JjohnniangK零S
liangjianhao2020 你可以亲自尝试一下。
但是不能用 docker 为什么呢
因为 docker 工具是集成到 base 容器中的,官方的 Node.js 镜像是不会有 docker client,如果你想要在流水线中使用 docker 工具,请参考:
stage('Use Docker client') {
steps {
container('base') {
sh 'docker version'
sh 'docker login'
标记一下 后面试试
johnniang 换成你这个直接报错了
io.fabric8.kubernetes.client.http.WebSocketHandshakeException
at io.fabric8.kubernetes.client.okhttp.OkHttpWebSocketImpl$BuilderImpl$1.onFailure(OkHttpWebSocketImpl.java:65)
at okhttp3.internal.ws.RealWebSocket.failWebSocket(RealWebSocket.java:571)
at okhttp3.internal.ws.RealWebSocket$2.onResponse(RealWebSocket.java:198)
at okhttp3.RealCall$AsyncCall.execute(RealCall.java:203)
at okhttp3.internal.NamedRunnable.run(NamedRunnable.java:32)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:829)
Suppressed: java.lang.Throwable: waiting here
at io.fabric8.kubernetes.client.utils.Utils.waitUntilReady(Utils.java:164)
at io.fabric8.kubernetes.client.utils.Utils.waitUntilReadyOrFail(Utils.java:175)
at io.fabric8.kubernetes.client.dsl.internal.core.v1.PodOperationsImpl.exec(PodOperationsImpl.java:322)
at io.fabric8.kubernetes.client.dsl.internal.core.v1.PodOperationsImpl.exec(PodOperationsImpl.java:84)
at org.csanchez.jenkins.plugins.kubernetes.pipeline.ContainerExecDecorator$1.doLaunch(ContainerExecDecorator.java:427)
at org.csanchez.jenkins.plugins.kubernetes.pipeline.ContainerExecDecorator$1.launch(ContainerExecDecorator.java:344)
at hudson.Launcher$ProcStarter.start(Launcher.java:507)
at org.jenkinsci.plugins.durabletask.BourneShellScript.launchWithCookie(BourneShellScript.java:176)
at org.jenkinsci.plugins.durabletask.FileMonitoringTask.launch(FileMonitoringTask.java:132)
at org.jenkinsci.plugins.workflow.steps.durable_task.DurableTaskStep$Execution.start(DurableTaskStep.java:320)
at org.jenkinsci.plugins.workflow.cps.DSL.invokeStep(DSL.java:319)
at org.jenkinsci.plugins.workflow.cps.DSL.invokeMethod(DSL.java:193)
at org.jenkinsci.plugins.workflow.cps.CpsScript.invokeMethod(CpsScript.java:122)
at jdk.internal.reflect.GeneratedMethodAccessor1808.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:93)
at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:325)
at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1213)
at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1022)
at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.call(PogoMetaClassSite.java:42)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:48)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:113)
at org.kohsuke.groovy.sandbox.impl.Checker$1.call(Checker.java:163)
at org.kohsuke.groovy.sandbox.GroovyInterceptor.onMethodCall(GroovyInterceptor.java:23)
at org.jenkinsci.plugins.scriptsecurity.sandbox.groovy.SandboxInterceptor.onMethodCall(SandboxInterceptor.java:158)
at org.kohsuke.groovy.sandbox.impl.Checker$1.call(Checker.java:161)
at org.kohsuke.groovy.sandbox.impl.Checker.checkedCall(Checker.java:165)
at org.kohsuke.groovy.sandbox.impl.Checker.checkedCall(Checker.java:135)
at com.cloudbees.groovy.cps.sandbox.SandboxInvoker.methodCall(SandboxInvoker.java:17)
at com.cloudbees.groovy.cps.impl.ContinuationGroup.methodCall(ContinuationGroup.java:86)
