主集群版本 v3.2.1
member集群版本 v3.2.1
runtime:containerd
Fluent Bit v1.8.3 日志如下
[2022/06/10 09:52:51] [ info] [engine] started (pid=61)
[2022/06/10 09:52:51] [ info] [storage] version=1.1.1, initializing...
[2022/06/10 09:52:51] [ info] [storage] in-memory
[2022/06/10 09:52:51] [ info] [storage] normal synchronization mode, checksum disabled, max_chunks_up=128
[2022/06/10 09:52:51] [ info] [cmetrics] version=0.1.6
[2022/06/10 09:52:51] [ info] [input:systemd:systemd.0] seek_cursor=s=66d13f2233484a49a3b310b705691122;i=1e5... OK
[2022/06/10 09:52:51] [ info] [input:systemd:systemd.1] seek_cursor=s=66d13f2233484a49a3b310b705691122;i=225... OK
[2022/06/10 09:52:51] [ info] [filter:kubernetes:kubernetes.1] https=1 host=kubernetes.default.svc port=443
[2022/06/10 09:52:51] [ info] [filter:kubernetes:kubernetes.1] local POD info OK
[2022/06/10 09:52:51] [ info] [filter:kubernetes:kubernetes.1] testing connectivity with API server...
[2022/06/10 09:52:51] [ info] [filter:kubernetes:kubernetes.1] connectivity OK
[2022/06/10 09:52:51] [ info] [sp] stream processor started
level=error msg="Fluent bit exited" error="signal: killed"
level=info msg=backoff delay=5m0s
level=info msg="backoff timer done" actual=5m0.000094737s expected=5m0s
level=info msg="Fluent bit started"
[1mFluent Bit v1.8.3[0m
* [1m[93mCopyright (C) 2019-2021 The Fluent Bit Authors[0m
* [1m[93mCopyright (C) 2015-2018 Treasure Data[0m
* Fluent Bit is a CNCF sub-project under the umbrella of Fluentd
* https://fluentbit.io
[2022/06/10 09:57:56] [ info] [engine] started (pid=64)
[2022/06/10 09:57:56] [ info] [storage] version=1.1.1, initializing...
[2022/06/10 09:57:56] [ info] [storage] in-memory
[2022/06/10 09:57:56] [ info] [storage] normal synchronization mode, checksum disabled, max_chunks_up=128
[2022/06/10 09:57:56] [ info] [cmetrics] version=0.1.6
[2022/06/10 09:57:56] [ info] [input:systemd:systemd.0] seek_cursor=s=66d13f2233484a49a3b310b705691122;i=216... OK
[2022/06/10 09:57:56] [ info] [input:systemd:systemd.1] seek_cursor=s=66d13f2233484a49a3b310b705691122;i=225... OK
[2022/06/10 09:57:56] [ info] [filter:kubernetes:kubernetes.1] https=1 host=kubernetes.default.svc port=443
[2022/06/10 09:57:56] [ info] [filter:kubernetes:kubernetes.1] local POD info OK
[2022/06/10 09:57:56] [ info] [filter:kubernetes:kubernetes.1] testing connectivity with API server...
[2022/06/10 09:57:56] [ info] [filter:kubernetes:kubernetes.1] connectivity OK
[2022/06/10 09:57:56] [ info] [sp] stream processor started
[2022/06/10 09:58:07] [ warn] [http_client] cannot increase buffer: current=512000 requested=544768 max=512000
[2022/06/10 09:58:08] [ warn] [http_client] cannot increase buffer: current=512000 requested=544768 max=512000
[2022/06/10 11:12:41] [ warn] [engine] failed to flush chunk '64-1654859557.494881885.flb', retry in 11 seconds: task_id=1, input=systemd.1 > output=es.0 (out_id=0)
[2022/06/10 11:52:41] [ warn] [engine] failed to flush chunk '64-1654861957.498122714.flb', retry in 7 seconds: task_id=1, input=systemd.1 > output=es.0 (out_id=0)
[2022/06/10 17:12:36] [ warn] [engine] failed to flush chunk '64-1654881151.760230362.flb', retry in 6 seconds: task_id=1, input=systemd.1 > output=es.0 (out_id=0)
[2022/06/10 17:32:41] [ warn] [engine] failed to flush chunk '64-1654882357.258750322.flb', retry in 10 seconds: task_id=1, input=systemd.1 > output=es.0 (out_id=0)
[2022/06/10 18:12:36] [ warn] [engine] failed to flush chunk '64-1654884751.757711333.flb', retry in 10 seconds: task_id=1, input=systemd.1 > output=es.0 (out_id=0)
[2022/06/20 05:52:41] [ warn] [engine] failed to flush chunk '64-1655704357.599898439.flb', retry in 11 seconds: task_id=1, input=systemd.1 > output=es.0 (out_id=0)
[2022/06/20 07:52:41] [ warn] [engine] failed to flush chunk '64-1655711558.6775275.flb', retry in 7 seconds: task_id=1, input=systemd.1 > output=es.0 (out_id=0)
