例如:虚拟机,Fedora 35,8C/16G
例如:v1.21.7多节点。
例如,docker
Client:
Version: 20.10.9
API version: 1.41
Go version: go1.16.8
Git commit: c2ea9bc
Built: Sun Oct 10 22:41:20 2021
Experimental: true
Server:
Version: 20.10.9
Git commit: 79ea9d3
Built: Fri Oct 8 00:00:00 2021
Version: 1.5.7
GitCommit:
Version: 1.0.2
GitCommit: c42bf99-dirty
Version: 0.19.0
GitCommit:
例如:v3.0.0。离线安装。已有K8s安装。
在 istio 环境下有 pod 处于 Init:CrashLoopBackOff 状态
再开启istio功能下,部署示例应用bookinfo,看到容器组中的istio-init处于无限重启状态:
istio-init的容器日志如下:日志
Environment:
ENVOY_PORT=
INBOUND_CAPTURE_PORT=
ISTIO_INBOUND_INTERCEPTION_MODE=
ISTIO_INBOUND_TPROXY_MARK=
ISTIO_INBOUND_TPROXY_ROUTE_TABLE=
ISTIO_INBOUND_PORTS=
ISTIO_LOCAL_EXCLUDE_PORTS=
ISTIO_SERVICE_CIDR=
ISTIO_SERVICE_EXCLUDE_CIDR=
Variables:
PROXY_PORT=15001
PROXY_INBOUND_CAPTURE_PORT=15006
PROXY_UID=1337
PROXY_GID=1337
INBOUND_INTERCEPTION_MODE=REDIRECT
INBOUND_TPROXY_MARK=1337
INBOUND_TPROXY_ROUTE_TABLE=133
INBOUND_PORTS_INCLUDE=*
INBOUND_PORTS_EXCLUDE=15020
OUTBOUND_IP_RANGES_INCLUDE=*
OUTBOUND_IP_RANGES_EXCLUDE=
OUTBOUND_PORTS_EXCLUDE=
KUBEVIRT_INTERFACES=
ENABLE_INBOUND_IPV6=
+ iptables -t nat -N ISTIO_REDIRECT
iptables: Chain already exists.
+ dump
+ iptables-save
# Generated by iptables-save v1.6.1 on Fri Dec 24 07:07:15 2021
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
:ISTIO_REDIRECT - [0:0]
COMMIT
# Completed on Fri Dec 24 07:07:15 2021
+ ip6tables-save
谷歌后网上说是要把istio-init 的privileged改成true,请大神指教,谢谢。
productpage-v1-8688b47d7c-s6vvk的配置文件如下附录:
附录
kind: Pod
generateName: productpage-v1-8688b47d7c-
namespace: project01
app: productpage
app.kubernetes.io/name: bookinfo
app.kubernetes.io/version: v1
pod-template-hash: 8688b47d7c
security.istio.io/tlsMode: istio
version: v1
annotations:
cni.projectcalico.org/podIP: 10.100.49.105/32
cni.projectcalico.org/podIPs: 10.100.49.105/32
sidecar.istio.io/inject: ‘true’
sidecar.istio.io/status: >-
{“version”:“7d3a4daf8f4b6208c528218b6bf6e38059855b1ab8185a50d223bb8756651fa5”,“initContainers”:[“istio-init”],“containers”:[“istio-proxy”],“volumes”:[“istio-envoy”,“istio-certs”],“imagePullSecrets”:null}
volumes:
- name: kube-api-access-tsv72
projected:
sources:
- serviceAccountToken:
expirationSeconds: 3607
path: token
- configMap:
items:
- key: ca.crt
path: ca.crt
- downwardAPI:
items:
- path: namespace
fieldRef:
fieldPath: metadata.namespace
defaultMode: 420
- name: istio-envoy
emptyDir:
medium: Memory
- name: istio-certs
secret:
secretName: istio.default
defaultMode: 420
optional: true
initContainers:
- name: istio-init
image: ‘10.200.43.153/istio/proxyv2:1.4.8’
command:
- istio-iptables
- ‘-p’
- ‘15001’
- ‘-z’
- ‘15006’
- ‘-u’
- ‘1337’
- ‘-m’
- REDIRECT
- ‘-i’
- ‘-x’
- ‘-b’
- ‘-d’
- ‘15020’
limits:
cpu: 100m
memory: 50Mi
requests:
cpu: 10m
memory: 10Mi
volumeMounts:
readOnly: true
mountPath: /var/run/secrets/kubernetes.io/serviceaccount
terminationMessagePath: /dev/termination-log
terminationMessagePolicy: File
imagePullPolicy: IfNotPresent
securityContext:
capabilities:
add:
- NET_ADMIN
- NET_RAW
drop:
- ALL
privileged: false
runAsUser: 0
