• 安装部署
  • 使用KK命令安装kubesphere v3.3.0报错kubelet.go:2451] node not found"
在安装到 “[InitKubernetesModule] Init cluster using kubeadm” 过不去了,貌似kubelet不能初始化。
systemctl status kubelet
● kubelet.service - kubelet: The Kubernetes Node Agent
Loaded: loaded (/etc/systemd/system/kubelet.service; enabled; vendor preset: disabled)
Drop-In: /etc/systemd/system/kubelet.service.d
       └─10-kubeadm.conf
Active: active (running) since Sun 2022-07-03 09:31:01 CST; 2min 18s ago
 Docs: http://kubernetes.io/docs/
Main PID: 8082 (kubelet)
Tasks: 12
Memory: 35.2M
CGroup: /system.slice/kubelet.service
       └─8082 /usr/local/bin/kubelet --bootstrap-kubeconfig=/etc/kubernetes/bootstrap-kubelet.conf --kubeconfig=/etc/kubernetes/kubelet.conf --config=/var/lib/kubelet/config.yaml --cgroup-driver=systemd --network-pl...
Jul 03 09:33:18 master1 kubelet[8082]: E0703 09:33:18.647153 8082 kubelet.go:2451] “Error getting node” err="node \“master1\” not found"
Jul 03 09:33:18 master1 kubelet[8082]: E0703 09:33:18.747274 8082 kubelet.go:2451] “Error getting node” err="node \“master1\” not found"
Jul 03 09:33:18 master1 kubelet[8082]: E0703 09:33:18.847356 8082 kubelet.go:2451] “Error getting node” err="node \“master1\” not found"
Jul 03 09:33:18 master1 kubelet[8082]: E0703 09:33:18.947447 8082 kubelet.go:2451] “Error getting node” err="node \“master1\” not found"
Jul 03 09:33:19 master1 kubelet[8082]: E0703 09:33:19.047541 8082 kubelet.go:2451] “Error getting node” err="node \“master1\” not found"
Jul 03 09:33:19 master1 kubelet[8082]: E0703 09:33:19.147603 8082 kubelet.go:2451] “Error getting node” err="node \“master1\” not found"
Jul 03 09:33:19 master1 kubelet[8082]: E0703 09:33:19.247731 8082 kubelet.go:2451] “Error getting node” err="node \“master1\” not found"
Jul 03 09:33:19 master1 kubelet[8082]: E0703 09:33:19.347798 8082 kubelet.go:2451] “Error getting node” err="node \“master1\” not found"
Jul 03 09:33:19 master1 kubelet[8082]: E0703 09:33:19.447884 8082 kubelet.go:2451] “Error getting node” err="node \“master1\” not found"
Jul 03 09:33:19 master1 kubelet[8082]: E0703 09:33:19.547965 8082 kubelet.go:2451] “Error getting node” err="node \“master1\” not found"
config_sample.yaml 用的是docker
kubernetes:
version: v1.22.10
clusterName: cluster.local
autoRenewCerts: true
containerManager: docker
LB的vip可以ping通,haproxy/keepalived已经装完。
麻烦大神们看看,谢谢,已经彻底删除后装了几遍。
[wait-control-plane] Waiting for the kubelet to boot up the control plane as static Pods from directory “/etc/kubernetes/manifests”. This can take up to 4m0s
    Unfortunately, an error has occurred:
            timed out waiting for the condition
    This error is likely caused by:
            - The kubelet is not running
            - The kubelet is unhealthy due to a misconfiguration of the node in some way (required cgroups disabled)
    If you are on a systemd-powered system, you can try to troubleshoot the error with the following commands:
            - 'systemctl status kubelet'
            - 'journalctl -xeu kubelet'
    Additionally, a control plane component may have crashed or exited when started by the container runtime.
    To troubleshoot, list all containers using your preferred container runtimes CLI.
    Here is one example how you may list all Kubernetes containers running in docker:
            - 'docker ps -a | grep kube | grep -v pause'
            Once you have found the failing container, you can inspect its logs with:
            - 'docker logs CONTAINERID'
error execution phase wait-control-plane: couldn’t initialize a Kubernetes cluster
To see the stack trace of this error execute with –v=5 or higher: Process exited with status 1
12:23:28 CST retry: [master1]
    2 年 后
