xulai 看了3.0自带的prometheus没有ingress的相关指标
global:
scrape_interval: 1m
scrape_timeout: 10s
evaluation_interval: 30s
external_labels:
prometheus: kubesphere-monitoring-system/k8s
prometheus_replica: prometheus-k8s-0
alerting:
alert_relabel_configs:
- separator: ;
regex: prometheus_replica
replacement: $1
action: labeldrop
alertmanagers:
- kubernetes_sd_configs:
- role: endpoints
namespaces:
names:
- kubesphere-monitoring-system
scheme: http
path_prefix: /
timeout: 10s
api_version: v1
relabel_configs:
- source_labels: [__meta_kubernetes_service_name]
separator: ;
regex: alertmanager-main
replacement: $1
action: keep
- source_labels: [__meta_kubernetes_endpoint_port_name]
separator: ;
regex: web
replacement: $1
action: keep
rule_files:
- /etc/prometheus/rules/prometheus-k8s-rulefiles-0/*.yaml
scrape_configs:
- job_name: istio-system/jaeger-operator-metrics/0
honor_timestamps: true
scrape_interval: 1m
scrape_timeout: 10s
metrics_path: /metrics
scheme: http
- role: endpoints
namespaces:
names:
- istio-system
relabel_configs:
- source_labels: [__meta_kubernetes_service_label_name]
separator: ;
regex: jaeger-operator
replacement: $1
action: keep
separator: ;
regex: http-metrics
replacement: $1
action: keep
- source_labels: [__meta_kubernetes_endpoint_address_target_kind, __meta_kubernetes_endpoint_address_target_name]
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
- source_labels: [__meta_kubernetes_namespace]
separator: ;
regex: (.*)
target_label: namespace
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: service
replacement: $1
action: replace
- source_labels: [__meta_kubernetes_pod_name]
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
- separator: ;
regex: (.*)
target_label: endpoint
replacement: http-metrics
action: replace
- job_name: istio-system/jaeger-operator-metrics/1
scrape_interval: 1m
scrape_timeout: 10s
scheme: http
- role: endpoints
namespaces:
names:
- istio-system
relabel_configs:
separator: ;
replacement: $1
action: keep
separator: ;
regex: cr-metrics
replacement: $1
action: keep
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
- separator: ;
regex: (.*)
replacement: cr-metrics
action: replace
- job_name: kube-system/kube-state-metrics/0
honor_labels: true
scrape_interval: 15s
scrape_timeout: 15s
scheme: http
- role: endpoints
namespaces:
names:
- kube-system
relabel_configs:
- source_labels: [__meta_kubernetes_service_label_app_kubernetes_io_name]
separator: ;
regex: kube-state-metrics
replacement: $1
action: keep
separator: ;
regex: http-metrics
replacement: $1
action: keep
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
separator: ;
regex: (.+)
target_label: job
replacement: ${1}
action: replace
- separator: ;
regex: (.*)
action: replace
- job_name: kube-system/node-exporter/0
honor_labels: true
scrape_timeout: 15s
scheme: http
- role: endpoints
namespaces:
names:
- kube-system
relabel_configs:
separator: ;
regex: node-exporter
replacement: $1
action: keep
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
separator: ;
regex: (.+)
target_label: job
replacement: ${1}
action: replace
- source_labels: [__meta_kubernetes_pod_node_name]
separator: ;
regex: (.*)
target_label: instance
replacement: $1
action: replace
- job_name: kubesphere-monitoring-system/alertmanager/0
scrape_interval: 1m
scrape_timeout: 10s
scheme: http
- role: endpoints
namespaces:
names:
relabel_configs:
- source_labels: [__meta_kubernetes_service_label_alertmanager]
separator: ;
regex: main
replacement: $1
action: keep
separator: ;
regex: web
replacement: $1
action: keep
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
- separator: ;
regex: (.*)
replacement: web
action: replace
- job_name: kubesphere-monitoring-system/coredns/0
scrape_interval: 1m
scrape_timeout: 10s
scheme: http
- role: endpoints
namespaces:
names:
- kube-system
bearer_token_file: /var/run/secrets/kubernetes.io/serviceaccount/token
relabel_configs:
- source_labels: [__meta_kubernetes_service_label_k8s_app]
separator: ;
regex: kube-dns
replacement: $1
action: keep
separator: ;
regex: metrics
replacement: $1
