操作系统是Centos7.9
Kubernetes版本: v1.23.7 多节点。
KubeSphere版本: v3.3.0
问题是什么:
使用kk多节点在线安装出现错误 [RestartETCD] exec failed after 3 retires: start etcd failed: Failed to exec command: sudo -E /bin/bash -c “systemctl daemon-reload && systemctl restart etcd && systemctl enable etcd” Job for etcd.service failed because a timeout was exceeded. See “systemctl status etcd.service” and “journalctl -xe” for details.: Process exited with status 1
安装日志如下
[root@VM-8-6-centos kk]# ./kk create cluster -f config-
sample.yaml
_ __ _ _ __
| |\ \ |_| | |_) | __/ |\ \ __/ |_| |
\_| \_/\__,_|_.__/ \___\_| \_/\___|\__, |
__/ |
|___/
22:31:39 CST [GreetingsModule] Greetings
yes
22:31:43 CST message: [node3]
Greetings, KubeKey!
22:31:46 CST message: [plane]
Greetings, KubeKey!
22:31:50 CST message: [node1]
Greetings, KubeKey!
22:31:54 CST message: [node2]
Greetings, KubeKey!
22:31:54 CST success: [node3]
22:31:54 CST success: [plane]
22:31:54 CST success: [node1]
22:31:54 CST success: [node2]
22:31:54 CST [NodePreCheckModule] A pre-check on nodes
22:32:10 CST success: [plane]
22:32:10 CST success: [node2]
22:32:10 CST success: [node3]
22:32:10 CST success: [node1]
22:32:10 CST [ConfirmModule] Display confirmation form
| name | sudo | curl | openssl | ebtables | socat |
ipset | ipvsadm | conntrack | chrony | docker | contain
erd | nfs client | ceph client | glusterfs client | tim
e |
| plane | y | y | y | y | y |
y | | y | y | |
| | | | EDT
10:32:06 |
| node1 | y | y | y | y | y |
y | | y | y | |
| | | | EDT
10:32:10 |
| node2 | y | y | y | y | y |
y | | y | y | |
| | | | EDT
10:32:09 |
| node3 | y | y | y | y | y |
y | | y | y | |
| | | | EDT
10:32:10 |
Before installation, ensure that your machines meet all
requirements specified at
https://github.com/kubesphere/kubekey#requirements-and-
recommendations
Continue this installation? [yes/no]: 22:32:10 CST succ
ess: [LocalHost]
22:32:10 CST [NodeBinariesModule] Download installation
binaries
22:32:10 CST message: [localhost]
downloading amd64 kubeadm v1.23.7 ...
kubeadm is existed
downloading amd64 kubelet v1.23.7 ...
22:32:11 CST message: [localhost]
kubelet is existed
downloading amd64 kubectl v1.23.7 ...
22:32:12 CST message: [localhost]
kubectl is existed
downloading amd64 helm v3.6.3 ...
helm is existed
downloading amd64 kubecni v0.9.1 ...
kubecni is existed
downloading amd64 crictl v1.24.0 ...
crictl is existed
downloading amd64 etcd v3.4.13 ...
etcd is existed
downloading amd64 docker 20.10.8 ...
22:32:13 CST message: [localhost]
docker is existed
22:32:13 CST success: [LocalHost]
22:32:13 CST [ConfigureOSModule] Prepare to init OS
22:32:34 CST success: [plane]
22:32:34 CST success: [node2]
22:32:34 CST success: [node1]
22:32:34 CST success: [node3]
22:32:34 CST [ConfigureOSModule] Generate init os scrip
t
22:32:41 CST success: [plane]
22:32:41 CST success: [node3]
22:32:41 CST success: [node1]
22:32:41 CST success: [node2]
22:32:41 CST [ConfigureOSModule] Exec init os script
22:32:43 CST stdout: [node2]
Permissive
net.ipv4.ip_forward = 1
net.bridge.bridge-nf-call-arptables = 1
net.bridge.bridge-nf-call-ip6tables = 1
net.bridge.bridge-nf-call-iptables = 1
net.ipv4.ip_local_reserved_ports = 30000-32767
vm.max_map_count = 262144
vm.swappiness = 1
fs.inotify.max_user_instances = 524288
kernel.pid_max = 65535
22:32:43 CST stdout: [node1]
Permissive
vm.swappiness = 1
22:32:44 CST stdout: [node3]
Permissive
vm.swappiness = 1
22:32:48 CST stdout: [plane]
Permissive
vm.swappiness = 1
22:32:48 CST success: [node2]
22:32:48 CST success: [node1]
22:32:48 CST success: [node3]
22:32:48 CST success: [plane]
22:32:48 CST [ConfigureOSModule] configure the ntp serv
er for each node
22:32:48 CST skipped: [node3]
22:32:48 CST skipped: [plane]
22:32:48 CST skipped: [node1]
