kubesphere-system 下的etcd在节点重启后 Error,导致minio服务启动失败。
报 etcdserver: raft save state and entries error: input/output error 错误
使用helm delete –purge 删除minio 也delete了job,重新部署minio依然失败
尝试过删除ETCD-PVC 下的文件,重新部署etcd 还是报错
mvcc/backend: cannot commit tx (input/output error),请问这种问题怎么解决?
2020-03-29 09:45:03.400017 I | etcdserver: name = default
2020-03-29 09:45:03.400036 I | etcdserver: data dir = /data
2020-03-29 09:45:03.400039 I | etcdserver: member dir = /data/member
2020-03-29 09:45:03.400041 I | etcdserver: heartbeat = 100ms
2020-03-29 09:45:03.400042 I | etcdserver: election = 1000ms
2020-03-29 09:45:03.400044 I | etcdserver: snapshot count = 100000
2020-03-29 09:45:03.400051 I | etcdserver: advertise client URLs = http://etcd.kubesphere-system.svc:2379
2020-03-29 09:45:03.400053 I | etcdserver: initial advertise peer URLs = http://localhost:2380
2020-03-29 09:45:03.400060 I | etcdserver: initial cluster = default=http://localhost:2380
2020-03-29 09:45:03.433237 I | etcdserver: starting member 8e9e05c52164694d in cluster cdf818194e3a8c32
2020-03-29 09:45:03.433267 I | raft: 8e9e05c52164694d became follower at term 0
2020-03-29 09:45:03.433276 I | raft: newRaft 8e9e05c52164694d [peers: [], term: 0, commit: 0, applied: 0, lastindex: 0, lastterm: 0]
2020-03-29 09:45:03.433279 I | raft: 8e9e05c52164694d became follower at term 1
2020-03-29 09:45:03.463421 W | auth: simple token is not cryptographically signed
2020-03-29 09:45:03.480814 I | etcdserver: starting server... [version: 3.2.18, cluster version: to_be_decided]
2020-03-29 09:45:03.481078 I | etcdserver: 8e9e05c52164694d as single-node; fast-forwarding 9 ticks (election ticks 10)
2020-03-29 09:45:03.481369 I | etcdserver/membership: added member 8e9e05c52164694d [http://localhost:2380] to cluster cdf818194e3a8c32
2020-03-29 09:45:04.445766 I | raft: 8e9e05c52164694d is starting a new election at term 1
2020-03-29 09:45:04.445827 I | raft: 8e9e05c52164694d became candidate at term 2
2020-03-29 09:45:04.445842 I | raft: 8e9e05c52164694d received MsgVoteResp from 8e9e05c52164694d at term 2
2020-03-29 09:45:04.445850 I | raft: 8e9e05c52164694d became leader at term 2
2020-03-29 09:45:04.445854 I | raft: raft.node: 8e9e05c52164694d elected leader 8e9e05c52164694d at term 2
2020-03-29 09:45:04.445995 I | etcdserver: setting up the initial cluster version to 3.2
2020-03-29 09:45:04.446183 I | embed: ready to serve client requests
2020-03-29 09:45:04.446295 I | etcdserver: published {Name:default ClientURLs:[http://etcd.kubesphere-system.svc:2379]} to cluster cdf818194e3a8c32
2020-03-29 09:45:04.446470 N | embed: serving insecure client requests on [::]:2379, this is strongly discouraged!
2020-03-29 09:45:07.522741 C | mvcc/backend: cannot commit tx (input/output error)