action: keep
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
separator: ;
regex: (.+)
target_label: job
replacement: ${1}
action: replace
- separator: ;
regex: (.*)
replacement: metrics
action: replace
- job_name: kubesphere-monitoring-system/kube-apiserver/0
scrape_interval: 1m
scrape_timeout: 10s
scheme: https
- role: endpoints
namespaces:
names:
- default
tls_config:
ca_file: /var/run/secrets/kubernetes.io/serviceaccount/ca.crt
server_name: kubernetes
insecure_skip_verify: false
relabel_configs:
- source_labels: [__meta_kubernetes_service_label_component]
separator: ;
regex: apiserver
replacement: $1
action: keep
- source_labels: [__meta_kubernetes_service_label_provider]
separator: ;
regex: kubernetes
replacement: $1
action: keep
separator: ;
regex: https
replacement: $1
action: keep
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
separator: ;
regex: (.+)
target_label: job
replacement: ${1}
action: replace
- separator: ;
regex: (.*)
replacement: https
action: replace
metric_relabel_configs:
- source_labels: [__name__]
separator: ;
regex: kubelet_(pod_worker_latency_microseconds|pod_start_latency_microseconds|cgroup_manager_latency_microseconds|pod_worker_start_latency_microseconds|pleg_relist_latency_microseconds|pleg_relist_interval_microseconds|runtime_operations|runtime_operations_latency_microseconds|runtime_operations_errors|eviction_stats_age_microseconds|device_plugin_registration_count|device_plugin_alloc_latency_microseconds|network_plugin_operations_latency_microseconds)
replacement: $1
action: drop
separator: ;
regex: scheduler_(e2e_scheduling_latency_microseconds|scheduling_algorithm_predicate_evaluation|scheduling_algorithm_priority_evaluation|scheduling_algorithm_preemption_evaluation|scheduling_algorithm_latency_microseconds|binding_latency_microseconds|scheduling_latency_seconds)
replacement: $1
action: drop
separator: ;
regex: apiserver_(request_count|request_latencies|request_latencies_summary|dropped_requests|storage_data_key_generation_latencies_microseconds|storage_transformation_failures_total|storage_transformation_latencies_microseconds|proxy_tunnel_sync_latency_secs)
replacement: $1
action: drop
separator: ;
regex: kubelet_docker_(operations|operations_latency_microseconds|operations_errors|operations_timeout)
replacement: $1
action: drop
separator: ;
regex: reflector_(items_per_list|items_per_watch|list_duration_seconds|lists_total|short_watches_total|watch_duration_seconds|watches_total)
replacement: $1
action: drop
separator: ;
regex: etcd_(helper_cache_hit_count|helper_cache_miss_count|helper_cache_entry_count|request_cache_get_latencies_summary|request_cache_add_latencies_summary|request_latencies_summary)
replacement: $1
action: drop
separator: ;
regex: transformation_(transformation_latencies_microseconds|failures_total)
replacement: $1
action: drop
separator: ;
regex: (admission_quota_controller_adds|crd_autoregistration_controller_work_duration|APIServiceOpenAPIAggregationControllerQueue1_adds|AvailableConditionController_retries|crd_openapi_controller_unfinished_work_seconds|APIServiceRegistrationController_retries|admission_quota_controller_longest_running_processor_microseconds|crdEstablishing_longest_running_processor_microseconds|crdEstablishing_unfinished_work_seconds|crd_openapi_controller_adds|crd_autoregistration_controller_retries|crd_finalizer_queue_latency|AvailableConditionController_work_duration|non_structural_schema_condition_controller_depth|crd_autoregistration_controller_unfinished_work_seconds|AvailableConditionController_adds|DiscoveryController_longest_running_processor_microseconds|autoregister_queue_latency|crd_autoregistration_controller_adds|non_structural_schema_condition_controller_work_duration|APIServiceRegistrationController_adds|crd_finalizer_work_duration|crd_naming_condition_controller_unfinished_work_seconds|crd_openapi_controller_longest_running_processor_microseconds|DiscoveryController_adds|crd_autoregistration_controller_longest_running_processor_microseconds|autoregister_unfinished_work_seconds|crd_naming_condition_controller_queue_latency|crd_naming_condition_controller_retries|non_structural_schema_condition_controller_queue_latency|crd_naming_condition_controller_depth|AvailableConditionController_longest_running_processor_microseconds|crdEstablishing_depth|crd_finalizer_longest_running_processor_microseconds|crd_naming_condition_controller_adds|APIServiceOpenAPIAggregationControllerQueue1_longest_running_processor_microseconds|DiscoveryController_queue_latency|DiscoveryController_unfinished_work_seconds|crd_openapi_controller_depth|APIServiceOpenAPIAggregationControllerQueue1_queue_latency|APIServiceOpenAPIAggregationControllerQueue1_unfinished_work_seconds|DiscoveryController_work_duration|autoregister_adds|crd_autoregistration_controller_queue_latency|crd_finalizer_retries|AvailableConditionController_unfinished_work_seconds|autoregister_longest_running_processor_microseconds|non_structural_schema_condition_controller_unfinished_work_seconds|APIServiceOpenAPIAggregationControllerQueue1_depth|AvailableConditionController_depth|DiscoveryController_retries|admission_quota_controller_depth|crdEstablishing_adds|APIServiceOpenAPIAggregationControllerQueue1_retries|crdEstablishing_queue_latency|non_structural_schema_condition_controller_longest_running_processor_microseconds|autoregister_work_duration|crd_openapi_controller_retries|APIServiceRegistrationController_work_duration|crdEstablishing_work_duration|crd_finalizer_adds|crd_finalizer_depth|crd_openapi_controller_queue_latency|APIServiceOpenAPIAggregationControllerQueue1_work_duration|APIServiceRegistrationController_queue_latency|crd_autoregistration_controller_depth|AvailableConditionController_queue_latency|admission_quota_controller_queue_latency|crd_naming_condition_controller_work_duration|crd_openapi_controller_work_duration|DiscoveryController_depth|crd_naming_condition_controller_longest_running_processor_microseconds|APIServiceRegistrationController_depth|APIServiceRegistrationController_longest_running_processor_microseconds|crd_finalizer_unfinished_work_seconds|crdEstablishing_retries|admission_quota_controller_unfinished_work_seconds|non_structural_schema_condition_controller_adds|APIServiceRegistrationController_unfinished_work_seconds|admission_quota_controller_work_duration|autoregister_depth|autoregister_retries|kubeproxy_sync_proxy_rules_latency_microseconds|rest_client_request_latency_seconds|non_structural_schema_condition_controller_retries)
replacement: $1
action: drop
separator: ;
regex: apiserver_admission_controller_admission_latencies_seconds_.*
replacement: $1
action: drop
separator: ;
regex: apiserver_admission_step_admission_latencies_seconds_.*
replacement: $1
action: drop
- source_labels: [__name__, le]
separator: ;
regex: apiserver_request_duration_seconds_bucket;(0.15|0.25|0.3|0.35|0.4|0.45|0.6|0.7|0.8|0.9|1.25|1.5|1.75|2.5|3|3.5|4.5|6|7|8|9|15|25|30|50)
replacement: $1
action: drop
- job_name: kubesphere-monitoring-system/kube-controller-manager/0
scrape_interval: 1m
scrape_timeout: 10s
scheme: http
- role: endpoints
namespaces:
names:
- kube-system
relabel_configs:
separator: ;
regex: kube-controller-manager
replacement: $1
action: keep
separator: ;
regex: http-metrics
replacement: $1
action: keep
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
separator: ;
regex: (.+)
target_label: job
replacement: ${1}
action: replace
- separator: ;
regex: (.*)
action: replace
separator: ;
regex: up
replacement: $1
action: keep
- job_name: kubesphere-monitoring-system/kube-scheduler/0
scrape_interval: 1m
scrape_timeout: 10s
scheme: http
- role: endpoints
namespaces:
names:
- kube-system
relabel_configs:
separator: ;
regex: kube-scheduler
replacement: $1
action: keep
separator: ;
regex: http-metrics
replacement: $1
action: keep
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
separator: ;
regex: (.+)
target_label: job
replacement: ${1}
action: replace
- separator: ;
regex: (.*)
action: replace
separator: ;
replacement: $1
action: drop
- job_name: kubesphere-monitoring-system/kube-state-metrics/0
