java.util.concurrent.RejectedExecutionException: Task okhttp3.RealCall$AsyncCall@7c8b7013 rejected from java.util.concurrent.ThreadPoolExecutor@419bf038[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 70]
at java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(ThreadPoolExecutor.java:2063)
at java.util.concurrent.ThreadPoolExecutor.reject(ThreadPoolExecutor.java:830)
at java.util.concurrent.ThreadPoolExecutor.execute(ThreadPoolExecutor.java:1379)
at okhttp3.RealCall$AsyncCall.executeOn(RealCall.java:183)
Caused: java.io.InterruptedIOException: executor rejected
at okhttp3.RealCall$AsyncCall.executeOn(RealCall.java:186)
at okhttp3.Dispatcher.promoteAndExecute(Dispatcher.java:186)
at okhttp3.Dispatcher.enqueue(Dispatcher.java:137)
at okhttp3.RealCall.enqueue(RealCall.java:127)
at okhttp3.internal.ws.RealWebSocket.connect(RealWebSocket.java:193)
at okhttp3.OkHttpClient.newWebSocket(OkHttpClient.java:435)
at io.fabric8.kubernetes.client.dsl.internal.WatchConnectionManager.runWatch(WatchConnectionManager.java:156)
at io.fabric8.kubernetes.client.dsl.internal.WatchConnectionManager.access$1200(WatchConnectionManager.java:50)
at io.fabric8.kubernetes.client.dsl.internal.WatchConnectionManager$2$1.execute(WatchConnectionManager.java:320)
at io.fabric8.kubernetes.client.dsl.internal.WatchConnectionManager$NamedRunnable.run(WatchConnectionManager.java:409)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
2022-12-01 03:48:06.451+0000 [id=40] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:48:06.451+0000 [id=40] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:48:11.451+0000 [id=34] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:48:11.451+0000 [id=34] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:48:16.451+0000 [id=39] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:48:16.451+0000 [id=39] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:48:21.451+0000 [id=29] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:48:21.451+0000 [id=29] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:48:26.451+0000 [id=35] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:48:26.451+0000 [id=35] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:48:31.451+0000 [id=38] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:48:31.451+0000 [id=38] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:48:36.122+0000 [id=1137] WARNING i.f.k.c.d.i.WatchConnectionManager$1#onFailure: Exec Failure
java.util.concurrent.RejectedExecutionException: Task okhttp3.RealCall$AsyncCall@52605bfa rejected from java.util.concurrent.ThreadPoolExecutor@419bf038[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 70]
2022-12-01 03:48:36.451+0000 [id=35] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:48:36.451+0000 [id=35] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:48:41.451+0000 [id=28] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:48:41.451+0000 [id=28] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:48:46.451+0000 [id=40] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:48:46.451+0000 [id=40] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:48:51.451+0000 [id=25] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:48:51.451+0000 [id=25] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:48:56.451+0000 [id=34] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:48:56.451+0000 [id=34] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:49:01.451+0000 [id=31] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:49:01.451+0000 [id=31] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:49:06.451+0000 [id=25] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:49:06.451+0000 [id=25] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:49:07.521+0000 [id=63671] WARNING o.c.j.p.k.KubernetesLauncher#launch: Error in provisioning; agent=KubernetesSlave name: nodejs-d51k1, template=PodTemplate{id=‘c80c4dd2-9a64-42dd-8897-f37d2185d313’, name=‘nodejs’, namespace=‘kubesphere-devops-system’, label=‘nodejs’, nodeUsageMode=EXCLUSIVE, workspaceVolume=EmptyDirWorkspaceVolume [memory=false], volumes=[HostPathVolume [mountPath=/var/run/docker.sock, hostPath=/var/run/docker.sock], HostPathVolume [mountPath=/root/.yarn, hostPath=/var/data/jenkins_nodejs_yarn_cache], HostPathVolume [mountPath=/root/.npm, hostPath=/var/data/jenkins_nodejs_npm_cache], HostPathVolume [mountPath=/root/.sonar/cache, hostPath=/var/data/jenkins_sonar_cache]], containers=[ContainerTemplate{name=‘nodejs’, image=‘registry.cn-beijing.aliyuncs.com/kubesphereio/builder-nodejs:v3.1.0’, command=‘cat’, args='', ttyEnabled=true, resourceRequestCpu=‘100m’, resourceRequestMemory=‘100Mi’, resourceLimitCpu=‘4000m’, resourceLimitMemory=‘8192Mi’}, ContainerTemplate{name=‘jnlp’, image=‘registry.cn-beijing.aliyuncs.com/kubesphereio/jnlp-slave:3.27-1’, command=‘jenkins-slave’, args=‘${computer.jnlpmac} ${computer.name}’, resourceRequestCpu=‘50m’, resourceRequestMemory=‘400Mi’, resourceLimitMemory=‘1536Mi’}]}
io.fabric8.kubernetes.client.KubernetesClientTimeoutException: Timed out waiting for [100000] milliseconds for [Pod] with name:[nodejs-d51k1] in namespace [kubesphere-devops-system].
