例如:9台虚拟机,Centos7.9,8C/16G
Client Version: version.Info{Major:“1”, Minor:“22”, GitVersion:“v1.22.1”, GitCommit:“632ed300f2c34f6d6d15ca4cef3d3c7073412212”, GitTreeState:“clean”, BuildDate:“2021-08-19T15:45:37Z”, GoVersion:“go1.16.7”, Compiler:“gc”, Platform:“linux/amd64”}
Server Version: version.Info{Major:“1”, Minor:“22”, GitVersion:“v1.22.1”, GitCommit:“632ed300f2c34f6d6d15ca4cef3d3c7073412212”, GitTreeState:“clean”, BuildDate:“2021-08-19T15:39:34Z”, GoVersion:“go1.16.7”, Compiler:“gc”, Platform:“linux/amd64”}
RuntimeVersion: v1.4.9
RuntimeApiVersion: v1alpha2
例如:v3.2.1。在线安装。用kk安装。
使用KubeKey升级 Kubermetes 到1.23.7 无法安装
[root@master1 ~]# ./kk upgrade –with-kubernetes v1.23.7 -f config-sample.yaml
10:53:13 CST [GreetingsModule] Greetings
10:53:13 CST message: [node6]
Greetings, KubeKey!
10:53:13 CST message: [node1]
Greetings, KubeKey!
10:53:13 CST message: [master1]
Greetings, KubeKey!
10:53:13 CST message: [master2]
Greetings, KubeKey!
10:53:13 CST message: [master3]
Greetings, KubeKey!
10:53:13 CST message: [node3]
Greetings, KubeKey!
10:53:14 CST message: [node2]
Greetings, KubeKey!
10:53:14 CST message: [node4]
Greetings, KubeKey!
10:53:14 CST message: [node5]
Greetings, KubeKey!
10:53:14 CST success: [node6]
10:53:14 CST success: [node1]
10:53:14 CST success: [master1]
10:53:14 CST success: [master2]
10:53:14 CST success: [master3]
10:53:14 CST success: [node3]
10:53:14 CST success: [node2]
10:53:14 CST success: [node4]
10:53:14 CST success: [node5]
10:53:14 CST [NodePreCheckModule] A pre-check on nodes
10:53:15 CST success: [node1]
10:53:15 CST success: [master3]
10:53:15 CST success: [node6]
10:53:15 CST success: [node5]
10:53:15 CST success: [master2]
10:53:15 CST success: [master1]
10:53:15 CST success: [node2]
10:53:15 CST success: [node4]
10:53:15 CST success: [node3]
10:53:15 CST [ClusterPreCheckModule] Get KubeConfig file
10:53:15 CST skipped: [master3]
10:53:15 CST skipped: [master2]
10:53:15 CST [ClusterPreCheckModule] Get all nodes Kubernetes version
10:53:15 CST [ClusterPreCheckModule] Calculate min Kubernetes version
10:53:15 CST [ClusterPreCheckModule] Check desired Kubernetes version
10:53:15 CST [ClusterPreCheckModule] Check KubeSphere version
10:53:16 CST skipped: [master3]
10:53:16 CST skipped: [master2]
10:53:16 CST success: [master1]
10:53:16 CST [ClusterPreCheckModule] Check dependency matrix for KubeSphere and Kubernetes
10:53:16 CST message: [master1]
Unsupported upgrade plan: v3.2.1 to v3.2.1
10:53:16 CST retry: [master1]
10:53:21 CST message: [master1]
10:53:21 CST retry: [master1]
10:53:26 CST message: [master1]
10:53:26 CST skipped: [master3]
10:53:26 CST skipped: [master2]
10:53:26 CST failed: [master1]
error: Pipeline[UpgradeClusterPipeline] execute failed: Module[ClusterPreCheckModule] exec failed:
failed: [master1] [DependencyCheck] exec failed after 3 retires: Unsupported upgrade plan: v3.2.1 to v3.2.1
