# uname -a
Linux master01 5.4.196-1.el7.elrepo.x86_64 #1 SMP Tue May 24 12:49:20 EDT 2022 x86_64 x86_64 x86_64 GNU/Linux
Client Version: version.Info{Major:"1", Minor:"24", GitVersion:"v1.24.1", GitCommit:"3ddd0f45aa91e2f30c70734b175631bec5b5825a", GitTreeState:"clean", BuildDate:"2022-05-24T12:26:19Z", GoVersion:"go1.18.2", Compiler:"gc", Platform:"linux/amd64"}
Kustomize Version: v4.5.4
Server Version: version.Info{Major:"1", Minor:"24", GitVersion:"v1.24.1", GitCommit:"3ddd0f45aa91e2f30c70734b175631bec5b5825a", GitTreeState:"clean", BuildDate:"2022-05-24T12:18:48Z", GoVersion:"go1.18.2", Compiler:"gc", Platform:"linux/amd64"}
RuntimeVersion: 1.6.6
v3.3.0 在已有 K8S 上启用 DevOps 失败, Task 'devops' failded
已有 K8S 上启用 DevOps 失败, Task ‘devops’ failded;
另: 每次 "在自定义资源中,点击 ks-installer ,选择编辑 YAML "后, 都会丢失 `accessTokenMaxAge`
Start installing monitoring
Start installing multicluster
Start installing openpitrix
Start installing network
Start installing alerting
Start installing devops
Waiting for all tasks to be completed ...
task alerting status is successful (1/6)
task network status is successful (2/6)
task openpitrix status is successful (3/6)
task multicluster status is successful (4/6)
task devops status is failed (5/6)
task monitoring status is successful (6/6)
Collecting installation results ...
Task 'devops' failed:
"counter": 145,
"created": "2022-06-29T08:29:07.729440",
"end_line": 174,
"event": "runner_on_failed",
"event_data": {
"duration": 1.890352,
"end": "2022-06-29T08:29:07.729295",
"event_loop": null,
"host": "localhost",
"ignore_errors": null,
"play": "localhost",
"play_pattern": "localhost",
"play_uuid": "e289f9d3-f574-8b86-920a-000000000005",
"playbook": "/kubesphere/playbooks/devops.yaml",
"playbook_uuid": "45494960-b6df-4d63-914d-72d1a5d8f349",
"remote_addr": "127.0.0.1",
"res": {
"changed": true,
"msg": "All items completed",
"results": [
"_ansible_item_label": "kubesphere-devops-worker",
"_ansible_no_log": false,
"ansible_loop_var": "item",
"changed": true,
"cmd": "/usr/local/bin/kubectl label --overwrite namespaces kubesphere-devops-worker kubesphere.io/workspace=system-workspace\n",
"delta": "0:00:00.308306",
"end": "2022-06-29 16:29:07.546699",
"failed": true,
"invocation": {
"module_args": {
"_raw_params": "/usr/local/bin/kubectl label --overwrite namespaces kubesphere-devops-worker kubesphere.io/workspace=system-workspace\n",
"_uses_shell": true,
"argv": null,
"chdir": null,
"creates": null,
"executable": null,
"removes": null,
"stdin": null,
"stdin_add_newline": true,
"strip_empty_ends": true,
"warn": true
"item": "kubesphere-devops-worker",
"rc": 1,
"start": "2022-06-29 16:29:07.238393",
"stderr": "Error from server (NotFound): namespaces \"kubesphere-devops-worker\" not found",
"stderr_lines": [
"stdout": "",
"stdout_lines": []
"resolved_action": "shell",
"role": "ks-devops",
"start": "2022-06-29T08:29:05.838943",
"task": "ks-devops | Labelling devops namespaces as system workspace",
"task_action": "shell",
"task_args": "",
"task_path": "/kubesphere/installer/roles/ks-devops/tasks/main.yaml:232",
"task_uuid": "e289f9d3-f574-8b86-920a-000000000043",
"uuid": "43c00ef3-12d3-4309-a105-f5ecd0ba0571"
"parent_uuid": "e289f9d3-f574-8b86-920a-000000000043",
"pid": 18015,
"runner_ident": "devops",
"start_line": 174,
"stdout": "",
操作是按照 `https://kubesphere.io/zh/docs/v3.3/pluggable-components/devops/#%E5%9C%A8%E5%AE%89%E8%A3%85%E5%90%8E%E5%90%AF%E7%94%A8-devops\`执行.
当前相关 ns
# kubectl get ns
NAME STATUS AGE
argocd Active 81m
demo-project Active 99m
kubernetes-dashboard Active 19d
kubesphere-controls-system Active 28h
kubesphere-devops-system Active 86m
kubesphere-monitoring-federated Active 28h
kubesphere-monitoring-system Active 28h
kubesphere-system Active 29h
project-test Active 3h13m
万分感谢解答!
