• 安装部署
  • EdgeMesh 安装后 edge 节点无法正常进行网络通讯
master,虚拟机,Ubuntu20.04,4C/4G,10.9.11.113
worker1,虚拟机,Ubuntu20.04,4C/4G,10.9.11.114
edge-node,虚拟机,Ubuntu20.04,4C/4G,nat网络(集群无法访问edge,但edge可以访问集群,模拟实际场景)
❯ k version
Client Version: version.Info{Major:"1", Minor:"21", GitVersion:"v1.21.5", GitCommit:"aea7bbadd2fc0cd689de94a54e5b7b758869d691", GitTreeState:"clean", BuildDate:"2021-09-15T21:10:45Z", GoVersion:"go1.16.8", Compiler:"gc", Platform:"linux/amd64"}
Server Version: version.Info{Major:"1", Minor:"21", GitVersion:"v1.21.5", GitCommit:"aea7bbadd2fc0cd689de94a54e5b7b758869d691", GitTreeState:"clean", BuildDate:"2021-09-15T21:04:16Z", GoVersion:"go1.16.8", Compiler:"gc", Platform:"linux/amd64"}
❯ docker version
 Version:           20.10.12
 API version:       1.41
 Go version:        go1.16.12
 Git commit:        e91ed57
 Built:             Mon Dec 13 11:45:33 2021
 OS/Arch:           linux/amd64
 Context:           default
 Experimental:      true
  Version:          20.10.12
  API version:      1.41 (minimum version 1.12)
  Git commit:       459d0df
  Built:            Mon Dec 13 11:43:42 2021
  Experimental:     false
  Version:          1.4.12
  GitCommit:        7b11cfaabd73bb80907dd23182b9347b4245eb5d
  Version:          1.0.2
  GitCommit:        v1.0.2-0-g52b36a2
  Version:          0.19.0
  GitCommit:        de40ad0
在线安装,使用kk安装,v3.2.1,k8s: v1.25.1
安装完EdgeMesh后,edge节点网络异常
操作步骤:
  1. 安装商店、metric_server、kubeedge
  2. 添加边缘节点
  3. 通过商店安装 EdgeMesh
现象:
  1. 3个机器的 edgemesh-agent 日志详见二楼
  2. edge节点,此时任何网络请求都失败,无法pull镜像,集群也无法进入原来edge上的pods,edge也无法ssh连上去
master-edgemes-10zspc-agent.log
2022/01/28 16:48:35 INFO: Install client plugin, protocol: rest
2022/01/28 16:48:35 INFO: Installed service discovery plugin: edge
I0128 16:48:35.064400       1 server.go:62] Version: v1.9.0-11+d4dc2cfd0e2dc1-dirty
I0128 16:48:35.064428       1 server.go:96] [1] New informers manager
W0128 16:48:35.064440       1 client_config.go:617] Neither --kubeconfig nor --master was specified.  Using the inClusterConfig.  This might not work.
I0128 16:48:35.067012       1 server.go:103] [2] Prepare agent to run
I0128 16:48:35.088006       1 server.go:107] edgemesh-agent running on CloudMode
I0128 16:48:35.088030       1 server.go:110] [3] Register beehive modules
W0128 16:48:35.088066       1 module.go:37] Module edgedns is disabled, do not register
I0128 16:48:35.172084       1 module.go:34] Module edgeproxy registered successfully
W0128 16:48:35.172104       1 module.go:37] Module edgegateway is disabled, do not register
I0128 16:48:35.172181       1 manager.go:33] Use noCaManager to handle security
I0128 16:48:35.172207       1 nocamanager.go:38] Private key does not exist, generate a new one
I0128 16:48:35.175263       1 module.go:34] Module tunnelagent registered successfully
I0128 16:48:35.175547       1 server.go:119] [4] Install go-chassis plugins
I0128 16:48:35.175885       1 log.go:184] DEBUG: Installed strategy plugin: [RoundRobin].
I0128 16:48:35.176119       1 log.go:184] DEBUG: Installed strategy plugin: [Random].
I0128 16:48:35.176335       1 log.go:184] DEBUG: Installed strategy plugin: [ConsistentHash].