honor_labels: true
scrape_interval: 1m
scrape_timeout: 30s
scheme: https
- role: endpoints
namespaces:
names:
tls_config:
insecure_skip_verify: true
relabel_configs:
separator: ;
replacement: $1
action: keep
separator: ;
regex: https-main
replacement: $1
action: keep
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
separator: ;
regex: (.+)
target_label: job
replacement: ${1}
action: replace
- separator: ;
regex: (.*)
replacement: https-main
action: replace
- separator: ;
regex: (service|endpoint)
replacement: $1
action: labeldrop
- source_labels: [label_kubesphere_io_workspace]
separator: ;
regex: (.*)
target_label: workspace
replacement: $1
action: replace
- job_name: kubesphere-monitoring-system/kube-state-metrics/1
scrape_interval: 1m
scrape_timeout: 10s
scheme: https
- role: endpoints
namespaces:
names:
tls_config:
relabel_configs:
separator: ;
replacement: $1
action: keep
separator: ;
regex: https-self
replacement: $1
action: keep
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
separator: ;
regex: (.+)
target_label: job
replacement: ${1}
action: replace
- separator: ;
regex: (.*)
replacement: https-self
action: replace
- job_name: kubesphere-monitoring-system/kubelet/0
honor_labels: true
scrape_interval: 1m
scrape_timeout: 10s
scheme: https
- role: endpoints
namespaces:
names:
- kube-system
tls_config:
relabel_configs:
separator: ;
regex: kubelet
replacement: $1
action: keep
separator: ;
regex: https-metrics
replacement: $1
action: keep
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
separator: ;
regex: (.+)
target_label: job
replacement: ${1}
action: replace
- separator: ;
regex: (.*)
replacement: https-metrics
action: replace
- separator: ;
replacement: $1
action: labeldrop
separator: ;
regex: kubelet_node_name|kubelet_running_container_count|kubelet_running_pod_count|kubelet_volume_stats.*|kubelet_pleg_relist_duration_seconds_.+
replacement: $1
action: keep
- job_name: kubesphere-monitoring-system/kubelet/1
honor_labels: true
scrape_interval: 1m
scrape_timeout: 10s
metrics_path: /metrics/cadvisor
scheme: https
- role: endpoints
namespaces:
names:
- kube-system
tls_config:
relabel_configs:
separator: ;
regex: kubelet
replacement: $1
action: keep
separator: ;
replacement: $1
action: keep
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
separator: ;
regex: (.+)
target_label: job
replacement: ${1}
action: replace
- separator: ;
regex: (.*)
action: replace
- separator: ;
replacement: $1
action: labeldrop
separator: ;
regex: container_cpu_usage_seconds_total|container_memory_usage_bytes|container_memory_cache|container_network_.+_bytes_total|container_memory_working_set_bytes|container_cpu_cfs_.*periods_total
replacement: $1
action: keep
- job_name: kubesphere-monitoring-system/node-exporter/0
scrape_interval: 1m
scrape_timeout: 10s
scheme: https
- role: endpoints
namespaces:
names:
tls_config:
relabel_configs:
separator: ;
replacement: $1
action: keep
separator: ;
regex: https
replacement: $1
action: keep
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
separator: ;
regex: (.+)
target_label: job
replacement: ${1}
action: replace
- separator: ;
regex: (.*)
replacement: https
action: replace
- separator: ;
replacement: $1
action: labeldrop
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: node_cpu_.+|node_memory_Mem.+_bytes|node_memory_SReclaimable_bytes|node_memory_Cached_bytes|node_memory_Buffers_bytes|node_network_(.+_bytes_total|up)|node_network_.+_errs_total|node_nf_conntrack_entries.*|node_disk_.+_completed_total|node_disk_.+_bytes_total|node_filesystem_files|node_filesystem_files_free|node_filesystem_avail_bytes|node_filesystem_size_bytes|node_filesystem_free_bytes|node_filesystem_readonly|node_load.+|node_timex_offset_seconds
replacement: $1
action: keep
- job_name: kubesphere-monitoring-system/prometheus/0
scrape_interval: 1m
scrape_timeout: 10s
scheme: http
- role: endpoints
namespaces:
names:
relabel_configs:
- source_labels: [__meta_kubernetes_service_label_prometheus]
separator: ;
regex: k8s
replacement: $1
action: keep
separator: ;
regex: web