runAsGroup: 0
runAsNonRoot: false
readOnlyRootFilesystem: false
allowPrivilegeEscalation: false
containers:
- name: productpage
image: ‘10.200.43.153/kubesphere/examples-bookinfo-productpage-v1:1.13.0’
ports:
- name: http-web
containerPort: 9080
protocol: TCP
limits:
cpu: ‘1’
memory: 1000Mi
requests:
cpu: 10m
memory: 10Mi
volumeMounts:
readOnly: true
- name: istio-proxy
args:
- proxy
- sidecar
- ‘–domain’
- $(POD_NAMESPACE).svc.cluster.local
- ‘–configPath’
- /etc/istio/proxy
- ‘–binaryPath’
- /usr/local/bin/envoy
- ‘–serviceCluster’
- productpage.$(POD_NAMESPACE)
- ‘–drainDuration’
- 45s
- ‘–parentShutdownDuration’
- 1m0s
- ‘–discoveryAddress’
- ‘istio-pilot.istio-system:15010’
- ‘–zipkinAddress’
- ‘jaeger-collector.istio-system.svc:9411’
- ‘–dnsRefreshRate’
- 300s
- ‘–connectTimeout’
- 10s
- ‘–proxyAdminPort’
- ‘15000’
- ‘–concurrency’
- ‘2’
- ‘–controlPlaneAuthPolicy’
- NONE
- ‘–statusPort’
- ‘15020’
- ‘–applicationPorts’
- ‘9080’
ports:
- name: http-envoy-prom
containerPort: 15090
protocol: TCP
env:
- name: POD_NAME
valueFrom:
fieldRef:
- name: ISTIO_META_POD_PORTS
value: |-
{“name”:“http-web”,“containerPort”:9080,“protocol”:“TCP”}
- name: ISTIO_META_CLUSTER_ID
value: Kubernetes
- name: POD_NAMESPACE
valueFrom:
fieldRef:
- name: INSTANCE_IP
valueFrom:
fieldRef:
fieldPath: status.podIP
- name: SERVICE_ACCOUNT
valueFrom:
fieldRef:
fieldPath: spec.serviceAccountName
- name: ISTIO_META_POD_NAME
valueFrom:
fieldRef:
- name: ISTIO_META_CONFIG_NAMESPACE
valueFrom:
fieldRef:
- name: SDS_ENABLED
value: ‘false’
- name: ISTIO_META_INTERCEPTION_MODE
value: REDIRECT
- name: ISTIO_META_INCLUDE_INBOUND_PORTS
value: ‘9080’
- name: ISTIO_METAJSON_ANNOTATIONS
value: |
{“sidecar.istio.io/inject”:“true”}
- name: ISTIO_METAJSON_LABELS
value: >
{“app”:“productpage”,“app.kubernetes.io/name”:“bookinfo”,“app.kubernetes.io/version”:“v1”,“pod-template-hash”:“8688b47d7c”,“version”:“v1”}
- name: ISTIO_META_WORKLOAD_NAME
value: productpage-v1
- name: ISTIO_META_OWNER
value: >-
kubernetes://apis/apps/v1/namespaces/project01/deployments/productpage-v1
limits:
cpu: ‘2’
memory: 1Gi
requests:
cpu: 100m
memory: 128Mi
volumeMounts:
- name: istio-envoy
mountPath: /etc/istio/proxy
- name: istio-certs
readOnly: true
mountPath: /etc/certs/
readOnly: true
readinessProbe:
httpGet:
path: /healthz/ready
port: 15020
scheme: HTTP
initialDelaySeconds: 1
timeoutSeconds: 1
periodSeconds: 2
successThreshold: 1
failureThreshold: 30
securityContext:
capabilities:
drop:
- ALL
privileged: false
runAsUser: 1337
runAsGroup: 1337
runAsNonRoot: true
readOnlyRootFilesystem: true
restartPolicy: Always
terminationGracePeriodSeconds: 30
dnsPolicy: ClusterFirst
serviceAccountName: default
serviceAccount: default
nodeName: yxall02-b5tgjsnlid6l-node-1
securityContext: {}
schedulerName: default-scheduler
tolerations:
- key: node.kubernetes.io/not-ready
operator: Exists
effect: NoExecute
tolerationSeconds: 300
- key: node.kubernetes.io/unreachable
operator: Exists
effect: NoExecute
priority: 0
enableServiceLinks: true
preemptionPolicy: PreemptLowerPriority