I0128 16:48:35.176538       1 log.go:184] DEBUG: ConfigurationFactory Initiated
I0128 16:48:35.176791       1 log.go:184] INFO: Configuration files: []
I0128 16:48:35.177078       1 log.go:184] WARN: empty configurtion from [FileSource]
I0128 16:48:35.177235       1 log.go:184] INFO: invoke dynamic handler:FileSource
I0128 16:48:35.177290       1 log.go:184] INFO: archaius init success
I0128 16:48:35.177305       1 server.go:124] [5] Start informers manager
I0128 16:48:35.177518       1 log.go:184] INFO: create new watcher
W0128 16:48:35.180092       1 shared_informer.go:372] The sharedIndexInformer has started, run more than once is not allowed
W0128 16:48:35.180205       1 shared_informer.go:372] The sharedIndexInformer has started, run more than once is not allowed
W0128 16:48:35.180537       1 shared_informer.go:372] The sharedIndexInformer has started, run more than once is not allowed
W0128 16:48:35.180593       1 shared_informer.go:372] The sharedIndexInformer has started, run more than once is not allowed
I0128 16:48:35.278691       1 server.go:128] [6] Start all modules
I0128 16:48:35.278775       1 core.go:24] Starting module edgeproxy
I0128 16:48:35.278810       1 core.go:24] Starting module tunnelagent
E0128 16:48:35.283995       1 tunnel.go:22] Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret "edgemeshaddrsecret" not found
I0128 16:48:40.209636       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:48:40.209763       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:48:40.209840       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:48:40.210142       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:48:40.210742       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:48:40.210835       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:48:40.210902       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:48:40.210962       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:48:40.210989       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:48:40.211021       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:48:40.211044       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:48:40.211066       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:48:40.211188       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:48:40.211226       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:48:40.211236       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:48:40.211239       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:48:40.211226       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:48:40.211262       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:48:40.211396       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:48:40.222863       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:48:40.223490       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:48:40.241614       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:48:40.246080       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:48:40.247520       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:48:40.247582       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:48:40.247623       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:48:40.247762       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:48:40.256135       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:48:40.275397       1 handler.go:95] Success proxy to master:10.233.70.8:9090
E0128 16:48:40.284925       1 tunnel.go:22] Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret "edgemeshaddrsecret" not found
I0128 16:48:40.918615       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:48:40.918786       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:48:40.918867       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:48:40.919235       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:48:40.921815       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:48:40.921960       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:48:40.922037       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:48:40.922399       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:48:40.939703       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:48:40.942526       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:48:41.013204       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:48:41.013388       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:48:41.013470       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:48:41.013967       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:48:41.033801       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:48:41.052065       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:48:41.381113       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:48:41.381221       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:48:41.381524       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:48:41.393985       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:48:41.403219       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:48:41.403926       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:48:41.405941       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:48:41.409278       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:48:41.412093       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:48:41.420260       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:48:41.420420       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:48:41.420504       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:48:41.420791       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:48:41.450730       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:48:44.007943       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:48:44.008427       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:48:44.008717       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:48:44.009757       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:48:44.038977       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:48:44.094249       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:48:49.129096       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:48:49.129629       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:48:49.130094       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:48:49.131325       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:48:49.180741       1 handler.go:95] Success proxy to master:10.233.70.8:9090
E0128 16:48:50.286223       1 tunnel.go:22] Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret "edgemeshaddrsecret" not found
I0128 16:48:54.128102       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:48:54.128256       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:48:54.128345       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:48:54.128786       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:48:54.169005       1 handler.go:95] Success proxy to master:10.233.70.8:9090
