ERRO[14:21:30 CST] Failed to add worker to cluster: Failed to exec command: sudo env PATH=$PATH /bin/sh -c "/usr/local/bin/kubeadm join lb.kubesphere.local:6443 --token ikjn9q.7rrehh8t9rylch3i --discovery-token-ca-cert-hash sha256:e746503c473829598cda70b9eb840f94a96f70ea70e0ee2c8d53c1b3071a6549"
[WARNING IsDockerSystemdCheck]: detected "cgroupfs" as the Docker cgroup driver. The recommended driver is "systemd". Please follow the guide at https://kubernetes.io/docs/setup/cri/
[WARNING SystemVerification]: this Docker version is not on the list of validated versions: 20.10.8. Latest validated version: 19.03
[preflight] Reading configuration from the cluster...
[preflight] FYI: You can look at this config file with 'kubectl -n kube-system get cm kubeadm-config -o yaml'
W1022 14:19:25.420260 27950 utils.go:69] The recommended value for "clusterDNS" in "KubeletConfiguration" is: [10.233.0.10]; the provided value is: [169.254.25.10]
[kubelet-start] Writing kubelet configuration to file "/var/lib/kubelet/config.yaml"
[kubelet-start] Writing kubelet environment file with flags to file "/var/lib/kubelet/kubeadm-flags.env"
[kubelet-start] Waiting for the kubelet to perform the TLS Bootstrap...
[kubelet-check] It seems like the kubelet isn't running or healthy.
[kubelet-check] The HTTP call equal to 'curl -sSL http://localhost:10248/healthz' failed with error: Get "http://localhost:10248/healthz": dial tcp [::1]:10248: connect: connection refused.
error execution phase kubelet-start: error uploading crisocket: timed out waiting for the condition
To see the stack trace of this error execute with --v=5 or higher: Process exited with status 1 node=10.30.30.160
3.1.1 新加节点报错,刚加入的节点是从旧集群kubeadm reset的结点
