望大佬给个思路排查一下,感谢
[root@k8s-1 ~]# kubectl logs -f -n istio-system jaeger-collector-59d498d557-x79l9
2021/11/09 01:05:03 maxprocs: Leaving GOMAXPROCS=8: CPU quota undefined
{"level":"info","ts":1636419903.0509253,"caller":"flags/service.go:115","msg":"Mounting metrics handler on admin server","route":"/metrics"}
{"level":"info","ts":1636419903.0511656,"caller":"flags/admin.go:115","msg":"Mounting health check on admin server","route":"/"}
{"level":"info","ts":1636419903.0512292,"caller":"flags/admin.go:121","msg":"Starting admin HTTP server","http-port":14269}
{"level":"info","ts":1636419903.051254,"caller":"flags/admin.go:107","msg":"Admin server started","http-port":14269,"health-status":"unavailable"}
{"level":"info","ts":1636419903.0835497,"caller":"config/config.go:163","msg":"Elasticsearch detected","version":6}
{"level":"fatal","ts":1636420913.0895228,"caller":"collector/main.go:70","msg":"Failed to init storage factory","error":"failed to create primary Elasticsearch client: health check timeout: no Elasticsearch node available","stacktrace":"main.main.func1\n\tgithub.com/jaegertracing/jaeger@/cmd/collector/main.go:70\ngithub.com/spf13/cobra.(*Command).execute\n\tgithub.com/spf13/cobra@v0.0.3/command.go:762\ngithub.com/spf13/cobra.(*Command).ExecuteC\n\tgithub.com/spf13/cobra@v0.0.3/command.go:852\ngithub.com/spf13/cobra.(*Command).Execute\n\tgithub.com/spf13/cobra@v0.0.3/command.go:800\nmain.main\n\tgithub.com/jaegertracing/jaeger@/cmd/collector/main.go:126\nruntime.main\n\truntime/proc.go:203"}
[root@k8s-1 ~]# kubectl get pod -n istio-system
istio-ingressgateway-974bc94b8-p4r9z 1/1 Running 0 15h
istiod-1-6-10-6b5db78f75-pwnc2 1/1 Running 0 15h
jaeger-collector-59d498d557-x79l9 0/1 Running 4 7m18s
jaeger-es-index-cleaner-1636386900-brpxx 0/1 Error 0 9h
jaeger-es-index-cleaner-1636386900-dzm2g 0/1 Error 0 9h
jaeger-es-index-cleaner-1636386900-lr4h8 0/1 Error 0 9h
jaeger-es-index-cleaner-1636386900-qkqdk 0/1 Error 0 9h
jaeger-es-index-cleaner-1636386900-t6fnl 0/1 Error 0 9h
jaeger-operator-677c7bc669-xvfqb 1/1 Running 0 15h
jaeger-query-79c7676c86-j57vz 2/2 Running 2 15h
kiali-6d6bc75869-6flxn 1/1 Running 0 15h
kiali-operator-6db4ccbf94-d7cc2 1/1 Running 0 15h