at org.csanchez.jenkins.plugins.kubernetes.AllContainersRunningPodWatcher.await(AllContainersRunningPodWatcher.java:97)
at org.csanchez.jenkins.plugins.kubernetes.KubernetesLauncher.launch(KubernetesLauncher.java:156)
at hudson.slaves.SlaveComputer.lambda$_connect$0(SlaveComputer.java:294)
at jenkins.util.ContextResettingExecutorService$2.call(ContextResettingExecutorService.java:46)
at jenkins.security.ImpersonatingExecutorService$2.call(ImpersonatingExecutorService.java:71)
2022-12-01 03:49:07.523+0000 [id=63671] INFO o.c.j.p.k.KubernetesSlave#_terminate: Terminating Kubernetes instance for agent nodejs-d51k1
2022-12-01 03:49:07.538+0000 [id=63671] INFO o.c.j.p.k.KubernetesSlave#deleteSlavePod: Terminated Kubernetes instance for agent kubesphere-devops-system/nodejs-d51k1
Disconnected computer nodejs-d51k1
2022-12-01 03:49:07.541+0000 [id=63671] INFO o.c.j.p.k.KubernetesSlave#_terminate: Disconnected computer nodejs-d51k1
2022-12-01 03:49:08.123+0000 [id=1137] WARNING i.f.k.c.d.i.WatchConnectionManager$1#onFailure: Exec Failure
java.util.concurrent.RejectedExecutionException: Task okhttp3.RealCall$AsyncCall@2ac5deac rejected from java.util.concurrent.ThreadPoolExecutor@419bf038[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 70]
2022-12-01 03:49:11.451+0000 [id=29] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 1
2022-12-01 03:49:11.451+0000 [id=29] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:49:11.459+0000 [id=29] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:49:11.459+0000 [id=29] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:49:12.462+0000 [id=63691] INFO hudson.slaves.NodeProvisioner#lambda$update$6: nodejs-hj6cm provisioning successfully completed. We have now 3 computer(s)
2022-12-01 03:49:12.462+0000 [id=63691] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:49:12.462+0000 [id=63691] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:49:12.463+0000 [id=63691] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:49:12.480+0000 [id=63671] INFO o.c.j.p.k.KubernetesLauncher#launch: Created Pod: kubesphere-devops-system/nodejs-hj6cm
2022-12-01 03:49:12.545+0000 [id=63671] INFO o.internal.platform.Platform#log: ALPN callback dropped: HTTP/2 is disabled. Is alpn-boot on the boot class path?