E0128 16:48:55.286811       1 tunnel.go:22] Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret "edgemeshaddrsecret" not found
I0128 16:48:59.129812       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:48:59.129964       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:48:59.130118       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:48:59.130654       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:48:59.167964       1 handler.go:95] Success proxy to master:10.233.70.8:9090
E0128 16:49:00.287003       1 tunnel.go:22] Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret "edgemeshaddrsecret" not found
I0128 16:49:04.128048       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:49:09.130680       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:49:09.131389       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:49:09.181835       1 handler.go:95] Success proxy to master:10.233.70.8:9090
W0128 16:49:10.289124       1 tunnel.go:28] Connection between agent and server [/ip4/10.9.11.113/tcp/20004 /ip4/127.0.0.1/tcp/20004 /ip4/218.17.55.228/tcp/20004] is not established, try connect
I0128 16:49:10.289173       1 tunnel.go:31] Tunnel agent connecting to tunnel server
I0128 16:49:10.298970       1 tunnel.go:50] agent success connected to server [/ip4/10.9.11.113/tcp/20004 /ip4/127.0.0.1/tcp/20004 /ip4/218.17.55.228/tcp/20004]
I0128 16:49:14.137952       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:49:14.138105       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:49:14.138215       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:50:56.879002       1 proxy.go:42] clusterIP: 10.233.36.253, servicePort: 443
I0128 16:50:56.879174       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:50:56.879257       1 log.go:184] ERROR: Lb err: [targetPort 443 not found in service: kube-system.metrics-server]
E0128 16:50:56.879269       1 tcp.go:67] handle l4 proxy err : lb: targetPort 443 not found in service: kube-system.metrics-server
I0128 16:50:56.896037       1 proxy.go:42] clusterIP: 10.233.36.253, servicePort: 443
I0128 16:50:56.896144       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:50:56.896197       1 log.go:184] ERROR: Lb err: [targetPort 443 not found in service: kube-system.metrics-server]
E0128 16:50:56.896205       1 tcp.go:67] handle l4 proxy err : lb: targetPort 443 not found in service: kube-system.metrics-server
I0128 16:50:56.912580       1 proxy.go:42] clusterIP: 10.233.36.253, servicePort: 443
I0128 16:50:56.912764       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:50:56.912897       1 log.go:184] ERROR: Lb err: [targetPort 443 not found in service: kube-system.metrics-server]
E0128 16:50:56.912918       1 tcp.go:67] handle l4 proxy err : lb: targetPort 443 not found in service: kube-system.metrics-server
I0128 16:50:59.126105       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:50:59.126296       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:50:59.126409       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:50:59.127014       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:51:41.657717       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:51:41.657802       1 log.go:184] ERROR: Lb err: [targetPort 443 not found in service: kube-system.metrics-server]
E0128 16:51:41.657826       1 tcp.go:67] handle l4 proxy err : lb: targetPort 443 not found in service: kube-system.metrics-server
I0128 16:51:42.038813       1 proxy.go:42] clusterIP: 10.233.26.85, servicePort: 80
I0128 16:51:42.039043       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:51:42.039384       1 handler.go:59] l4 proxy get tcpserver address: master:10.233.70.8:9090
I0128 16:51:42.040118       1 handler.go:89] l4 proxy start proxy data between tcpserver 10.233.70.8:9090
I0128 16:51:42.061485       1 handler.go:95] Success proxy to master:10.233.70.8:9090
I0128 16:51:51.706065       1 proxy.go:42] clusterIP: 10.233.36.253, servicePort: 443
I0128 16:51:51.706246       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:51:51.706323       1 log.go:184] ERROR: Lb err: [targetPort 443 not found in service: kube-system.metrics-server]
E0128 16:51:51.706334       1 tcp.go:67] handle l4 proxy err : lb: targetPort 443 not found in service: kube-system.metrics-server
I0128 16:51:52.840829       1 proxy.go:42] clusterIP: 10.233.36.253, servicePort: 443
I0128 16:51:52.841191       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:51:52.841309       1 log.go:184] ERROR: Lb err: [targetPort 443 not found in service: kube-system.metrics-server]
E0128 16:51:52.841322       1 tcp.go:67] handle l4 proxy err : lb: targetPort 443 not found in service: kube-system.metrics-server
I0128 16:51:52.853585       1 proxy.go:42] clusterIP: 10.233.36.253, servicePort: 443
I0128 16:51:52.853720       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
worker1-edgemes-10zspc-agent.log
2022/01/28 16:48:13 INFO: Install client plugin, protocol: rest
2022/01/28 16:48:13 INFO: Installed service discovery plugin: edge
I0128 16:48:13.686324       1 server.go:62] Version: v1.9.0-11+d4dc2cfd0e2dc1-dirty
I0128 16:48:13.686354       1 server.go:96] [1] New informers manager
W0128 16:48:13.686367       1 client_config.go:617] Neither --kubeconfig nor --master was specified.  Using the inClusterConfig.  This might not work.
I0128 16:48:13.687244       1 server.go:103] [2] Prepare agent to run
I0128 16:48:13.722300       1 server.go:107] edgemesh-agent running on CloudMode
I0128 16:48:13.722352       1 server.go:110] [3] Register beehive modules
W0128 16:48:13.722399       1 module.go:37] Module edgedns is disabled, do not register
I0128 16:48:14.419208       1 module.go:34] Module edgeproxy registered successfully
W0128 16:48:14.419268       1 module.go:37] Module edgegateway is disabled, do not register
I0128 16:48:14.419452       1 manager.go:33] Use noCaManager to handle security
I0128 16:48:14.419614       1 nocamanager.go:38] Private key does not exist, generate a new one
I0128 16:48:14.430398       1 module.go:34] Module tunnelagent registered successfully
I0128 16:48:14.430436       1 server.go:119] [4] Install go-chassis plugins
I0128 16:48:14.430625       1 log.go:184] DEBUG: Installed strategy plugin: [RoundRobin].
I0128 16:48:14.430642       1 log.go:184] DEBUG: Installed strategy plugin: [Random].
I0128 16:48:14.430652       1 log.go:184] DEBUG: Installed strategy plugin: [ConsistentHash].
I0128 16:48:14.430672       1 log.go:184] DEBUG: ConfigurationFactory Initiated
I0128 16:48:14.430701       1 log.go:184] INFO: Configuration files: []
I0128 16:48:14.430720       1 log.go:184] WARN: empty configurtion from [FileSource]
I0128 16:48:14.430922       1 log.go:184] INFO: invoke dynamic handler:FileSource
I0128 16:48:14.431088       1 log.go:184] INFO: archaius init success
I0128 16:48:14.431109       1 server.go:124] [5] Start informers manager
I0128 16:48:14.444246       1 log.go:184] INFO: create new watcher
W0128 16:48:14.444296       1 shared_informer.go:372] The sharedIndexInformer has started, run more than once is not allowed
