xiaosageK零S
rayzhou2017 https://kubesphere.com.cn/forum/d/297-kubesphere
我的是这个里面的域名—>nginx—>kubesphere ip:port 这种架构 然后按照方法一配置之后还是不行。
rayzhou2017 状态码还是400 错误信息没变 版本是2.1.0
方便把你的nginx配置发下吗?
wanjunlei
`upstream ksin {
server 1.1.1.1:30880;
server {
listen 80;
server_name nb.ex.cn;
rewrite /(.*) https://nb.ex.cn permanent;
server {
listen 443;
add_header Strict-Transport-Security “max-age=63072000” always;
ssl on;
ssl_certificate /usr/local/nginx/nb.ex.cnpem;
ssl_certificate_key /usr/local/nginx/nb.ex.cnkey;
ssl_session_timeout 5m;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_ciphers ALL:!ADH:!EXPORT56:RC4+RSA:+HIGH:+MEDIUM:+LOW:+SSLv2:+EXP;
ssl_prefer_server_ciphers on;
location / {
proxy_pass http://ksin;
proxy_set_header X-Real_IP $remote_addr;
proxy_set_header Host $host;
proxy_set_header X_Forward_For $proxy_add_x_forwarded_for;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection ‘upgrade’;
access_log off;
这是我的ng配置
https://www.nginx.com/blog/websocket-nginx/
参照这个配置
http {
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
upstream websocket {
server 192.168.100.10:8010;
server {
listen 8020;
location / {
proxy_pass http://websocket;
proxy_set_header Connection $connection_upgrade;
这个引号不太对吧,改成
你也可以先确认一下,通过node port可不可以正常打开
hongming 我按照这个配置在登录的时候一直报" 用户名或密码错误" 后台401,但是同样的密码可以用内网IP通过nodeport登录成功,反代到外网就不行:
#nginx
upstream ksconsole {
server 192.168.13.28:30880;
location / {
proxy_pass http://ksconsole;
<-- POST /login 2020/10/28T07:36:11.897
Unauthorized P {
timeout: 0,
[Symbol(Body internals)]:
{ body:
PassThrough {
_readableState: [Object],
readable: false,
domain: null,
_events: [Object],
_eventsCount: 4,
_maxListeners: undefined,
_writableState: [Object],
writable: false,
allowHalfOpen: true,
_transformState: [Object] },
disturbed: true,
error: null },
[Symbol(Response internals)]:
{ url: 'http://ks-apigateway.kubesphere-system.svc/kapis/iam.kubesphere.io/v1alpha2/login',
status: 401,
statusText: 'Unauthorized',
headers: C { [Symbol(map)]: [Object] } } } false
{ code: 401,
message: 'LDAP Result Code 49 "Invalid Credentials": ',
statusText: 'Unauthorized' }
--> POST /login 200 39ms 16.15kb 2020/10/28T07:36:11.936
<-- GET /kapis/monitoring.kubesphere.io/v1alpha2/namespaces/tfsmy-springboot/pods?ownerKind=Deployment&ownerName=commercial-house-api&resources_filter=commercial-house-api-76df6f7896-ldsht%24&metrics_filter=pod_cpu_usage%7Cpod_memory_usage_wo_cache%24 2020/10/28T07:36:12.812