2022-12-01 03:49:16.451+0000 [id=29] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:49:16.451+0000 [id=29] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:49:17.528+0000 [id=63647] WARNING o.c.j.p.k.KubernetesLauncher#launch: Error in provisioning; agent=KubernetesSlave name: nodejs-mkkc9, template=PodTemplate{id=‘c80c4dd2-9a64-42dd-8897-f37d2185d313’, name=‘nodejs’, namespace=‘kubesphere-devops-system’, label=‘nodejs’, nodeUsageMode=EXCLUSIVE, workspaceVolume=EmptyDirWorkspaceVolume [memory=false], volumes=[HostPathVolume [mountPath=/var/run/docker.sock, hostPath=/var/run/docker.sock], HostPathVolume [mountPath=/root/.yarn, hostPath=/var/data/jenkins_nodejs_yarn_cache], HostPathVolume [mountPath=/root/.npm, hostPath=/var/data/jenkins_nodejs_npm_cache], HostPathVolume [mountPath=/root/.sonar/cache, hostPath=/var/data/jenkins_sonar_cache]], containers=[ContainerTemplate{name=‘nodejs’, image=‘registry.cn-beijing.aliyuncs.com/kubesphereio/builder-nodejs:v3.1.0’, command=‘cat’, args='', ttyEnabled=true, resourceRequestCpu=‘100m’, resourceRequestMemory=‘100Mi’, resourceLimitCpu=‘4000m’, resourceLimitMemory=‘8192Mi’}, ContainerTemplate{name=‘jnlp’, image=‘registry.cn-beijing.aliyuncs.com/kubesphereio/jnlp-slave:3.27-1’, command=‘jenkins-slave’, args=‘${computer.jnlpmac} ${computer.name}’, resourceRequestCpu=‘50m’, resourceRequestMemory=‘400Mi’, resourceLimitMemory=‘1536Mi’}]}
io.fabric8.kubernetes.client.KubernetesClientTimeoutException: Timed out waiting for [100000] milliseconds for [Pod] with name:[nodejs-mkkc9] in namespace [kubesphere-devops-system].
2022-12-01 03:49:17.529+0000 [id=63647] INFO o.c.j.p.k.KubernetesSlave#_terminate: Terminating Kubernetes instance for agent nodejs-mkkc9
2022-12-01 03:49:17.546+0000 [id=63647] INFO o.c.j.p.k.KubernetesSlave#deleteSlavePod: Terminated Kubernetes instance for agent kubesphere-devops-system/nodejs-mkkc9
Disconnected computer nodejs-mkkc9
2022-12-01 03:49:17.546+0000 [id=63647] INFO o.c.j.p.k.KubernetesSlave#_terminate: Disconnected computer nodejs-mkkc9
2022-12-01 03:49:21.451+0000 [id=39] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 1
2022-12-01 03:49:21.451+0000 [id=39] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:49:21.456+0000 [id=39] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:49:21.456+0000 [id=39] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:49:22.459+0000 [id=63647] INFO hudson.slaves.NodeProvisioner#lambda$update$6: nodejs-4ks34 provisioning successfully completed. We have now 3 computer(s)
2022-12-01 03:49:22.459+0000 [id=63647] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:49:22.459+0000 [id=63647] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:49:22.472+0000 [id=63691] INFO o.c.j.p.k.KubernetesLauncher#launch: Created Pod: kubesphere-devops-system/nodejs-4ks34
2022-12-01 03:49:22.520+0000 [id=63615] INFO o.internal.platform.Platform#log: ALPN callback dropped: HTTP/2 is disabled. Is alpn-boot on the boot class path?
2022-12-01 03:49:22.567+0000 [id=63691] INFO o.internal.platform.Platform#log: ALPN callback dropped: HTTP/2 is disabled. Is alpn-boot on the boot class path?
2022-12-01 03:49:22.594+0000 [id=63671] INFO o.internal.platform.Platform#log: ALPN callback dropped: HTTP/2 is disabled. Is alpn-boot on the boot class path?
2022-12-01 03:49:26.451+0000 [id=35] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:49:26.451+0000 [id=35] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:49:31.451+0000 [id=38] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:49:31.451+0000 [id=38] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:49:36.451+0000 [id=35] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:49:36.451+0000 [id=35] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
2022-12-01 03:49:40.124+0000 [id=1137] WARNING i.f.k.c.d.i.WatchConnectionManager$1#onFailure: Exec Failure
java.util.concurrent.RejectedExecutionException: Task okhttp3.RealCall$AsyncCall@70ff48c2 rejected from java.util.concurrent.ThreadPoolExecutor@419bf038[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 70]
2022-12-01 03:49:41.451+0000 [id=34] INFO o.c.j.p.k.KubernetesCloud#provision: Excess workload after pending Kubernetes agents: 0
2022-12-01 03:49:41.451+0000 [id=34] INFO o.c.j.p.k.KubernetesCloud#provision: Template for label nodejs: nodejs