W0128 16:48:14.445174       1 shared_informer.go:372] The sharedIndexInformer has started, run more than once is not allowed
W0128 16:48:14.446132       1 shared_informer.go:372] The sharedIndexInformer has started, run more than once is not allowed
W0128 16:48:14.446160       1 shared_informer.go:372] The sharedIndexInformer has started, run more than once is not allowed
I0128 16:48:14.532483       1 server.go:128] [6] Start all modules
I0128 16:48:14.532650       1 core.go:24] Starting module edgeproxy
I0128 16:48:14.532804       1 core.go:24] Starting module tunnelagent
E0128 16:48:14.532884       1 tunnel.go:22] Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret "edgemeshaddrsecret" not found
E0128 16:48:19.533869       1 tunnel.go:22] Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret "edgemeshaddrsecret" not found
E0128 16:48:24.534566       1 tunnel.go:22] Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret "edgemeshaddrsecret" not found
E0128 16:48:29.535552       1 tunnel.go:22] Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret "edgemeshaddrsecret" not found
E0128 16:48:34.536239       1 tunnel.go:22] Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret "edgemeshaddrsecret" not found
E0128 16:48:39.537696       1 tunnel.go:22] Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret "edgemeshaddrsecret" not found
E0128 16:48:44.538130       1 tunnel.go:22] Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret "edgemeshaddrsecret" not found
E0128 16:48:49.538469       1 tunnel.go:22] Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret "edgemeshaddrsecret" not found
E0128 16:48:54.539352       1 tunnel.go:22] Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret "edgemeshaddrsecret" not found
E0128 16:48:59.540438       1 tunnel.go:22] Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret "edgemeshaddrsecret" not found
E0128 16:49:04.541474       1 tunnel.go:22] Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret "edgemeshaddrsecret" not found
W0128 16:49:09.542883       1 tunnel.go:28] Connection between agent and server [/ip4/10.9.11.113/tcp/20004 /ip4/127.0.0.1/tcp/20004 /ip4/218.17.55.228/tcp/20004] is not established, try connect
I0128 16:49:09.542963       1 tunnel.go:31] Tunnel agent connecting to tunnel server
I0128 16:49:09.565728       1 tunnel.go:50] agent success connected to server [/ip4/10.9.11.113/tcp/20004 /ip4/127.0.0.1/tcp/20004 /ip4/218.17.55.228/tcp/20004]
I0128 16:52:05.024056       1 proxy.go:42] clusterIP: 10.233.30.202, servicePort: 19093
I0128 16:52:05.024216       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:52:05.024340       1 log.go:184] ERROR: Lb err: [targetPort 19093 not found in service: kubesphere-monitoring-system.notification-manager-svc]
E0128 16:52:05.024352       1 tcp.go:67] handle l4 proxy err : lb: targetPort 19093 not found in service: kubesphere-monitoring-system.notification-manager-svc
I0128 16:52:05.271374       1 proxy.go:42] clusterIP: 10.233.30.202, servicePort: 19093
I0128 16:52:05.271606       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:52:05.271734       1 log.go:184] ERROR: Lb err: [targetPort 19093 not found in service: kubesphere-monitoring-system.notification-manager-svc]
E0128 16:52:05.271894       1 tcp.go:67] handle l4 proxy err : lb: targetPort 19093 not found in service: kubesphere-monitoring-system.notification-manager-svc
I0128 16:52:05.717307       1 proxy.go:42] clusterIP: 10.233.30.202, servicePort: 19093
I0128 16:52:05.717482       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:52:05.717562       1 log.go:184] ERROR: Lb err: [targetPort 19093 not found in service: kubesphere-monitoring-system.notification-manager-svc]
E0128 16:52:05.717575       1 tcp.go:67] handle l4 proxy err : lb: targetPort 19093 not found in service: kubesphere-monitoring-system.notification-manager-svc
I0128 16:52:06.860143       1 proxy.go:42] clusterIP: 10.233.30.202, servicePort: 19093
I0128 16:52:06.860308       1 log.go:184] DEBUG: add [2] handlers for chain [tcp]
I0128 16:52:06.860389       1 log.go:184] ERROR: Lb err: [targetPort 19093 not found in service: kubesphere-monitoring-system.notification-manager-svc]
E0128 16:52:06.860401       1 tcp.go:67] handle l4 proxy err : lb: targetPort 19093 not found in service: kubesphere-monitoring-system.notification-manager-svc
I0128 16:52:08.558955       1 proxy.go:42] clusterIP: 10.233.30.202, servicePort: 19093
edge-edgemes-10zspc-agent.log
2022/01/28 16:48:48 INFO: Install client plugin, protocol: rest
2022/01/28 16:48:48 INFO: Installed service discovery plugin: edge
I0128 16:48:48.667577       1 server.go:62] Version: v1.9.0-11+d4dc2cfd0e2dc1-dirty
I0128 16:48:48.667608       1 server.go:96] [1] New informers manager
I0128 16:48:48.667931       1 server.go:103] [2] Prepare agent to run
I0128 16:48:48.668096       1 netif.go:98] bridge device edgemesh0 already exists
I0128 16:48:48.669000       1 server.go:107] edgemesh-agent running on EdgeMode
I0128 16:48:48.669014       1 server.go:110] [3] Register beehive modules
I0128 16:48:48.669030       1 module.go:34] Module edgedns registered successfully
W0128 16:48:48.718567       1 iptables.go:162] failed to get kubernetes.default service, err: Get "http://127.0.0.1:10550/api/v1/namespaces/default/services/kubernetes": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:48.719005       1 iptables.go:170] failed to get coredns.kube-system service, err: Get "http://127.0.0.1:10550/api/v1/namespaces/kube-system/services/coredns": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:48.719496       1 iptables.go:178] failed to list service labeled with k8s-app=kube-dns, err: Get "http://127.0.0.1:10550/api/v1/namespaces/kube-system/services?labelSelector=k8s-app%3Dkube-dns": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:48.719884       1 iptables.go:189] failed to list service labeled with noproxy=edgemesh, err: Get "http://127.0.0.1:10550/api/v1/services?labelSelector=noproxy%3Dedgemesh": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:48.719914       1 iptables.go:278] failed to create ignore rules: Get "http://127.0.0.1:10550/api/v1/services?labelSelector=noproxy%3Dedgemesh": dial tcp 127.0.0.1:10550: connect: connection refused
I0128 16:48:48.731506       1 module.go:34] Module edgeproxy registered successfully
W0128 16:48:48.731609       1 module.go:37] Module edgegateway is disabled, do not register
I0128 16:48:48.731702       1 manager.go:33] Use noCaManager to handle security
I0128 16:48:48.731741       1 nocamanager.go:38] Private key does not exist, generate a new one
I0128 16:48:48.736868       1 module.go:34] Module tunnelagent registered successfully
I0128 16:48:48.736898       1 server.go:119] [4] Install go-chassis plugins
I0128 16:48:48.737197       1 log.go:184] DEBUG: Installed strategy plugin: [RoundRobin].
I0128 16:48:48.737214       1 log.go:184] DEBUG: Installed strategy plugin: [Random].
I0128 16:48:48.737284       1 log.go:184] DEBUG: Installed strategy plugin: [ConsistentHash].