at com.cloudbees.groovy.cps.impl.FunctionCallBlock$ContinuationImpl.dispatchOrArg(FunctionCallBlock.java:113)
at com.cloudbees.groovy.cps.impl.FunctionCallBlock$ContinuationImpl.fixArg(FunctionCallBlock.java:83)
at jdk.internal.reflect.GeneratedMethodAccessor130.invoke(Unknown Source)
at com.cloudbees.groovy.cps.impl.ContinuationPtr$ContinuationImpl.receive(ContinuationPtr.java:72)
at com.cloudbees.groovy.cps.impl.ConstantBlock.eval(ConstantBlock.java:21)
at com.cloudbees.groovy.cps.Next.step(Next.java:83)
at com.cloudbees.groovy.cps.Continuable$1.call(Continuable.java:174)
at com.cloudbees.groovy.cps.Continuable$1.call(Continuable.java:163)
at org.codehaus.groovy.runtime.GroovyCategorySupport$ThreadCategoryInfo.use(GroovyCategorySupport.java:129)
at org.codehaus.groovy.runtime.GroovyCategorySupport.use(GroovyCategorySupport.java:268)
at com.cloudbees.groovy.cps.Continuable.run0(Continuable.java:163)
at org.jenkinsci.plugins.workflow.cps.SandboxContinuable.access$001(SandboxContinuable.java:18)
at org.jenkinsci.plugins.workflow.cps.SandboxContinuable.run0(SandboxContinuable.java:51)
at org.jenkinsci.plugins.workflow.cps.CpsThread.runNextChunk(CpsThread.java:185)
at org.jenkinsci.plugins.workflow.cps.CpsThreadGroup.run(CpsThreadGroup.java:402)
at org.jenkinsci.plugins.workflow.cps.CpsThreadGroup.access$400(CpsThreadGroup.java:96)
at org.jenkinsci.plugins.workflow.cps.CpsThreadGroup$2.call(CpsThreadGroup.java:314)
at org.jenkinsci.plugins.workflow.cps.CpsThreadGroup$2.call(CpsThreadGroup.java:278)
at org.jenkinsci.plugins.workflow.cps.CpsVmExecutorService$2.call(CpsVmExecutorService.java:67)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at hudson.remoting.SingleLaneExecutorService$1.run(SingleLaneExecutorService.java:139)
at jenkins.util.ContextResettingExecutorService$1.run(ContextResettingExecutorService.java:28)
at jenkins.security.ImpersonatingExecutorService$1.run(ImpersonatingExecutorService.java:68)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
... 3 more
Caused by: java.net.ProtocolException: Expected HTTP 101 response but was '400 Bad Request'
at okhttp3.internal.ws.RealWebSocket.checkResponse(RealWebSocket.java:229)
at okhttp3.internal.ws.RealWebSocket$2.onResponse(RealWebSocket.java:196)
... 5 more
An error has occurred.
666
方便后来者,重新构建了nodejs和maven镜像
node版本v18.18.0,npm版本9.8.1;
jdk版本17
hub.docker.com/r/liyongyao/kubesphere/tags
该镜像执行 npm -v 命令会报错
node[1]: ../src/node_platform.cc:68:std::unique_ptr<long unsigned int> node::WorkerThreadsTaskRunner:elayedTaskScheduler::Start(): Assertion `(0) == (uv_thread_create(t.get(), start_thread, this))' failed.
1: 0xb87bc0 node::Abort() [node]
2: 0xb87c3e [node]
3: 0xbf50fe [node]
4: 0xbf51e1 node::NodePlatform::NodePlatform(int, v8::TracingController*, v8:ageAllocator*) [node]
5: 0xb458f3 node::InitializeOncePerProcess(std::vector<std::cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, node:rocessFlags::Flags) [node]
6: 0xb45f4b node::Start(int, char**) [node]
7: 0×7f96a0d4c590 [/lib64/libc.so.6]
8: 0×7f96a0d4c640 __libc_start_main [/lib64/libc.so.6]
9: 0xac3f4e _start [node]
