物理机,Centos 7.9 ,8C /32G
3Masters /7 workers
Client Version: version.Info{Major:“1”, Minor:“21”, GitVersion:“v1.21.5”, GitCommit:“aea7bbadd2fc0cd689de94a54e5b7b758869d691”, GitTreeState:“clean”, BuildDate:“2021-09-15T21:10:45Z”, GoVersion:“go1.16.8”, Compiler:“gc”, Platform:“linux/amd64”}
Server Version: version.Info{Major:“1”, Minor:“21”, GitVersion:“v1.21.5”, GitCommit:“aea7bbadd2fc0cd689de94a54e5b7b758869d691”, GitTreeState:“clean”, BuildDate:“2021-09-15T21:04:16Z”, GoVersion:“go1.16.8”, Compiler:“gc”, Platform:“linux/amd64”}
Docker Version
Client:
Version: 20.10.8
API version: 1.41
Go version: go1.16.6
Git commit: 3967b7d
Experimental: true
Version: 20.10.8
Git commit: 75249d8
Version: v1.4.9
尚未安装kubesphere,用的是 3.2.0版 kk, 准备分步骤安装:
  1. 只安装kubernetes –with-kubenetes
  2. 安装kubernetes dashboard
  3. 安装rook-ceph
  4. 安装kubesphere
    目前只安装了第一步以后,发现集群有问题。
  1. kubectl describe pod calico-kube-controller -n kube-system
    Events:
    Type Reason Age From Message
    Normal Scheduled 28m default-scheduler Successfully assigned kube-system/calico-kube-controllers-68586cd975-zqb7v to k8s-n0
    Normal Pulled 27m (x4 over 28m) kubelet Container image “registry.cn-beijing.aliyuncs.com/kubesphereio/kube-controllers:v3.20.0” already present on machine
    Normal Created 27m (x4 over 28m) kubelet Created container calico-kube-controllers
    Normal Started 27m (x4 over 28m) kubelet Started container calico-kube-controllers
    Warning Unhealthy 27m (x4 over 28m) kubelet Readiness probe failed: Failed to read status file /status/status.json: unexpected end of JSON input
    Warning BackOff 3m18s (x119 over 28m) kubelet Back-off restarting failed container
    1. kubectl logs -n kube-system calico-kube-controllers-68586cd975-zqb7v
      2022-01-02 08:02:21.709 [INFO][1] main.go 94: Loaded configuration from environment config=&config.Config{LogLevel:“info”, WorkloadEndpointWorkers:1, ProfileWorkers:1, PolicyWorkers:1, NodeWorkers:1, Kubeconfig:"", DatastoreType:“kubernetes”}
      W0102 08:02:21.711702 1 client_config.go:615] Neither –kubeconfig nor –master was specified. Using the inClusterConfig. Thismight not work.
      2022-01-02 08:02:21.712 [INFO][1] main.go 115: Ensuring Calico datastore is initialized
      2022-01-02 08:02:24.720 [ERROR][1] client.go 261: Error getting cluster information config ClusterInformation=“default” error=Get “https://10.233.0.1:443/apis/crd.projectcalico.org/v1/clusterinformations/default”: dial tcp 10.233.0.1:443: connect: no route to host
      2022-01-02 08:02:24.720 [FATAL][1] main.go 120: Failed to initialize Calico datastore error=Get “https://10.233.0.1:443/apis/crd.projectcalico.org/v1/clusterinformations/default”: dial tcp 10.233.0.1:443: connect: no route to host
    2. coredns也是类似的报错信息。
BTW: 我在安装的时候,纯内网环境,用httpproxy 和 https_proxy利用另一台主机作为正向代理机下载的images.
你的config.yaml提供一下呢
镜像是正常下载, 报错信息看起来是 coredns不能连接的kube-apiserver,网络不通
    6 天 后
    chauncey
    已解决,后来发现犯了一个极简单的错误。
    因为最开始是内网外网两根网线,所以默认网关是在外网网卡上。在部署k8s时,把所有的外网网线去掉了,导致没有默认路由了。
    后来把每个内网网卡配上默认网关以后,问题就解决了。