I0128 16:48:48.737301       1 log.go:184] DEBUG: ConfigurationFactory Initiated
I0128 16:48:48.737314       1 log.go:184] INFO: Configuration files: []
I0128 16:48:48.737332       1 log.go:184] WARN: empty configurtion from [FileSource]
I0128 16:48:48.737342       1 log.go:184] INFO: invoke dynamic handler:FileSource
I0128 16:48:48.737392       1 log.go:184] INFO: archaius init success
I0128 16:48:48.737402       1 server.go:124] [5] Start informers manager
I0128 16:48:48.737523       1 log.go:184] INFO: create new watcher
W0128 16:48:48.738003       1 shared_informer.go:372] The sharedIndexInformer has started, run more than once is not allowed
W0128 16:48:48.738478       1 shared_informer.go:372] The sharedIndexInformer has started, run more than once is not allowed
W0128 16:48:48.738907       1 shared_informer.go:372] The sharedIndexInformer has started, run more than once is not allowed
W0128 16:48:48.738917       1 shared_informer.go:372] The sharedIndexInformer has started, run more than once is not allowed
W0128 16:48:48.739594       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:48.739690       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Pod: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:48.739762       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:48.739795       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Secret: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:48.739852       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:48.739884       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1alpha3.DestinationRule: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:48.739979       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:48.740008       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Service: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:48.740061       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:48.740086       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Endpoints: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:49.627168       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:49.627369       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Endpoints: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:49.781800       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:49.781982       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Pod: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:49.935486       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:49.935617       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Secret: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:50.019674       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:50.019800       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1alpha3.DestinationRule: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:50.327109       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:50.327152       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Service: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:51.819035       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:51.819112       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Secret: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:52.570477       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:52.571317       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Endpoints: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:52.873334       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:52.873458       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1alpha3.DestinationRule: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:52.960016       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:52.960135       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Pod: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:53.319626       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:53.319798       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Service: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:55.390101       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:55.390228       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Secret: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:48:57.234401       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
E0128 16:48:57.234561       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Endpoints: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
W0128 16:49:07.933226       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": read tcp 127.0.0.1:39578->127.0.0.1:10550: read: connection reset by peer
I0128 16:49:07.933421       1 trace.go:205] Trace[1935192880]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:48:57.847) (total time: 10086ms):
Trace[1935192880]: ---"Objects listed" error:Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": read tcp 127.0.0.1:39578->127.0.0.1:10550: read: connection reset by peer 10086ms (16:49:07.933)
Trace[1935192880]: [10.086214002s] [10.086214002s] END
E0128 16:49:07.933458       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1alpha3.DestinationRule: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": read tcp 127.0.0.1:39578->127.0.0.1:10550: read: connection reset by peer
W0128 16:49:08.368217       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": EOF
I0128 16:49:08.368400       1 trace.go:205] Trace[924086577]: "Reflector ListAndWatch" name:k8s.io/client-go/informers/factory.go:134 (28-Jan-2022 16:48:58.309) (total time: 10059ms):
Trace[924086577]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": EOF 10059ms (16:49:08.368)
Trace[924086577]: [10.059220277s] [10.059220277s] END
E0128 16:49:08.368436       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Pod: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": EOF
W0128 16:49:09.274966       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": read tcp 127.0.0.1:39590->127.0.0.1:10550: read: connection reset by peer
I0128 16:49:09.275134       1 trace.go:205] Trace[1218867398]: "Reflector ListAndWatch" name:k8s.io/client-go/informers/factory.go:134 (28-Jan-2022 16:48:59.115) (total time: 10159ms):
Trace[1218867398]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": read tcp 127.0.0.1:39590->127.0.0.1:10550: read: connection reset by peer 10159ms (16:49:09.274)
Trace[1218867398]: [10.159888296s] [10.159888296s] END
E0128 16:49:09.275201       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Service: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": read tcp 127.0.0.1:39590->127.0.0.1:10550: read: connection reset by peer
W0128 16:49:17.053989       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": read tcp 127.0.0.1:39632->127.0.0.1:10550: read: connection reset by peer
