wangpo1991K零S
手把手教程:Kubeadm 安装 k8s 后安装 kubesphere 2.1.1
wangpo1991K零S
切换openebs存储为nfs果然好使了,目前已经完成安装
感谢大哥的帖子,感谢kubesphere官方
全网找不到centos7.7
wangpo1991 老铁能贴下你咋改的nfs的吗?我也是一直pending,要无奈了。。。
LleishengxnK零S
nfs可以在线上用吗?
wangpo1991K零S
zhenghao299 这个帖子上面有啊,你好好看下这个开贴的大哥写的,比较详细,按照他说的,但是master不要安装NFS server,另外注意一下tiller的版本,最近比较忙,没有及时看,哎
Zzk8sK零S
- 已编辑
可能的文档修正:
storageclass.yaml 文件中涉及rbac部分的配置应添加kube-system命名空间的用户
kind: ClusterRoleBinding
apiVersion: rbac.authorization.k8s.io/v1
subjects:
- kind: ServiceAccount
namespace: default
- kind: ServiceAccount //这三行之前没有
namespace: kube-system
roleRef:
kind: ClusterRole
apiGroup: rbac.authorization.k8s.io
出现的问题:kubesphere-system 命名空间下除了ks-installer的其他三个pod一直为pending状态
后定位到pod nfs-client-provisioner 的日志
[root@kubesphere01 ~]# kubectl logs nfs-client-provisioner-7f959768b5-vchmj
E0830 07:12:31.186152 1 leaderelection.go:234] error retrieving resource lock kube-system/fuseim.pri-ifs: endpoints "fuseim.pri-ifs" is forbidden: User "system:serviceaccount:kube-system:nfs-provisioner" cannot get resource "endpoints" in API group "" in the namespace "kube-system"
E0830 07:12:34.579320 1 leaderelection.go:234] error retrieving resource lock kube-system/fuseim.pri-ifs: endpoints "fuseim.pri-ifs" is forbidden: User "system:serviceaccount:kube-system:nfs-provisioner" cannot get resource "endpoints" in API group "" in the namespace "kube-system"
E0830 07:12:36.602935 1 leaderelection.go:234] error retrieving resource lock kube-system/fuseim.pri-ifs: endpoints "fuseim.pri-ifs" is forbidden: User "system:serviceaccount:kube-system:nfs-provisioner" cannot get resource "endpoints" in API group "" in the namespace "kube-system"
E0830 07:12:40.947084 1 leaderelection.go:234] error retrieving resource lock kube-system/fuseim.pri-ifs: endpoints "fuseim.pri-ifs" is forbidden: User "system:serviceaccount:kube-system:nfs-provisioner" cannot get resource "endpoints" in API group "" in the namespace "kube-system"
E0830 07:12:45.005643 1 leaderelection.go:234] error retrieving resource lock kube-system/fuseim.pri-ifs: endpoints "fuseim.pri-ifs" is forbidden: User "system:serviceaccount:kube-system:nfs-provisioner" cannot get resource "endpoints" in API group "" in the namespace "kube-system"
修改rbac配置并apply后,一切正常,pod转为Running状态
ks-account-596657f8c6-vph5v 这个pod一直处于Init:0/2状态, ks-apigateway-78bcdc8ffc-4znrv 这个报错“ redis.go:51] unable to reach redis hostdial tcp: i/o timeout”,测试redis是正常的
freemankevinK零S
kubesphere-minimal.yaml 找不到了额????:
freemankevinK零S
能不能用3.0的功能全开的yaml 安装2.1.1 呢???
zk8s 按照你的方法做了,最终成功了
你好,请问如何从k8s集群中卸载掉ks而不破坏原有的k8s集群,因为ks和k8s有些东西冲突了
请问有把kubesphere源码编译成二进制文件,然后安装kubesphere的帖子吗
FeynmanK零SK贰SK壹S
wizard2318 没有,但是有编译成二进制文件运行前后端代码的方法 (搭建前后开发环境),我们在 B 站发布了视频教程
