"counter": 80,
"created": "2022-07-04T06:45:32.675011",
"end_line": 77,
"event": "runner_on_failed",
"event_data": {
"duration": 66.596422,
"end": "2022-07-04T06:45:32.674895",
"event_loop": null,
"host": "localhost",
"ignore_errors": null,
"play": "localhost",
"play_pattern": "localhost",
"play_uuid": "de5a14e8-4ba8-688b-0288-000000000005",
"playbook": "/kubesphere/playbooks/monitoring.yaml",
"playbook_uuid": "a458c0b3-75e3-4a12-a5ee-49e57492baab",
"remote_addr": "127.0.0.1",
"res": {
"changed": true,
"msg": "All items completed",
"results": [
"_ansible_item_label": "/kubesphere/kubesphere/prometheus/prometheus-operator/prometheus-operator-0alertmanagerConfigCustomResourceDefinition.yaml",
"_ansible_no_log": false,
"ansible_loop_var": "item",
"attempts": 1,
"changed": true,
"cmd": "/usr/local/bin/kubectl apply -f /kubesphere/kubesphere/prometheus/prometheus-operator/prometheus-operator-0alertmanagerConfigCustomResourceDefinition.yaml --force || /usr/local/bin/kubectl apply -f /kubesphere/kubesphere/prometheus/prometheus-operator/prometheus-operator-0alertmanagerConfigCustomResourceDefinition.yaml --force-conflicts --server-side",
"delta": "0:00:01.400373",
"end": "2022-07-04 14:44:28.274389",
"failed": false,
"failed_when_result": false,
"invocation": {
"module_args": {
"_raw_params": "/usr/local/bin/kubectl apply -f /kubesphere/kubesphere/prometheus/prometheus-operator/prometheus-operator-0alertmanagerConfigCustomResourceDefinition.yaml --force || /usr/local/bin/kubectl apply -f /kubesphere/kubesphere/prometheus/prometheus-operator/prometheus-operator-0alertmanagerConfigCustomResourceDefinition.yaml --force-conflicts --server-side",
"_uses_shell": true,
"argv": null,
"chdir": null,
"creates": null,
"executable": null,
"removes": null,
"stdin": null,
"stdin_add_newline": true,
"strip_empty_ends": true,
"warn": true
"item": "/kubesphere/kubesphere/prometheus/prometheus-operator/prometheus-operator-0alertmanagerConfigCustomResourceDefinition.yaml",
"rc": 0,
"start": "2022-07-04 14:44:26.874016",
"stderr": "",
"stderr_lines": [],
"stdout": "customresourcedefinition.apiextensions.k8s.io/alertmanagerconfigs.monitoring.coreos.com configured",
"stdout_lines": [