I0128 16:49:17.054105       1 trace.go:205] Trace[1658630943]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:49:07.030) (total time: 10023ms):
Trace[1658630943]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": read tcp 127.0.0.1:39632->127.0.0.1:10550: read: connection reset by peer 10023ms (16:49:17.053)
Trace[1658630943]: [10.023666864s] [10.023666864s] END
E0128 16:49:17.054154       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Secret: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": read tcp 127.0.0.1:39632->127.0.0.1:10550: read: connection reset by peer
W0128 16:49:17.549792       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": read tcp 127.0.0.1:39636->127.0.0.1:10550: read: connection reset by peer
I0128 16:49:17.549923       1 trace.go:205] Trace[1881187655]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:49:07.520) (total time: 10029ms):
Trace[1881187655]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": read tcp 127.0.0.1:39636->127.0.0.1:10550: read: connection reset by peer 10029ms (16:49:17.549)
Trace[1881187655]: [10.029112371s] [10.029112371s] END
E0128 16:49:17.549996       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Endpoints: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": read tcp 127.0.0.1:39636->127.0.0.1:10550: read: connection reset by peer
W0128 16:49:24.658530       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": read tcp 127.0.0.1:39682->127.0.0.1:10550: read: connection reset by peer
I0128 16:49:24.658845       1 trace.go:205] Trace[796629538]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:49:14.543) (total time: 10115ms):
Trace[796629538]: ---"Objects listed" error:Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": read tcp 127.0.0.1:39682->127.0.0.1:10550: read: connection reset by peer 10114ms (16:49:24.658)
Trace[796629538]: [10.115132078s] [10.115132078s] END
E0128 16:49:24.658936       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1alpha3.DestinationRule: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": read tcp 127.0.0.1:39682->127.0.0.1:10550: read: connection reset by peer
W0128 16:49:27.395206       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": EOF
I0128 16:49:27.395474       1 trace.go:205] Trace[1500621839]: "Reflector ListAndWatch" name:k8s.io/client-go/informers/factory.go:134 (28-Jan-2022 16:49:17.329) (total time: 10066ms):
Trace[1500621839]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": EOF 10066ms (16:49:27.395)
Trace[1500621839]: [10.066230754s] [10.066230754s] END
E0128 16:49:27.395501       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Service: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": EOF
W0128 16:49:28.682629       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": EOF
I0128 16:49:28.683447       1 trace.go:205] Trace[1008732287]: "Reflector ListAndWatch" name:k8s.io/client-go/informers/factory.go:134 (28-Jan-2022 16:49:18.608) (total time: 10073ms):
Trace[1008732287]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": EOF 10073ms (16:49:28.682)
Trace[1008732287]: [10.073919833s] [10.073919833s] END
E0128 16:49:28.683495       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Pod: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": EOF
W0128 16:49:43.895898       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": EOF
I0128 16:49:43.896105       1 trace.go:205] Trace[221084773]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:49:33.728) (total time: 10167ms):
Trace[221084773]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": EOF 10167ms (16:49:43.895)
Trace[221084773]: [10.167907391s] [10.167907391s] END
E0128 16:49:43.896135       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Endpoints: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": EOF
W0128 16:49:44.458399       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": EOF
I0128 16:49:44.458552       1 trace.go:205] Trace[1055830966]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:49:34.321) (total time: 10137ms):
Trace[1055830966]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": EOF 10137ms (16:49:44.458)
Trace[1055830966]: [10.137154469s] [10.137154469s] END
E0128 16:49:44.458573       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Secret: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": EOF
W0128 16:49:53.550759       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": read tcp 127.0.0.1:39804->127.0.0.1:10550: read: connection reset by peer
I0128 16:49:53.550912       1 trace.go:205] Trace[956811060]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:49:43.322) (total time: 10228ms):
Trace[956811060]: ---"Objects listed" error:Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": read tcp 127.0.0.1:39804->127.0.0.1:10550: read: connection reset by peer 10228ms (16:49:53.550)
Trace[956811060]: [10.228347213s] [10.228347213s] END
E0128 16:49:53.550941       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1alpha3.DestinationRule: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": read tcp 127.0.0.1:39804->127.0.0.1:10550: read: connection reset by peer
W0128 16:49:57.399932       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": read tcp 127.0.0.1:39820->127.0.0.1:10550: read: connection reset by peer
I0128 16:49:57.400089       1 trace.go:205] Trace[137150171]: "Reflector ListAndWatch" name:k8s.io/client-go/informers/factory.go:134 (28-Jan-2022 16:49:47.335) (total time: 10064ms):
Trace[137150171]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": read tcp 127.0.0.1:39820->127.0.0.1:10550: read: connection reset by peer 10064ms (16:49:57.399)
Trace[137150171]: [10.064291814s] [10.064291814s] END
E0128 16:49:57.400123       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Pod: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": read tcp 127.0.0.1:39820->127.0.0.1:10550: read: connection reset by peer
W0128 16:49:57.588944       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": EOF
I0128 16:49:57.589135       1 trace.go:205] Trace[341105354]: "Reflector ListAndWatch" name:k8s.io/client-go/informers/factory.go:134 (28-Jan-2022 16:49:47.500) (total time: 10088ms):
Trace[341105354]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": EOF 10088ms (16:49:57.588)
Trace[341105354]: [10.088880744s] [10.088880744s] END
E0128 16:49:57.589221       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Service: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": EOF
W0128 16:50:34.931797       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": http: server closed idle connection
E0128 16:50:34.931929       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Pod: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": http: server closed idle connection
W0128 16:50:36.570958       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": read tcp 127.0.0.1:39892->127.0.0.1:10550: read: connection reset by peer
