[root@k8s1 data]# ./kk create cluster -f config-sample.yaml –with-kubesphere v3.2.1
| |\ \ || | |) | __/ |\ \ __/ |_| |
\| \/\,|./ \\| \/\|\__, |
__/ |
|___/
12:32:40 CST [NodePreCheckModule] A pre-check on nodes
12:32:41 CST success: [k8s2]
12:32:41 CST success: [k8s1]
12:32:41 CST [ConfirmModule] Display confirmation form
| name | sudo | curl | openssl | ebtables | socat | ipset | conntrack | chrony | docker | nfs client | ceph client | glusterfs client | time |
| k8s1 | y | y | y | y | y | y | y | y | 20.10.9 | y | | | CST 12:32:41 |
| k8s2 | y | y | y | y | y | y | y | y | 20.10.9 | y | | | CST 12:32:41 |
Before installation, you should ensure that your machines meet all requirements specified at
https://github.com/kubesphere/kubekey#requirements-and-recommendations
Continue this installation? [yes/no]: yes
12:32:44 CST success: [LocalHost]
12:32:44 CST [NodeBinariesModule] Download installation binaries
12:32:44 CST message: [localhost]
downloading amd64 kubeadm 1.21.5 …
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 219 100 219 0 0 323 0 –:–:– –:–:– –:–:– 323
100 219 100 219 0 0 367 0 –:–:– –:–:– –:–:– 367
100 219 100 219 0 0 372 0 –:–:– –:–:– –:–:– 373
100 219 100 219 0 0 370 0 –:–:– –:–:– –:–:– 370
100 219 100 219 0 0 373 0 –:–:– –:–:– –:–:– 374
12:32:47 CST message: [LocalHost]
Failed to download kubeadm binary: curl -L -o /data/kubekey/kube/1.21.5/amd64/kubeadm https://storage.googleapis.com/kubernetes-release/release/1.21.5/bin/linux/amd64/kubeadm error: No SHA256 found for kubeadm. 1.21.5 is not supported.
12:32:47 CST failed: [LocalHost]
error: Pipeline[CreateClusterPipeline] execute failed: Module[NodeBinariesModule] exec failed:
failed: [LocalHost] [DownloadBinaries] exec failed after 1 retires: Failed to download kubeadm binary: curl -L -o /data/kubekey/kube/1.21.5/amd64/kubeadm https://storage.googleapis.com/kubernetes-release/release/1.21.5/bin/linux/amd64/kubeadm error: No SHA256 found for kubeadm. 1.21.5 is not supported.
