ansible.parsing.utils.yaml import from_yaml
File “/usr/lib/python2.7/site-packages/ansible/parsing/utils/yaml.py”, line 17, in <module>
from ansible.parsing.yaml.loader import AnsibleLoader
File “/usr/lib/python2.7/site-packages/ansible/parsing/yaml/loader.py”, line 30, in <module>
from ansible.parsing.yaml.constructor import AnsibleConstructor
File “/usr/lib/python2.7/site-packages/ansible/parsing/yaml/constructor.py”, line 29, in <module>
from ansible.parsing.vault import VaultLib
File “/usr/lib/python2.7/site-packages/ansible/parsing/vault/init.py”, line 42, in <module>
from cryptography.hazmat.backends import default_backend
File “/usr/lib64/python2.7/site-packages/cryptography/hazmat/backends/init.py”, line 7, in <module>
import pkg_resources
File “/usr/lib/python2.7/site-packages/pkg_resources.py”, line 3007, in <module>
working_set.require(requires)
File “/usr/lib/python2.7/site-packages/pkg_resources.py”, line 728, in require
needed = self.resolve(parse_requirements(requirements))
File “/usr/lib/python2.7/site-packages/pkg_resources.py”, line 631, in resolve
requirements.extend(dist.requires(req.extras)[::-1])
File “/usr/lib/python2.7/site-packages/pkg_resources.py”, line 2489, in requires
dm = self._dep_map
File “/usr/lib/python2.7/site-packages/pkg_resources.py”, line 2700, in dep_map
self.__dep_map = self.compute_dependencies()
File “/usr/lib/python2.7/site-packages/pkg_resources.py”, line 2733, in compute_dependencies
common = frozenset(reqs_for_extra(None))
File “/usr/lib/python2.7/site-packages/pkg_resources.py”, line 2730, in reqs_for_extra
if req.marker_fn(override={‘extra’:extra}):
File “/usr/lib/python2.7/site-packages/markerlib/markers.py”, line 113, in marker_fn
return eval(compiled_marker, environment)
File “<environment marker>”, line 1, in <module>
NameError: name ‘platform_system’ is not defined
failed!
please refer to https://kubesphere.io/docs/v2.1/zh-CN/faq/faq-install/
和https://kubesphere.com.cn/forum/d/306-all-in-one-version-2-1-0类似,求助