22:32:48 CST skipped: [node2]
22:32:48 CST [KubernetesStatusModule] Get kubernetes cl
uster status
22:32:50 CST success: [plane]
22:32:50 CST [InstallContainerModule] Sync docker binar
ies
22:53:47 CST success: [plane]
22:53:47 CST success: [node2]
22:53:47 CST success: [node3]
22:53:47 CST success: [node1]
22:53:47 CST [InstallContainerModule] Generate docker s
ervice
22:53:55 CST success: [plane]
22:53:55 CST success: [node2]
22:53:55 CST success: [node3]
22:53:55 CST success: [node1]
22:53:55 CST [InstallContainerModule] Generate docker c
onfig
22:54:03 CST success: [plane]
22:54:03 CST success: [node2]
22:54:03 CST success: [node1]
22:54:03 CST success: [node3]
22:54:03 CST [InstallContainerModule] Enable docker
22:54:08 CST success: [node2]
22:54:08 CST success: [node1]
22:54:08 CST success: [node3]
22:54:08 CST success: [plane]
22:54:08 CST [InstallContainerModule] Add auths to cont
ainer runtime
22:54:09 CST skipped: [plane]
22:54:09 CST skipped: [node2]
22:54:09 CST skipped: [node3]
22:54:09 CST skipped: [node1]
22:54:09 CST [PullModule] Start to pull images on all n
odes
22:54:09 CST message: [node3]
downloading image: kubesphere/pause:3.6
22:54:09 CST message: [plane]
22:54:09 CST message: [node1]
22:54:09 CST message: [node2]
22:54:11 CST message: [plane]
downloading image: kubesphere/kube-apiserver:v1.23.7
22:54:15 CST message: [node2]
downloading image: kubesphere/kube-proxy:v1.23.7
22:54:15 CST message: [node3]
22:54:15 CST message: [node1]
22:54:17 CST message: [plane]
downloading image: kubesphere/kube-controller-manager:v
1.23.7
22:54:23 CST message: [plane]
downloading image: kubesphere/kube-scheduler:v1.23.7
22:54:27 CST message: [plane]
22:54:34 CST message: [plane]
downloading image: coredns/coredns:1.8.6
22:54:35 CST message: [node1]
22:54:37 CST message: [node2]
22:54:37 CST message: [node3]
22:54:38 CST message: [plane]
downloading image: kubesphere/k8s-dns-node-cache:1.15.1
2
22:54:44 CST message: [node1]
2
22:54:45 CST message: [plane]
downloading image: calico/kube-controllers:v3.20.0
22:54:46 CST message: [node2]
2
22:54:49 CST message: [node3]
2
22:54:51 CST message: [plane]
downloading image: calico/cni:v3.20.0
22:55:01 CST message: [plane]
downloading image: calico/node:v3.20.0
22:55:05 CST message: [node2]
22:55:08 CST message: [node1]
22:55:11 CST message: [node3]
22:55:12 CST message: [plane]
downloading image: calico/pod2daemon-flexvol:v3.20.0
22:55:19 CST message: [node2]
22:55:22 CST message: [node1]
22:55:26 CST message: [node3]
22:55:42 CST message: [node2]
22:55:46 CST message: [node1]
22:55:51 CST message: [node3]
22:56:09 CST message: [node2]
22:56:15 CST message: [node1]
22:56:23 CST message: [node3]
22:56:31 CST success: [plane]
22:56:31 CST success: [node2]
22:56:31 CST success: [node1]
22:56:31 CST success: [node3]
22:56:31 CST [ETCDPreCheckModule] Get etcd status
22:56:34 CST success: [node1]
22:56:34 CST success: [node2]
22:56:34 CST success: [node3]
22:56:34 CST [CertsModule] Fetch etcd certs
22:56:34 CST skipped: [node2]
22:56:34 CST skipped: [node3]
22:56:34 CST [CertsModule] Generate etcd Certs
[certs] Using existing ca certificate authority
[certs] Using existing node-plane certificate and key
on disk
[certs] Using existing admin-node1 certificate and ke
y on disk
[certs] Using existing member-node1 certificate and k
ey on disk
[certs] Using existing admin-node2 certificate and ke
y on disk
[certs] Using existing member-node2 certificate and k
ey on disk
[certs] Using existing admin-node3 certificate and ke
y on disk
[certs] Using existing member-node3 certificate and k
ey on disk
22:56:34 CST success: [LocalHost]
22:56:34 CST [CertsModule] Synchronize certs file
22:58:29 CST success: [node2]
22:58:29 CST success: [node3]
