错误信息:
++ pwd
  • mvn clean -o -gs /home/jenkins/agent/workspace/project-LAVM8N5g5XAo/gxweb-pipeline/configuration/settings.xml test
    [ERROR] Error executing Maven.
    [ERROR] The specified global settings file does not exist: /home/jenkins/agent/workspace/project-LAVM8N5g5XAo/gxweb-pipeline/configuration/settings.xml
    script returned exit code 1
    我是根据
    https://kubesphere.com.cn/docs/v2.1/zh-CN/quick-start/jenkinsfile-out-of-scm/
    这篇图形化教程配置的
    LLLDDD 麻烦把流水线的各种配置说明一下
    包括代码仓库、流水线最终产生的jenkinsfile
      runzexia
      pipeline {
      agent {
      node {
      label ‘maven’
      stages {
      stage(‘Checkout SCM’) {
      steps {
      git(url: ‘http://10.10.8.182/hxpaas/gcweb.git’, credentialsId: ‘gitlab-id’, branch: ‘master’, changelog: true, poll: false)
      stage(‘Unit Test’) {
      steps {
      container(‘maven’) {
      sh ‘mvn clean -o -gs pwd/configuration/settings.xml test’
      stage('Code Analysis') {
        steps {
          container('maven') {
            withCredentials([string(credentialsId : 'sonar-token' ,variable : 'SONAR_TOKEN' ,)]) {
              withSonarQubeEnv('sonar') {
                sh 'mvn sonar:sonar -o -gs `pwd`/configuration/settings.xml -Dsonar.branch=$BRANCH_NAME -Dsonar.login=$SONAR_TOKEN'
            timeout(unit: 'HOURS', activity: true, time: 1) {
              waitForQualityGate 'true'
      stage('Build and Push') {
        steps {
            sh 'mvn -o -Dmaven.test.skip=true -gs `pwd`/configuration/settings.xml clean package'
            sh 'docker build -f Dockerfile-online -t $REGISTRY/$DOCKERHUB_NAMESPACE/$APP_NAME:SNAPSHOT-$BUILD_NUMBER .'
            withCredentials([usernamePassword(credentialsId : 'dockerhub-id' ,passwordVariable : 'DOCKER_PASSWORD' ,usernameVariable : 'DOCKER_USERNAME' ,)]) {
              sh 'echo "$DOCKER_PASSWORD" | docker login $REGISTRY -u "$DOCKER_USERNAME" --password-stdin'
              sh 'docker push $REGISTRY/$DOCKERHUB_NAMESPACE/$APP_NAME:SNAPSHOT-$BUILD_NUMBER'
      stage('Artifacts') {
        steps {
          archiveArtifacts 'target/*.war'
      stage('Deploy to DEV') {
        steps {
          input(message: '@admin  ', submitter: 'admin')
          kubernetesDeploy(enableConfigSubstitution: true, deleteResource: false, kubeconfigId: 'demo-kubeconfig', configs: 'deploy/dev/**')
          mail(to: '15556695962@163.com', subject: '流水线完成', body: '应用部署完成')
      LLLDDD
      是以devops-java-sample项目为配置的吗?不是的话,对比实例和你本身项目configuration/settings.xml目录问题。
        4 个月 后
        1 年 后
        也是这个问题 用的提供的项目文件 请问是咋解决的啊
        2 年 后
        该github项目之前提了一个commit(kubesphere/devops-maven-sample#5/commits/9b1b30aab87cc405d68aafbf2e23136ac6ebcdb7),将这个settings.xml已经删掉了,所以没有该文件,可以将教程中流水线的bash指令:
        mvn clean -gs `pwd`/configuration/settings.xml test 修改为 mvn clean test 即可。