I0128 16:50:36.571057       1 trace.go:205] Trace[1151179211]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:50:26.341) (total time: 10229ms):
Trace[1151179211]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": read tcp 127.0.0.1:39892->127.0.0.1:10550: read: connection reset by peer 10229ms (16:50:36.570)
Trace[1151179211]: [10.229865106s] [10.229865106s] END
E0128 16:50:36.571076       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Endpoints: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": read tcp 127.0.0.1:39892->127.0.0.1:10550: read: connection reset by peer
W0128 16:50:37.002077       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": EOF
I0128 16:50:37.002530       1 trace.go:205] Trace[868114787]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:50:26.932) (total time: 10070ms):
Trace[868114787]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": EOF 10070ms (16:50:37.002)
Trace[868114787]: [10.070457817s] [10.070457817s] END
E0128 16:50:37.002828       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Secret: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": EOF
W0128 16:50:47.059779       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": http: server closed idle connection
E0128 16:50:47.059994       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Service: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": http: server closed idle connection
W0128 16:50:52.202781       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": EOF
I0128 16:50:52.202932       1 trace.go:205] Trace[479430434]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:50:42.035) (total time: 10167ms):
Trace[479430434]: ---"Objects listed" error:Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": EOF 10167ms (16:50:52.202)
Trace[479430434]: [10.16738063s] [10.16738063s] END
E0128 16:50:52.202960       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1alpha3.DestinationRule: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": EOF
W0128 16:51:23.073683       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": read tcp 127.0.0.1:39994->127.0.0.1:10550: read: connection reset by peer
I0128 16:51:23.073833       1 trace.go:205] Trace[1431533874]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:51:12.987) (total time: 10086ms):
Trace[1431533874]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": read tcp 127.0.0.1:39994->127.0.0.1:10550: read: connection reset by peer 10086ms (16:51:23.073)
Trace[1431533874]: [10.086195851s] [10.086195851s] END
E0128 16:51:23.073857       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Endpoints: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": read tcp 127.0.0.1:39994->127.0.0.1:10550: read: connection reset by peer
W0128 16:51:26.835506       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": read tcp 127.0.0.1:40020->127.0.0.1:10550: read: connection reset by peer
I0128 16:51:26.835668       1 trace.go:205] Trace[2102965231]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:51:16.795) (total time: 10040ms):
Trace[2102965231]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": read tcp 127.0.0.1:40020->127.0.0.1:10550: read: connection reset by peer 10040ms (16:51:26.835)
Trace[2102965231]: [10.040250646s] [10.040250646s] END
E0128 16:51:26.835695       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Secret: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": read tcp 127.0.0.1:40020->127.0.0.1:10550: read: connection reset by peer
W0128 16:51:27.762671       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": EOF
I0128 16:51:27.762852       1 trace.go:205] Trace[1559822416]: "Reflector ListAndWatch" name:k8s.io/client-go/informers/factory.go:134 (28-Jan-2022 16:51:17.684) (total time: 10078ms):
Trace[1559822416]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": EOF 10078ms (16:51:27.762)
Trace[1559822416]: [10.078260565s] [10.078260565s] END
E0128 16:51:27.762883       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Pod: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": EOF
W0128 16:51:33.252560       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": read tcp 127.0.0.1:40038->127.0.0.1:10550: read: connection reset by peer
I0128 16:51:33.252749       1 trace.go:205] Trace[1459447761]: "Reflector ListAndWatch" name:k8s.io/client-go/informers/factory.go:134 (28-Jan-2022 16:51:23.113) (total time: 10139ms):
Trace[1459447761]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": read tcp 127.0.0.1:40038->127.0.0.1:10550: read: connection reset by peer 10139ms (16:51:33.252)
Trace[1459447761]: [10.139533568s] [10.139533568s] END
E0128 16:51:33.252779       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Service: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": read tcp 127.0.0.1:40038->127.0.0.1:10550: read: connection reset by peer
W0128 16:51:48.786406       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": EOF
I0128 16:51:48.786569       1 trace.go:205] Trace[1010583348]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:51:38.749) (total time: 10037ms):
Trace[1010583348]: ---"Objects listed" error:Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": EOF 10037ms (16:51:48.786)
Trace[1010583348]: [10.037463576s] [10.037463576s] END
E0128 16:51:48.786595       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1alpha3.DestinationRule: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": EOF
W0128 16:52:12.015949       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": read tcp 127.0.0.1:40138->127.0.0.1:10550: read: connection reset by peer
I0128 16:52:12.016108       1 trace.go:205] Trace[1741765841]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:52:01.951) (total time: 10065ms):
Trace[1741765841]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": read tcp 127.0.0.1:40138->127.0.0.1:10550: read: connection reset by peer 10064ms (16:52:12.015)
Trace[1741765841]: [10.065026656s] [10.065026656s] END
E0128 16:52:12.016137       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Endpoints: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": read tcp 127.0.0.1:40138->127.0.0.1:10550: read: connection reset by peer
W0128 16:52:14.735131       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": read tcp 127.0.0.1:40152->127.0.0.1:10550: read: connection reset by peer
I0128 16:52:14.735341       1 trace.go:205] Trace[1212335811]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:52:04.683) (total time: 10051ms):
Trace[1212335811]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": read tcp 127.0.0.1:40152->127.0.0.1:10550: read: connection reset by peer 10051ms (16:52:14.735)
Trace[1212335811]: [10.05131829s] [10.05131829s] END
E0128 16:52:14.735380       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Secret: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": read tcp 127.0.0.1:40152->127.0.0.1:10550: read: connection reset by peer
