/ # root@node02:~# kubelogs ks-apiserver-79585cffc4-zrvlq -n kubesphere-system
W0918 11:19:16.589481 1 client_config.go:552] Neither --kubeconfig nor --master was specified. Using the inClusterConfig. This might not work.
W0918 11:19:16.590664 1 client_config.go:552] Neither --kubeconfig nor --master was specified. Using the inClusterConfig. This might not work.
W0918 11:19:16.599921 1 metricsserver.go:238] Metrics API not available.
W0918 11:19:16.599944 1 options.go:180] ks-apiserver starts without redis provided, it will use in memory cache. This may cause inconsistencies when running ks-apiserver with multiple replicas.
I0918 11:19:16.611554 1 interface.go:60] start helm repo informer
I0918 11:19:16.624868 1 apiserver.go:372] Start cache objects
W0918 11:19:16.974873 1 apiserver.go:503] resource devops.kubesphere.io/v1alpha3, Resource=devopsprojects not exists in the cluster
E0918 11:19:16.977166 1 reflector.go:178] pkg/mod/k8s.io/client-go@v0.18.6/tools/cache/reflector.go:125: Failed to list *v1alpha3.DevOpsProject: the server could not find the requested resource (get devopsprojects.devops.kubesphere.io)
E0918 11:19:18.020040 1 reflector.go:178] pkg/mod/k8s.io/client-go@v0.18.6/tools/cache/reflector.go:125: Failed to list *v1alpha3.DevOpsProject: the server could not find the requested resource (get devopsprojects.devops.kubesphere.io)
E0918 11:19:20.082939 1 reflector.go:178] pkg/mod/k8s.io/client-go@v0.18.6/tools/cache/reflector.go:125: Failed to list *v1alpha3.DevOpsProject: the server could not find the requested resource (get devopsprojects.devops.kubesphere.io)
E0918 11:19:25.810389 1 reflector.go:178] pkg/mod/k8s.io/client-go@v0.18.6/tools/cache/reflector.go:125: Failed to list *v1alpha3.DevOpsProject: the server could not find the requested resource (get devopsprojects.devops.kubesphere.io)
E0918 11:19:34.535971 1 reflector.go:178] pkg/mod/k8s.io/client-go@v0.18.6/tools/cache/reflector.go:125: Failed to list *v1alpha3.DevOpsProject: the server could not find the requested resource (get devopsprojects.devops.kubesphere.io)
