报错信息为:msg":“Failed to init storage factory”,“error”:“failed to create primary Elasticsearch client: health check timeout: no Elasticsearch node available”,“errorVerbose”:"no Elasticsearch node available
不知道是不是因为安装完ks,再修改外接elk地址导致的呢
kubectl get po -n kubesphere-logging-system
elasticsearch-logging-data-0 1/1 Running 0 2d16h
elasticsearch-logging-discovery-0 1/1 Running 1 3d13h
elasticsearch-logging-discovery-1 1/1 Running 1 3d13h
elasticsearch-logging-discovery-2 1/1 Running 1 3d13h
elasticsearch-logging-kibana-867f4c47c-7fbwc 1/1 Running 0 39m
fluent-bit-8nrrj 2/2 Running 4 67d
fluent-bit-h8gbp 2/2 Running 2 67d
fluent-bit-kdks9 2/2 Running 6 67d
fluent-bit-sjtlq 2/2 Running 2 67d
fluent-bit-sm8f9 2/2 Running 2 67d
fluent-bit-v5xf9 2/2 Running 14 67d
logging-fluentbit-operator-858b6c4cc7-27sk2 1/1 Running 0 39m
logsidecar-injector-67bbcdd8c6-2xdbm 1/1 Running 1 3d14h
logsidecar-injector-67bbcdd8c6-bdzbg 1/1 Running 1 3d14h
{"level":"info","ts":1587534777.6271994,"caller":"flags/service.go:115","msg":"Mounting metrics handler on admin server","route":"/metrics"}
{"level":"info","ts":1587534777.627708,"caller":"flags/admin.go:108","msg":"Mounting health check on admin server","route":"/"}
{"level":"info","ts":1587534777.6277888,"caller":"flags/admin.go:114","msg":"Starting admin HTTP server","http-port":14269}
{"level":"info","ts":1587534777.6278222,"caller":"flags/admin.go:100","msg":"Admin server started","http-port":14269,"health-status":"unavailable"}
{"level":"fatal","ts":1587534782.642159,"caller":"collector/main.go:89","msg":"Failed to init storage factory","error":"failed to create primary Elasticsearch client: health check timeout: no Elasticsearch node available","errorVerbose":"no Elasticsearch node available\ngithub.com/jaegertracing/jaeger/vendor/gopkg.in/olivere/elastic%2ev5.init.ializers\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/vendor/gopkg.in/olivere/elastic.v5/client.go:88\nruntime.main\n\t/home/travis/.gimme/versions/go1.12.1.linux.amd64/src/runtime/proc.go:188\nruntime.goexit\n\t/home/travis/.gimme/versions/go1.12.1.linux.amd64/src/runtime/asm_amd64.s:1337\nhealth check timeout\ngithub.com/jaegertracing/jaeger/vendor/gopkg.in/olivere/elastic%2ev5.(*Client).startupHealthcheck\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/vendor/gopkg.in/olivere/elastic.v5/client.go:1118\ngithub.com/jaegertracing/jaeger/vendor/gopkg.in/olivere/elastic%2ev5.NewClient\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/vendor/gopkg.in/olivere/elastic.v5/client.go:244\ngithub.com/jaegertracing/jaeger/pkg/es/config.(*Configuration).NewClient\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/pkg/es/config/config.go:100\ngithub.com/jaegertracing/jaeger/plugin/storage/es.(*Factory).Initialize\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/plugin/storage/es/factory.go:80\ngithub.com/jaegertracing/jaeger/plugin/storage.(*Factory).Initialize\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/plugin/storage/factory.go:107\nmain.main.func1\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/cmd/collector/main.go:88\ngithub.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra.(*Command).execute\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra/command.go:762\ngithub.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra.(*Command).ExecuteC\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra/command.go:852\ngithub.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra.(*Command).Execute\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra/command.go:800\nmain.main\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/cmd/collector/main.go:180\nruntime.main\n\t/home/travis/.gimme/versions/go1.12.1.linux.amd64/src/runtime/proc.go:200\nruntime.goexit\n\t/home/travis/.gimme/versions/go1.12.1.linux.amd64/src/runtime/asm_amd64.s:1337\nfailed to create primary Elasticsearch client\ngithub.com/jaegertracing/jaeger/plugin/storage/es.(*Factory).Initialize\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/plugin/storage/es/factory.go:82\ngithub.com/jaegertracing/jaeger/plugin/storage.(*Factory).Initialize\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/plugin/storage/factory.go:107\nmain.main.func1\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/cmd/collector/main.go:88\ngithub.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra.(*Command).execute\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra/command.go:762\ngithub.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra.(*Command).ExecuteC\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra/command.go:852\ngithub.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra.(*Command).Execute\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra/command.go:800\nmain.main\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/cmd/collector/main.go:180\nruntime.main\n\t/home/travis/.gimme/versions/go1.12.1.linux.amd64/src/runtime/proc.go:200\nruntime.goexit\n\t/home/travis/.gimme/versions/go1.12.1.linux.amd64/src/runtime/asm_amd64.s:1337","stacktrace":"main.main.func1\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/cmd/collector/main.go:89\ngithub.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra.(*Command).execute\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra/command.go:762\ngithub.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra.(*Command).ExecuteC\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra/command.go:852\ngithub.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra.(*Command).Execute\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/vendor/github.com/spf13/cobra/command.go:800\nmain.main\n\t/home/travis/gopath/src/github.com/jaegertracing/jaeger/cmd/collector/main.go:180\nruntime.main\n\t/home/travis/.gimme/versions/go1.12.1.linux.amd64/src/runtime/proc.go:200"}