W0128 16:52:14.879236       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": read tcp 127.0.0.1:40154->127.0.0.1:10550: read: connection reset by peer
I0128 16:52:14.879416       1 trace.go:205] Trace[279479726]: "Reflector ListAndWatch" name:k8s.io/client-go/informers/factory.go:134 (28-Jan-2022 16:52:04.807) (total time: 10071ms):
Trace[279479726]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": read tcp 127.0.0.1:40154->127.0.0.1:10550: read: connection reset by peer 10071ms (16:52:14.879)
Trace[279479726]: [10.071816717s] [10.071816717s] END
E0128 16:52:14.879445       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Service: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": read tcp 127.0.0.1:40154->127.0.0.1:10550: read: connection reset by peer
W0128 16:52:18.925461       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": EOF
I0128 16:52:18.925608       1 trace.go:205] Trace[1719610177]: "Reflector ListAndWatch" name:k8s.io/client-go/informers/factory.go:134 (28-Jan-2022 16:52:08.793) (total time: 10131ms):
Trace[1719610177]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": EOF 10131ms (16:52:18.925)
Trace[1719610177]: [10.131785577s] [10.131785577s] END
E0128 16:52:18.925635       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Pod: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": EOF
W0128 16:52:54.763281       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": read tcp 127.0.0.1:40224->127.0.0.1:10550: read: connection reset by peer
I0128 16:52:54.763433       1 trace.go:205] Trace[98357229]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:52:44.731) (total time: 10032ms):
Trace[98357229]: ---"Objects listed" error:Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": read tcp 127.0.0.1:40224->127.0.0.1:10550: read: connection reset by peer 10031ms (16:52:54.763)
Trace[98357229]: [10.032083353s] [10.032083353s] END
E0128 16:52:54.763460       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1alpha3.DestinationRule: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": read tcp 127.0.0.1:40224->127.0.0.1:10550: read: connection reset by peer
W0128 16:52:55.768008       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": read tcp 127.0.0.1:40230->127.0.0.1:10550: read: connection reset by peer
I0128 16:52:55.768243       1 trace.go:205] Trace[1722378471]: "Reflector ListAndWatch" name:k8s.io/client-go/informers/factory.go:134 (28-Jan-2022 16:52:45.734) (total time: 10033ms):
Trace[1722378471]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": read tcp 127.0.0.1:40230->127.0.0.1:10550: read: connection reset by peer 10033ms (16:52:55.767)
Trace[1722378471]: [10.033374223s] [10.033374223s] END
E0128 16:52:55.768293       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Service: failed to list *v1.Service: Get "http://127.0.0.1:10550/api/v1/services?limit=500&resourceVersion=0": read tcp 127.0.0.1:40230->127.0.0.1:10550: read: connection reset by peer
W0128 16:53:07.419044       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": read tcp 127.0.0.1:40258->127.0.0.1:10550: read: connection reset by peer
I0128 16:53:07.419223       1 trace.go:205] Trace[86447993]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:52:57.365) (total time: 10054ms):
Trace[86447993]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": read tcp 127.0.0.1:40258->127.0.0.1:10550: read: connection reset by peer 10054ms (16:53:07.419)
Trace[86447993]: [10.054139341s] [10.054139341s] END
E0128 16:53:07.419257       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Endpoints: failed to list *v1.Endpoints: Get "http://127.0.0.1:10550/api/v1/endpoints?limit=500&resourceVersion=0": read tcp 127.0.0.1:40258->127.0.0.1:10550: read: connection reset by peer
W0128 16:53:22.757222       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": read tcp 127.0.0.1:40300->127.0.0.1:10550: read: connection reset by peer
I0128 16:53:22.757406       1 trace.go:205] Trace[574093224]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:53:12.705) (total time: 10051ms):
Trace[574093224]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": read tcp 127.0.0.1:40300->127.0.0.1:10550: read: connection reset by peer 10051ms (16:53:22.757)
Trace[574093224]: [10.051638605s] [10.051638605s] END
E0128 16:53:22.757435       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1.Secret: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": read tcp 127.0.0.1:40300->127.0.0.1:10550: read: connection reset by peer
W0128 16:53:27.431179       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": EOF
I0128 16:53:27.431356       1 trace.go:205] Trace[18755803]: "Reflector ListAndWatch" name:k8s.io/client-go/informers/factory.go:134 (28-Jan-2022 16:53:17.370) (total time: 10060ms):
Trace[18755803]: ---"Objects listed" error:Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": EOF 10060ms (16:53:27.431)
Trace[18755803]: [10.060780842s] [10.060780842s] END
E0128 16:53:27.431450       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Pod: failed to list *v1.Pod: Get "http://127.0.0.1:10550/api/v1/pods?limit=500&resourceVersion=0": EOF
W0128 16:53:43.750049       1 reflector.go:324] /code/common/informers/informers.go:87: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": read tcp 127.0.0.1:40342->127.0.0.1:10550: read: connection reset by peer
I0128 16:53:43.750242       1 trace.go:205] Trace[1769767418]: "Reflector ListAndWatch" name:/code/common/informers/informers.go:87 (28-Jan-2022 16:53:33.639) (total time: 10110ms):
Trace[1769767418]: ---"Objects listed" error:Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": read tcp 127.0.0.1:40342->127.0.0.1:10550: read: connection reset by peer 10110ms (16:53:43.750)
Trace[1769767418]: [10.110949595s] [10.110949595s] END
E0128 16:53:43.750285       1 reflector.go:138] /code/common/informers/informers.go:87: Failed to watch *v1alpha3.DestinationRule: failed to list *v1alpha3.DestinationRule: Get "http://127.0.0.1:10550/apis/networking.istio.io/v1alpha3/destinationrules?limit=500&resourceVersion=0": read tcp 127.0.0.1:40342->127.0.0.1:10550: read: connection reset by peer
2 个月 后
没有下文了吗? 会的人来走两步
4 个月 后
请问这个问题解决了吗?我也遇到了这个问题,log里边显示“Failed to get tunnel server addr: get edgemeshserver addr from api server err: secret “edgemeshaddrsecret” not found”,这可能是哪里的问题呢?
2 年 后
我也遇到了同样的问题,我边缘节点上的edgemesh-agent关于list *v1.Secret不断出错
 W0723 20:00:45.813754       1 reflector.go:324] k8s.io/client-go/informers/factory.go:134: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
 E0723 20:00:45.813942       1 reflector.go:138] k8s.io/client-go/informers/factory.go:134: Failed to watch *v1.Secret: failed to list *v1.Secret: Get "http://127.0.0.1:10550/api/v1/secrets?limit=500&resourceVersion=0": dial tcp 127.0.0.1:10550: connect: connection refused
