Ubuntu 20.04.2 LTS
将 kubectl version
命令执行结果贴在下方
請問我想用all-in-one的安裝方式指定kubernetes 的版本會出現下面這個錯誤,
有人知道該怎麼解決嗎?不過如果使用1.22.12版本就沒有這個問題,但是因為相依問題所以得安裝此版本。
sudo ./kk create cluster –with-kubernetes v1.20.15 –with-kubesphere v3.3.1
Failed to download kubeadm binary: curl -L -o /home/mars/kubeshpere/kubekey/kube/v1.20.15/amd64/kubeadm https://storage.googleapis.com/kubernetes-release/release/v1.20.15/bin/linux/amd64/kubeadm error: No SHA256 found for kubeadm. v1.20.15 is not supported.
03:34:09 UTC failed: [LocalHost]
error: Pipeline[CreateClusterPipeline] execute failed: Module[NodeBinariesModule] exec failed:
failed: [LocalHost] [DownloadBinaries] exec failed after 1 retires: Failed to download kubeadm binary: curl -L -o /home/mars/kubeshpere/kubekey/kube/v1.20.15/amd64/kubeadm https://storage.googleapis.com/kubernetes-release/release/v1.20.15/bin/linux/amd64/kubeadm error: No SHA256 found for kubeadm. v1.20.15 is not supported.
