2个节点的calico-node均等待中,报错信息如下:
Namespace: kube-system
Priority: 2000001000
Priority Class Name: system-node-critical
Node: ecs-f6f0/192.168.55.15
Start Time: Wed, 23 Nov 2022 10:45:56 +0800
Labels: controller-revision-hash=78fbbfbbc8
k8s-app=calico-node
pod-template-generation=1
Annotations: <none>
Status: Running
IP: 192.168.55.15
IPs:
IP: 192.168.55.15
Controlled By: DaemonSet/calico-node
Init Containers:
upgrade-ipam:
Container ID: docker://949a97321d25779090f726db4582d48ef82c6821dbcb221fdada460a4700a5cb
Image: calico/cni:v3.23.2
Image ID: docker-pullable://calico/cni@sha256:a5c1e5eba59b0b59b6767fbcfb6d4b2cef355a83cfc0627b31e7f4dddfec09d0
Port: <none>
Host Port: <none>
Command:
/opt/cni/bin/calico-ipam
-upgrade
State: Terminated
Reason: Completed
Exit Code: 0
Started: Wed, 23 Nov 2022 10:45:57 +0800
Finished: Wed, 23 Nov 2022 10:45:57 +0800
Ready: True
Restart Count: 0
Environment Variables from:
kubernetes-services-endpoint ConfigMap Optional: true
Environment:
KUBERNETES_NODE_NAME: (v1:spec.nodeName)
CALICO_NETWORKING_BACKEND: <set to the key 'calico_backend' of config map 'calico-config'> Optional: false
Mounts:
/host/opt/cni/bin from cni-bin-dir (rw)
/var/lib/cni/networks from host-local-net-dir (rw)
/var/run/secrets/kubernetes.io/serviceaccount from kube-api-access-l8bj5 (ro)
install-cni:
Container ID: docker://fc651e6b709a3c609057748290ef2ed0f993eaab0b44d33055c1f4d0e0800476
Port: <none>
Host Port: <none>
Command:
/opt/cni/bin/install
State: Terminated
Reason: Completed
Exit Code: 0
Started: Wed, 23 Nov 2022 10:45:58 +0800
Finished: Wed, 23 Nov 2022 10:46:00 +0800
Ready: True
Restart Count: 0
Environment:
CNI_CONF_NAME: 10-calico.conflist
CNI_NETWORK_CONFIG: <set to the key 'cni_network_config' of config map 'calico-config'> Optional: false
CNI_MTU: <set to the key 'veth_mtu' of config map 'calico-config'> Optional: false
SLEEP: false
Mounts:
/host/etc/cni/net.d from cni-net-dir (rw)
Containers:
calico-node:
Container ID: docker://c57f331d6a56df75b198476b304ea9fc6712e5c071addc5d281d6cf5684a8be8
Image: calico/node:v3.23.2
Image ID: docker-pullable://calico/node@sha256:b4ac0660c297b3a582ef2f4a0d7ef86f954ad5497b704b41d82fa99418e7a51e
Port: <none>
Host Port: <none>
State: Running
Started: Wed, 23 Nov 2022 10:46:00 +0800
Ready: False
Restart Count: 0
Requests:
cpu: 250m
Liveness: exec [/bin/calico-node -felix-live -bird-live] delay=10s timeout=10s period=10s #success=1 #failure=6
Readiness: exec [/bin/calico-node -felix-ready -bird-ready] delay=0s timeout=10s period=10s #success=1 #failure=3
Environment:
DATASTORE_TYPE: kubernetes
WAIT_FOR_DATASTORE: true
NODENAME: (v1:spec.nodeName)
CLUSTER_TYPE: k8s,bgp
NODEIP: (v1:status.hostIP)
IP_AUTODETECTION_METHOD: can-reach=$(NODEIP)
IP: autodetect
CALICO_IPV4POOL_IPIP: Always
CALICO_IPV4POOL_VXLAN: Never
CALICO_IPV6POOL_VXLAN: Never
FELIX_IPINIPMTU: <set to the key 'veth_mtu' of config map 'calico-config'> Optional: false
FELIX_VXLANMTU: <set to the key 'veth_mtu' of config map 'calico-config'> Optional: false
FELIX_WIREGUARDMTU: <set to the key 'veth_mtu' of config map 'calico-config'> Optional: false
CALICO_IPV4POOL_CIDR: 10.233.64.0/18
CALICO_IPV4POOL_BLOCK_SIZE: 24
CALICO_DISABLE_FILE_LOGGING: true
FELIX_DEFAULTENDPOINTTOHOSTACTION: ACCEPT
FELIX_IPV6SUPPORT: false
FELIX_HEALTHENABLED: true
Mounts:
/lib/modules from lib-modules (ro)
/run/xtables.lock from xtables-lock (rw)
/sys/fs/ from sysfs (rw)
/var/lib/calico from var-lib-calico (rw)
/var/log/calico/cni from cni-log-dir (ro)
/var/run/calico from var-run-calico (rw)
/var/run/nodeagent from policysync (rw)
Conditions:
Type Status
Initialized True
Ready False
ContainersReady False
PodScheduled True
Volumes:
lib-modules:
Type: HostPath (bare host directory volume)
Path: /lib/modules
HostPathType:
var-run-calico:
Path: /var/run/calico
HostPathType:
var-lib-calico:
Path: /var/lib/calico
HostPathType:
xtables-lock:
Path: /run/xtables.lock
HostPathType: FileOrCreate
sysfs:
Path: /sys/fs/
HostPathType: DirectoryOrCreate
cni-bin-dir:
Path: /opt/cni/bin
HostPathType:
cni-net-dir:
Path: /etc/cni/net.d
HostPathType:
cni-log-dir:
Path: /var/log/calico/cni
HostPathType:
host-local-net-dir:
Path: /var/lib/cni/networks
HostPathType:
policysync:
Path: /var/run/nodeagent
kube-api-access-l8bj5:
Type: Projected (a volume that contains injected data from multiple sources)
TokenExpirationSeconds: 3607
ConfigMapName: kube-root-ca.crt
ConfigMapOptional: <nil>
DownwardAPI: true
QoS Class: Burstable
Node-Selectors: kubernetes.io/os=linux
Tolerations: :NoSchedule op=Exists
:NoExecute op=Exists
CriticalAddonsOnly op=Exists
node.kubernetes.io/disk-pressure:NoSchedule op=Exists
node.kubernetes.io/memory-pressure:NoSchedule op=Exists
node.kubernetes.io/network-unavailable:NoSchedule op=Exists
node.kubernetes.io/not-ready:NoExecute op=Exists
node.kubernetes.io/pid-pressure:NoSchedule op=Exists
node.kubernetes.io/unreachable:NoExecute op=Exists
node.kubernetes.io/unschedulable:NoSchedule op=Exists
Events:
Type Reason Age From Message
Warning Unhealthy 37s (x38382 over 3d22h) kubelet (combined from similar events): Readiness probe failed: 2022-11-29 01:09:07.507 [INFO][10350] confd/health.go 180: Number of node(s) with BGP peering established = 0
calico/node is not ready: BIRD is not ready: BGP not established with 192.168.55.242