22:58:29 CST success: [node1]
22:58:29 CST [CertsModule] Synchronize certs file to ma
ster
22:59:50 CST success: [plane]
22:59:50 CST [InstallETCDBinaryModule] Install etcd usi
ng binary
23:05:50 CST success: [node2]
23:05:50 CST success: [node1]
23:05:50 CST success: [node3]
23:05:50 CST [InstallETCDBinaryModule] Generate etcd se
rvice
23:05:57 CST success: [node2]
23:05:57 CST success: [node3]
23:05:57 CST success: [node1]
23:05:57 CST [InstallETCDBinaryModule] Generate access
address
23:05:57 CST skipped: [node3]
23:05:57 CST skipped: [node2]
23:05:57 CST [ETCDConfigureModule] Health check on exis
t etcd
23:05:57 CST skipped: [node1]
23:05:57 CST [ETCDConfigureModule] Generate etcd.env co
nfig on new etcd
23:06:18 CST success: [node1]
23:06:18 CST success: [node2]
23:06:18 CST success: [node3]
23:06:18 CST [ETCDConfigureModule] Refresh etcd.env con
fig on all etcd
23:06:39 CST success: [node1]
23:06:39 CST success: [node2]
23:06:39 CST success: [node3]
23:06:39 CST [ETCDConfigureModule] Restart etcd
23:08:10 CST stdout: [node2]
ded. See "systemctl status etcd.service" and "journalct
l -xe" for details.
23:08:10 CST message: [node2]
/bash -c "systemctl daemon-reload && systemctl restart
etcd && systemctl enable etcd"
l -xe" for details.: Process exited with status 1
23:08:10 CST retry: [node2]
23:08:10 CST stdout: [node1]
l -xe" for details.
23:08:10 CST message: [node1]
23:08:10 CST retry: [node1]
23:08:11 CST stdout: [node3]
l -xe" for details.
23:08:11 CST message: [node3]
23:08:11 CST retry: [node3]
23:09:47 CST stdout: [node2]
l -xe" for details.
23:09:47 CST message: [node2]
23:09:47 CST retry: [node2]
23:09:47 CST stdout: [node1]
l -xe" for details.
23:09:47 CST message: [node1]
23:09:47 CST retry: [node1]
23:09:47 CST stdout: [node3]
l -xe" for details.
23:09:47 CST message: [node3]
23:09:47 CST retry: [node3]
23:11:23 CST stdout: [node2]
l -xe" for details.
23:11:23 CST message: [node2]
23:11:23 CST stdout: [node1]
l -xe" for details.
23:11:23 CST message: [node1]
23:11:23 CST stdout: [node3]
l -xe" for details.
23:11:23 CST message: [node3]
23:11:23 CST failed: [node2]
23:11:23 CST failed: [node1]
23:11:23 CST failed: [node3]
error: Pipeline[CreateClusterPipeline] execute failed:
Module[ETCDConfigureModule] exec failed:
failed: [node2] [RestartETCD] exec failed after 3 ret
E /bin/bash -c "systemctl daemon-reload && systemctl re
start etcd && systemctl enable etcd"
Job for etcd.service failed because a timeout was exceeded. See "systemctl status etcd.service" and "journalctl -xe" for details.: Process exited with status 1
error: Pipeline[CreateClusterPipeline] execute failed: Module[ETCDConfigureModule] exec failed:
failed: [node2] [RestartETCD] exec failed after 3 retires: start etcd failed: Failed to exec command: sudo -E /bin/bash -c "systemctl daemon-reload && systemctl restart etcd && systemctl enable etcd"
failed: [node1] [RestartETCD] exec failed after 3 retires: start etcd failed: Failed to exec command: sudo -E /bin/bash -c "systemctl daemon-reload && systemctl restart etcd && systemctl enable etcd"
failed: [node3] [RestartETCD] exec failed after 3 retires: start etcd failed: Failed to exec command: sudo -E /bin/bash -c "systemctl daemon-reload && systemctl restart etcd && systemctl enable etcd"
node1-3是etcd节点 执行journalctl -xe 显示内容如下
etcd[40808]: rejected connection from "100.118.47.12:38784"
etcd[40808]: rejected connection from "100.118.6.168:34562"
etcd[40808]: rejected connection from "100.118.6.168:34570"
etcd[40808]: rejected connection from "100.118.6.168:34574"
etcd[40808]: rejected connection from "100.118.47.12:38800"
etcd[40808]: rejected connection from "100.118.47.12:38802"
etcd[40808]: rejected connection from "100.118.6.168:34582"
节点之间的网络是通的
