相同问题,我发下我的,麻烦大家帮忙看一下。截图不太好截,所以直接贴了describe和logs的文本内容。劳烦查阅了各位:
# kubectl describe pod sonarqube-sonarqube-544cd95ccd-p89r5 -n kubesphere-devops-system
Namespace: kubesphere-devops-system
Priority: 0
Node: node2/172.16.29.83
Start Time: Fri, 04 Jun 2021 17:22:31 +0800
Labels: app=sonarqube
pod-template-hash=544cd95ccd
release=sonarqube
Annotations: checksum/config: 890e34f2c9d29bc1318d0ee1c630c6c5c8695433d9cbac9047a0972b445d80b3
checksum/plugins: 93d52379b10718202a0d61acdae98b65a5fb9c13e2d6fd79bd722759c88829d7
checksum/secret: e3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855
cni.projectcalico.org/podIP: 10.233.96.249/32
cni.projectcalico.org/podIPs: 10.233.96.249/32
Status: Running
IP: 10.233.96.249
IPs:
IP: 10.233.96.249
Controlled By: ReplicaSet/sonarqube-sonarqube-544cd95ccd
Init Containers:
init-sysctl:
Container ID: docker://2fb17da18b6c3cc0fd3d2eb3e07c9b3647b266e2583cf655048eb5695849b696
Image: busybox:1.31
Image ID: docker-pullable://busybox@sha256:95cf004f559831017cdf4628aaf1bb30133677be8702a8c5f2994629f637a209
Port: <none>
Host Port: <none>
Command:
/bin/sh
-c
if [[ "$(sysctl -n vm.max_map_count)" -lt 262144 ]]; then sysctl -w vm.max_map_count=262144; fi
State: Terminated
Reason: Completed
Exit Code: 0
Started: Fri, 04 Jun 2021 17:22:41 +0800
Finished: Fri, 04 Jun 2021 17:22:41 +0800
Ready: True
Restart Count: 0
Environment: <none>
Mounts:
/var/run/secrets/kubernetes.io/serviceaccount from default-token-9jmtr (ro)
Containers:
sonarqube:
Container ID: docker://73020de34ede7bd077a1253d8779e61e10d7e9e8db7befcfa612911404a1af98
Image: sonarqube:8.2-community
Image ID: docker-pullable://sonarqube@sha256:a246bc64207e69bdc3919ac24d7a0526633e0d4560c66a5f7abd6ea2cc25925a
Port: 9000/TCP
Host Port: 0/TCP
State: Waiting
Reason: CrashLoopBackOff
Last State: Terminated
Reason: Completed
Exit Code: 0
Started: Fri, 04 Jun 2021 17:33:39 +0800
Finished: Fri, 04 Jun 2021 17:36:42 +0800
Ready: False
Restart Count: 6
Liveness: http-get http://:http/sessions/new delay=60s timeout=1s period=30s #success=1 #failure=3
Readiness: http-get http://:http/sessions/new delay=60s timeout=1s period=30s #success=1 #failure=6
Environment Variables from:
sonarqube-sonarqube-postgres-config ConfigMap Optional: false
Environment:
SONARQUBE_WEB_JVM_OPTS:
SONARQUBE_JDBC_PASSWORD: <set to the key 'postgresql-password' in secret 'sonarqube-postgresql'> Optional: false
Mounts:
/opt/sonarqube/data from sonarqube (rw,path="data")
/opt/sonarqube/extensions/downloads from sonarqube (rw,path="downloads")
/opt/sonarqube/extensions/plugins/tmp from sonarqube (rw,path="tmp")
/opt/sonarqube/logs from sonarqube (rw,path="logs")
/opt/sonarqube/temp from sonarqube (rw,path="temp")
/tmp from tmp-dir (rw)
/tmp/scripts from copy-plugins (rw)
Conditions:
Type Status
Initialized True
Ready False
ContainersReady False
PodScheduled True
Volumes:
install-plugins:
Type: ConfigMap (a volume populated by a ConfigMap)
Optional: false
copy-plugins:
Optional: false
sonarqube:
Type: EmptyDir (a temporary directory that shares a pod's lifetime)
Medium:
SizeLimit: <unset>
tmp-dir:
Medium:
SizeLimit: <unset>
default-token-9jmtr:
SecretName: default-token-9jmtr
Optional: false
QoS Class: BestEffort
Node-Selectors: <none>
Tolerations: node.kubernetes.io/not-ready:NoExecute op=Exists for 300s
node.kubernetes.io/unreachable:NoExecute op=Exists for 300s
Events:
Type Reason Age From Message
Normal Scheduled 16m default-scheduler Successfully assigned kubesphere-devops-system/sonarqube-sonarqube-544cd95ccd-p89r5 to node2
Normal Pulled 15m kubelet Container image "busybox:1.31" already present on machine
Normal Created 15m kubelet Created container init-sysctl
Normal Started 15m kubelet Started container init-sysctl
Normal Pulled 12m (x5 over 15m) kubelet Container image "sonarqube:8.2-community" already present on machine