replacement: $1
action: keep
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
- separator: ;
regex: (.*)
replacement: web
action: replace
- separator: ;
replacement: $1
action: labeldrop
- job_name: kubesphere-monitoring-system/prometheus-operator/0
honor_labels: true
scrape_interval: 1m
scrape_timeout: 10s
scheme: https
- role: endpoints
namespaces:
names:
tls_config:
relabel_configs:
- source_labels: [__meta_kubernetes_service_label_app_kubernetes_io_component]
separator: ;
regex: controller
replacement: $1
action: keep
separator: ;
regex: prometheus-operator
replacement: $1
action: keep
- source_labels: [__meta_kubernetes_service_label_app_kubernetes_io_version]
separator: ;
regex: v0.38.3
replacement: $1
action: keep
separator: ;
regex: https
replacement: $1
action: keep
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
- separator: ;
regex: (.*)
replacement: https
action: replace
- job_name: kubesphere-monitoring-system/s2i-operator/0
honor_labels: true
scrape_interval: 1m
scrape_timeout: 10s
scheme: http
- role: endpoints
namespaces:
names:
- kubesphere-devops-system
relabel_configs:
- source_labels: [__meta_kubernetes_service_label_app]
separator: ;
regex: s2i-metrics
replacement: $1
action: keep
- source_labels: [__meta_kubernetes_service_label_control_plane]
separator: ;
regex: s2i-controller-manager
replacement: $1
action: keep
separator: ;
regex: http
replacement: $1
action: keep
separator: ;
regex: Node;(.*)
target_label: node
replacement: ${1}
action: replace
separator: ;
regex: Pod;(.*)
target_label: pod
replacement: ${1}
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
separator: ;
regex: (.*)
target_label: job
replacement: ${1}
action: replace
separator: ;
regex: (.+)
target_label: job
replacement: ${1}
action: replace
- separator: ;
regex: (.*)
replacement: http
action: replace
separator: ;
regex: s2i_s2ibuilder_created
replacement: $1
action: keep
- job_name: istio-mesh
scrape_timeout: 10s
scheme: http
- role: endpoints
namespaces:
names:
- istio-system
relabel_configs:
- source_labels: [__meta_kubernetes_service_name, __meta_kubernetes_endpoint_port_name]
separator: ;
regex: istio-telemetry;prometheus
replacement: $1
action: keep
- job_name: istio-envoy
scrape_timeout: 10s
scheme: http
- role: endpoints
namespaces:
names:
- istio-system
relabel_configs:
separator: ;
regex: istio-statsd-prom-bridge;statsd-prom
replacement: $1
action: keep
- job_name: istio-policy
scrape_timeout: 10s
scheme: http
- role: endpoints
namespaces:
names:
- istio-system
relabel_configs:
separator: ;
regex: istio-policy;http-monitoring
replacement: $1
action: keep
- job_name: istio-telemetry
scrape_timeout: 10s
scheme: http
- role: endpoints
namespaces:
names:
- istio-system
relabel_configs:
separator: ;
regex: istio-telemetry;http-monitoring
replacement: $1
action: keep
- job_name: istio-pilot
scrape_timeout: 10s
scheme: http
- role: endpoints
namespaces:
names:
- istio-system
relabel_configs:
separator: ;
regex: istio-pilot;http-monitoring
replacement: $1
action: keep
- job_name: istio-galley
scrape_timeout: 10s
scheme: http
- role: endpoints
namespaces:
names:
- istio-system
relabel_configs:
separator: ;
regex: istio-galley;http-monitoring
replacement: $1
action: keep
https://github.com/kubernetes/ingress-nginx/blob/master/deploy/prometheus/prometheus.yaml
很多提到的这个文件的内容要怎么加进去呢
global:
scrape_interval: 10s
scrape_configs:
- job_name: 'ingress-nginx-endpoints'
- role: pod
namespaces:
names:
- ingress-nginx
relabel_configs:
- source_labels: [__meta_kubernetes_pod_annotation_prometheus_io_scrape]
action: keep
regex: true
- source_labels: [__meta_kubernetes_pod_annotation_prometheus_io_scheme]
action: replace
target_label: __scheme__
regex: (https?)
- source_labels: [__meta_kubernetes_pod_annotation_prometheus_io_path]
action: replace
target_label: __metrics_path__
regex: (.+)
- source_labels: [__address__, __meta_kubernetes_pod_annotation_prometheus_io_port]
action: replace
target_label: __address__
regex: ([^:]+)(?::\d+)?;(\d+)
replacement: $1:$2
regex: prometheus-server
action: drop
