- 虚拟机 Oracle Linux Server 8.4,4C/16G
- 安装命令:./kk create cluster –with-kubernetes v1.21.5 –with-kubesphere v3.2.0
# kubectl version
Client Version: version.Info{Major:"1", Minor:"21", GitVersion:"v1.21.5", GitCommit:"aea7bbadd2fc0cd689de94a54e5b7b758869d691", GitTreeState:"clean", BuildDate:"2021-09-15T21:10:45Z", GoVersion:"go1.16.8", Compiler:"gc", Platform:"linux/amd64"}
Server Version: version.Info{Major:"1", Minor:"21", GitVersion:"v1.21.5", GitCommit:"aea7bbadd2fc0cd689de94a54e5b7b758869d691", GitTreeState:"clean", BuildDate:"2021-09-15T21:04:16Z", GoVersion:"go1.16.8", Compiler:"gc", Platform:"linux/amd64"}
# docker version
Client:
Version: 20.10.8
API version: 1.41
Go version: go1.16.6
Git commit: 3967b7d
Experimental: true
Version: 20.10.8
Git commit: 75249d8
Version: v1.4.9
Version: 1.0.1
GitCommit: v1.0.1-0-g4144b638
Version: 0.19.0
GitCommit: de40ad0
- kubernetes v1.21.5
- kubesphere v3.2.0
- 使用kk安装,在线安装
安装完毕使用了一段时间,今天不小心在web页面将ks-apiserver
的 replicas: 1
设置为0
,导致界面无法登陆,在登陆虚拟机终端通过命令:kubectl edit deployment ks-apiserver -n kubesphere-system
将ks-apiserver
的 replicas: 0
从新修改为1
,但是现在ks-apiserver
一直在重启,导致kubesphere
无法登陆。
一些具体的信息:
# kubectl get service -n kubesphere-system
ks-apiserver NodePort 10.233.2.181 <none> 80:30154/TCP 474d
ks-console NodePort 10.233.63.17 <none> 80:30880/TCP 474d
ks-controller-manager ClusterIP 10.233.10.5 <none> 443/TCP 474d
minio ClusterIP 10.233.5.70 <none> 9000/TCP 470d
tower LoadBalancer 10.233.8.244 <pending> 8080:31970/TCP 474d
# kubectl get deployments -n kubesphere-system
NAME READY UP-TO-DATE AVAILABLE AGE
ks-apiserver 0/1 1 0 474d
ks-console 1/1 1 1 474d
ks-controller-manager 1/1 1 1 474d
ks-installer 0/1 1 0 159m
minio 1/1 1 1 470d
tower 1/1 1 1 474d
# kubectl get pods -n kubesphere-system
ks-apiserver-64568c4c-twwb6 0/1 CrashLoopBackOff 36 151m
ks-console-565df7f477-4nxw4 1/1 Running 3 474d
ks-controller-manager-7c5d587b7b-2zkt8 1/1 Running 296 470d
ks-installer-6484f6c4cf-7kr85 0/1 CrashLoopBackOff 32 159m
minio-859cb4d777-f5f44 1/1 Running 9 470d
openpitrix-import-job-lvr9q 0/1 Completed 0 470d
tower-786bb99f5d-2fp97 1/1 Running 144 474d
在容器重启过程中,界面可以刷出来,登陆界面的报错:
request to http://ks-apiserver/oauth/token failed, reason: connect ECONNREFUSED 10.233.2.181:80
容器的日志报错:
# kubectl logs ks-apiserver-64568c4c-twwb6 -n kubesphere-system
W0308 17:20:11.978847 1 client_config.go:615] Neither --kubeconfig nor --master was specified. Using the inClusterConfig. This might not work.
W0308 17:20:11.980650 1 client_config.go:615] Neither --kubeconfig nor --master was specified. Using the inClusterConfig. This might not work.
E0308 17:20:41.981744 1 metricsserver.go:231] Get "https://10.233.0.1:443/api?timeout=32s": dial tcp 10.233.0.1:443: i/o timeout
W0308 17:20:41.981791 1 options.go:183] ks-apiserver starts without redis provided, it will use in memory cache. This may cause inconsistencies when running ks-apiserver with multiple replicas.
F0308 17:21:11.984241 1 options.go:235] unable to create controller runtime cache: could not create RESTMapper from config
从报错看是连接超时,但是从同一个 namespace的 ks-controller-manager-7c5d587b7b-2zkt8
发现IP和端口是通的
# docker exec -ti beb9270b13c8 /bin/sh
/ # nc -zv 10.233.0.1 443
10.233.0.1 (10.233.0.1:443) open
在虚拟机上执行:
# curl -k https://10.233.0.1:443
"kind": "Status",
"apiVersion": "v1",
"metadata": {
"status": "Failure",
"message": "forbidden: User \"system:anonymous\" cannot get path \"/\"",
"reason": "Forbidden",
"details": {
"code": 403
我现在倾向于是下面报错导致的问题
但是在虚拟机上执行:
# kubectl get config -n kubesphere-system
No resources found
请帮忙看下。