Normal Created 12m (x5 over 15m) kubelet Created container sonarqube
Normal Started 12m (x5 over 15m) kubelet Started container sonarqube
Warning BackOff 5m42s (x23 over 15m) kubelet Back-off restarting failed container
**logs*******************************************************************************************************************************************
send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40092, remoteAddress=null}]
java.nio.channels.ClosedChannelException: null
at io.netty.channel.AbstractChannel$AbstractUnsafe.write(...)(Unknown Source)
2021.06.04 09:36:41 WARN app[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40102, remoteAddress=null}]
2021.06.04 09:36:41 WARN app[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40106, remoteAddress=null}]
2021.06.04 09:36:41 WARN app[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40116, remoteAddress=null}]
2021.06.04 09:36:41 WARN app[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40112, remoteAddress=/127.0.0.1:9001}]
2021.06.04 09:36:41 WARN app[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40098, remoteAddress=/127.0.0.1:9001}]
2021.06.04 09:36:41 WARN app[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40110, remoteAddress=null}]
2021.06.04 09:36:41 WARN app[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40114, remoteAddress=null}]
2021.06.04 09:36:41 WARN app[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40096, remoteAddress=null}]
2021.06.04 09:36:41 WARN app[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40100, remoteAddress=null}]
2021.06.04 09:36:41 WARN app[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40104, remoteAddress=/127.0.0.1:9001}]
2021.06.04 09:36:41 WARN app[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40094, remoteAddress=null}]
2021.06.04 09:36:41 WARN app[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40108, remoteAddress=null}]
2021.06.04 09:36:41 INFO ce[][o.s.ce.app.CeServer] Compute Engine is stopping...
2021.06.04 09:36:41 INFO ce[][o.s.c.t.CeProcessingSchedulerImpl] Hard stopping workers...
2021.06.04 09:36:41 WARN ce[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40424, remoteAddress=null}]
2021.06.04 09:36:41 WARN ce[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40432, remoteAddress=null}]
2021.06.04 09:36:41 WARN ce[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40420, remoteAddress=/127.0.0.1:9001}]
2021.06.04 09:36:41 WARN ce[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40426, remoteAddress=null}]
2021.06.04 09:36:41 WARN ce[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40422, remoteAddress=null}]
2021.06.04 09:36:41 WARN ce[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40430, remoteAddress=null}]
2021.06.04 09:36:41 WARN ce[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40428, remoteAddress=/127.0.0.1:9001}]
2021.06.04 09:36:41 WARN ce[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40440, remoteAddress=null}]
2021.06.04 09:36:41 WARN ce[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40434, remoteAddress=null}]
2021.06.04 09:36:41 WARN ce[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40444, remoteAddress=null}]
2021.06.04 09:36:41 WARN ce[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40438, remoteAddress=null}]
2021.06.04 09:36:41 WARN ce[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40436, remoteAddress=null}]
2021.06.04 09:36:41 WARN ce[][o.e.t.OutboundHandler] send message failed [channel: Netty4TcpChannel{localAddress=0.0.0.0/0.0.0.0:40442, remoteAddress=null}]
2021.06.04 09:36:41 INFO ce[][o.s.ce.app.CeServer] Compute Engine is stopped
2021.06.04 09:36:41 INFO app[][o.s.a.SchedulerImpl] Process[ce] is stopped
2021.06.04 09:36:41 INFO app[][o.s.a.SchedulerImpl] SonarQube is stopped
