例如:虚拟机,Centos7.6,2C/4G
将 kubectl version
命令执行结果贴在下方
Client Version: version.Info{Major:“1”, Minor:“21”, GitVersion:“v1.21.5”, GitCommit:“aea7bbadd2fc0cd689de94a54e5b7b758869d691”, GitTreeState:“clean”, BuildDate:“2021-09-15T21:10:45Z”, GoVersion:“go1.16.8”, Compiler:“gc”, Platform:“linux/amd64”}
Server Version: version.Info{Major:“1”, Minor:“21”, GitVersion:“v1.21.5”, GitCommit:“aea7bbadd2fc0cd689de94a54e5b7b758869d691”, GitTreeState:“clean”, BuildDate:“2021-09-15T21:04:16Z”, GoVersion:“go1.16.8”, Compiler:“gc”, Platform:“linux/amd64”}
将 docker version
/ crictl version
/ nerdctl version
结果贴在下方
[root@k8s-master data]# docker version
Client:
Version: 20.10.8
API version: 1.41
Go version: go1.16.6
Git commit: 3967b7d
Experimental: true
Version: 20.10.8
Git commit: 75249d8
Version: v1.4.9
Version: 1.0.1
GitCommit: v1.0.1-0-g4144b638
Version: 0.19.0
GitCommit: de40ad0
例如:v3.2.1。在线安装。使用kk安装。安装方法是按照
https://kubesphere.com.cn/docs/quick-start/all-in-one-on-linux/
安装完成后系统组件里的prometheus-operated和prometheus-k8s一直是异常状态,请问下该如何处理呢**
