操作系统信息,物理机,Ubuntu18.04,8核16G * 3台
Kubernetes版本信息,例如:v21.5。多节点。
KubeSphere版本信息,例如:v3.2.0。在线安装。2.1.1 升级到3.0.0,在升级到3.1.0 -> 3.2.0。
问题是什么,报错日志是什么,最好有截图。
升级完成后,系统工具里面日志没有采集,经过分析,
kubesphere-logging-system 下的Pod fluent-bit-xxxx 状态正常,但是查看日志,发现一直在报错后重启。
[2021/11/29 10:31:46] [ warn] [parser:json] invalid time format %d/%b/%Y:%H:%M:%S %z for ‘2021-11-29T10:31:45.117525958Z’
[2021/11/29 10:32:11] [error] [parser] cannot parse ‘2021-11-29T10:32:09.491622301Z’
[2021/11/29 10:32:11] [ warn] [parser:json] invalid time format %d/%b/%Y:%H:%M:%S %z for ‘2021-11-29T10:32:09.491622301Z’
[2021/11/29 10:32:14] [error] [parser] cannot parse ‘2021-11-29T10:32:13.359122975Z’
[2021/11/29 10:32:14] [ warn] [parser:json] invalid time format %d/%b/%Y:%H:%M:%S %z for ‘2021-11-29T10:32:13.359122975Z’
[2021/11/29 10:32:46] [error] [parser] cannot parse ‘2021-11-29T10:32:45.879583103Z’
[2021/11/29 10:32:46] [ warn] [parser:json] invalid time format %d/%b/%Y:%H:%M:%S %z for ‘2021-11-29T10:32:45.879583103Z’
[2021/11/29 10:25:41] [error] [upstream] connection #256 to elasticsearch-logging-data.kubesphere-logging-system.svc:9200 timed out after 10 seconds
[2021/11/29 10:25:41] [error] [upstream] connection #257 to elasticsearch-logging-data.kubesphere-logging-system.svc:9200 timed out after 10 seconds
[2021/11/29 10:25:41] [error] [upstream] connection #258 to elasticsearch-logging-data.kubesphere-logging-system.svc:9200 timed out after 10 seconds
[2021/11/29 10:25:41] [error] [upstream] connection #259 to elasticsearch-logging-data.kubesphere-logging-system.svc:9200 timed out after 10 seconds
[2021/11/29 10:25:45] [error] [upstream] connection #-1 to elasticsearch-logging-data.kubesphere-logging-system.svc:9200 timed out after 10 seconds
求指导。谢谢
