Client Version: version.Info{Major:“1”, Minor:“19”, GitVersion:“v1.19.8”, GitCommit:“fd5d41537aee486160ad9b5356a9d82363273721”, GitTreeState:“clean”, BuildDate:“2021-02-17T12:41:51Z”, GoVersion:“go1.15.8”, Compiler:“gc”, Platform:“linux/amd64”}
Server Version: version.Info{Major:“1”, Minor:“19”, GitVersion:“v1.19.8”, GitCommit:“fd5d41537aee486160ad9b5356a9d82363273721”, GitTreeState:“clean”, BuildDate:“2021-02-17T12:33:08Z”, GoVersion:“go1.15.8”, Compiler:“gc”, Platform:“linux/amd64”}
Version: 20.10.7
API version: 1.41
Go version: go1.13.15
Git commit: f0df350
Built: Wed Jun 2 11:58:10 2021
Experimental: true
Version: 20.10.7
Git commit: b0f5bc3
Built: Wed Jun 2 11:56:35 2021
Version: 1.4.6
GitCommit: d71fcd7d8303cbf684402823e425e9dd2e99285d
Version: 1.0.0-rc95
GitCommit: b9ee9c6314599f1b4a7f497e1f1f856fe433d3b7
Version: 0.19.0
GitCommit: de40ad0
v3.2.1
流水线:
#!groovy
该Jenkinsfile作用: 构建aosp7 docker镜像,并推送到harbor (用于后续编译安卓源码)
参考:
https://github.com/jenkinsci/kubernetes-plugin/blob/master/README_zh.md
https://www.jenkins.io/zh/blog/2018/09/14/kubernetes-and-secret-agents/
自定义podTemplate:
1\.继承ks提供的base podTemplate
2\.添加ubuntu containerTemplate
podTemplate(label: ‘myAgentPod’, inheritFrom: ‘base’, containers: [
containerTemplate(name: 'my-ubuntu', image: 'ubuntu', command: 'cat', ttyEnabled: true)
node('myAgentPod') {
stage("CheckOut") {
checkout(scm)
stage("Build") {
container('my-ubuntu') {
buildPush()
def buildPush() {
String appName = 'aosp7'
String harborProject = 'lyhtest'
String branchName = "${BRANCH_NAME}"
String imageName = getImageName(harborProject, appName, replaceBranchName(branchName))
env.IMAGE_NAME = imageName
sh "ls -al"
sh "pwd"
sh "export BRANCH_NAME=${BRANCH_NAME}"
sh "export SVN_URL=${env.SVN_URL}"
sh "export SVN_REVISION=${env.SVN_REVISION}"
sh "cd docker"
sh "ls -al"
sh "pwd"
sh "docker build "+' --build-arg BRANCH_NAME=${BRANCH_NAME} '+". -t ${imageName} "
withCredentials([usernamePassword(credentialsId: "${getHarborToken()}", passwordVariable: 'HARBOR_PASSWORD', usernameVariable: 'HARBOR_USERNAME')]) {
sh "echo ${HARBOR_PASSWORD} | docker login ${getRegistry()} -u ${HARBOR_USERNAME} --password-stdin"
sh "docker push ${imageName}"
sh "docker rmi ${imageName} -f"
def String getRegistry(){
return "${env.REGISTRY_IP}"
def String getHarborToken(){
return "我的token(脱敏)";
def String getImageName(String harborProject, String appName, String branchName){
return "${getRegistry()}/${harborProject}/${appName}:${branchName}-${BUILD_NUMBER}"
def replaceBranchName(String branchName){
return branchName.replace("/","-")
