华为云虚拟机
LSB Version: :core-4.1-amd64:core-4.1-noarch
Distributor ID: CentOS
Description: CentOS Linux release 7.9.2009 (Core)
Release: 7.9.2009
Codename: Core
8C/16G
v1.22.10
将 docker version
/ crictl version
/ nerdctl version
结果贴在下方
v3.3.1。在线安装。使用kk安装。
是从v3.3.0 升级到v3.3.1
在v3.3.0时候
stage('部署') {
agent none
steps {
container('maven') {
withCredentials([kubeconfigFile(credentialsId : 'back-end-config' ,variable : 'KUBECONFIG' )]) {
sh '''envsubst < deploy/test/devops-sample-svc.yaml | kubectl apply -f -
envsubst < deploy/test/devops-sample.yaml | kubectl apply -f -'''
是能够正常部署的
在v3.3.1
会报错
Starting Kubernetes deployment
ERROR: ERROR: java.lang.IllegalStateException: No matching configuration files found for test/devops-sample.yaml
hudson.remoting.ProxyException: java.lang.IllegalStateException: No matching configuration files found for test/devops-sample.yaml
at com.microsoft.jenkins.kubernetes.command.DeploymentCommand$DeploymentTask.doCall(DeploymentCommand.java:152)
at com.microsoft.jenkins.kubernetes.command.DeploymentCommand$DeploymentTask.call(DeploymentCommand.java:124)
at com.microsoft.jenkins.kubernetes.command.DeploymentCommand$DeploymentTask.call(DeploymentCommand.java:106)
at hudson.remoting.UserRequest.perform(UserRequest.java:211)
at hudson.remoting.UserRequest.perform(UserRequest.java:54)
at hudson.remoting.Request$2.run(Request.java:376)
at hudson.remoting.InterceptingExecutorService.lambda$wrap$0(InterceptingExecutorService.java:78)
at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at hudson.remoting.Engine$1.lambda$newThread$0(Engine.java:122)
at java.base/java.lang.Thread.run(Unknown Source)
Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to JNLP4-connect connection from 10.233.90.249/10.233.90.249:38596
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1797)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:356)
at hudson.remoting.Channel.call(Channel.java:1001)
at hudson.FilePath.act(FilePath.java:1256)
at com.microsoft.jenkins.kubernetes.command.DeploymentCommand.execute(DeploymentCommand.java:68)
at com.microsoft.jenkins.kubernetes.command.DeploymentCommand.execute(DeploymentCommand.java:45)
at com.microsoft.jenkins.azurecommons.command.CommandService.runCommand(CommandService.java:88)
at com.microsoft.jenkins.azurecommons.command.CommandService.execute(CommandService.java:96)
at com.microsoft.jenkins.azurecommons.command.CommandService.executeCommands(CommandService.java:75)
at com.microsoft.jenkins.azurecommons.command.BaseCommandContext.executeCommands(BaseCommandContext.java:77)
at com.microsoft.jenkins.kubernetes.KubernetesDeploy.perform(KubernetesDeploy.java:42)
at com.microsoft.jenkins.azurecommons.command.SimpleBuildStepExecution.run(SimpleBuildStepExecution.java:54)
at com.microsoft.jenkins.azurecommons.command.SimpleBuildStepExecution.run(SimpleBuildStepExecution.java:35)
at org.jenkinsci.plugins.workflow.steps.SynchronousNonBlockingStepExecution.lambda$start$0(SynchronousNonBlockingStepExecution.java:47)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:829)
Kubernetes deployment ended with HasError
若那svc和deploy 分开部署也会报错
ERROR: ERROR: java.lang.RuntimeException: io.kubernetes.client.openapi.ApiException:
hudson.remoting.ProxyException: java.lang.RuntimeException: io.kubernetes.client.openapi.ApiException:
at com.microsoft.jenkins.kubernetes.wrapper.ResourceManager.handleApiExceptionExceptNotFound(ResourceManager.java:180)
at com.microsoft.jenkins.kubernetes.wrapper.V1ResourceManager$DeploymentUpdater.getCurrentResource(V1ResourceManager.java:213)
at com.microsoft.jenkins.kubernetes.wrapper.V1ResourceManager$DeploymentUpdater.getCurrentResource(V1ResourceManager.java:201)
at com.microsoft.jenkins.kubernetes.wrapper.ResourceManager$ResourceUpdater.createOrApply(ResourceManager.java:93)
at com.microsoft.jenkins.kubernetes.wrapper.KubernetesClientWrapper.handleResource(KubernetesClientWrapper.java:289)
at com.microsoft.jenkins.kubernetes.wrapper.KubernetesClientWrapper.apply(KubernetesClientWrapper.java:256)
at com.microsoft.jenkins.kubernetes.command.DeploymentCommand$DeploymentTask.doCall(DeploymentCommand.java:172)
Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to JNLP4-connect connection from 10.233.90.251/10.233.90.251:44446
Caused by: hudson.remoting.ProxyException: io.kubernetes.client.openapi.ApiException:
at io.kubernetes.client.openapi.ApiClient.handleResponse(ApiClient.java:979)
at io.kubernetes.client.openapi.ApiClient.execute(ApiClient.java:895)
at io.kubernetes.client.openapi.apis.AppsV1Api.readNamespacedDeploymentWithHttpInfo(AppsV1Api.java:7299)
at io.kubernetes.client.openapi.apis.AppsV1Api.readNamespacedDeployment(AppsV1Api.java:7275)
at com.microsoft.jenkins.kubernetes.wrapper.V1ResourceManager$DeploymentUpdater.getCurrentResource(V1ResourceManager.java:210)
... 16 more
Api call failed with code 400, detailed message: {
"kind": "Status",
"apiVersion": "v1",
"metadata": {
"status": "Failure",
"message": "the export parameter, deprecated since v1.14, is no longer supported",
"reason": "BadRequest",
"code": 400
这个问题怎么解决?
