xiaosageK零S
calico网络出现问题,nodeport访问不通,检查发现calico出现问题
klj890K零S
http://www.asznl.com/post/41
感觉和删除kube-node-lease有关。
klj890K零S
Kubernetes 节点发送的心跳有助于确定节点的可用性。 心跳有两种形式:NodeStatus 和 Lease 对象。 每个节点在 kube-node-lease命名空间 中都有一个关联的 Lease 对象。 Lease 是一种轻量级的资源,可在集群扩展时提高节点心跳机制的性能.
你为什么要删除kube-node-lease?
WwanjunleiK零S
看一下calico-node的日志,kubectl logs
klj890K零S
root@demo2r01n00:# kubectl -n kube-node-lease get leases.coordination.k8s.io
NAME HOLDER AGE
demo2r01n00 demo2r01n00 144d
demo2r01n01 demo2r01n01 144d
demo2r01n02 demo2r01n02 144d
demo2r01n04 demo2r01n04 144d
demo2r01n05 demo2r01n05 144d
demo2r01n06 demo2r01n06 144d
不是什么都没有。。。。。。。有节点信息。
xiaosageK零S
[root@ykj-prod-common-kubesphere-master1 tmp]# kubectl logs -n kube-system calico-node-bcrdm |grep -v INFO
Calico node started successfully
bird: Unable to open configuration file /etc/calico/confd/config/bird6.cfg: No such file or directory
bird: Unable to open configuration file /etc/calico/confd/config/bird.cfg: No such file or directory
2020-05-13 08:49:04.047 [WARNING][45] int_dataplane.go 354: Failed to query VXLAN device error=Link not found
2020-05-13 08:49:04.048 [WARNING][45] int_dataplane.go 366: Can't enable XDP acceleration. error=kernel is too old (have: 3.10.0 but want at least: 4.16.0)
bird: device1: Initializing
bird: direct1: Initializing
bird: Mesh_172_16_1_93: Initializing
bird: Mesh_172_16_6_70: Initializing
bird: device1: Starting
bird: device1: Connected to table master
bird: device1: State changed to feed
bird: direct1: Starting
bird: direct1: Connected to table master
bird: direct1: State changed to feed
bird: Mesh_172_16_1_93: Starting
bird: Mesh_172_16_1_93: State changed to start
bird: Mesh_172_16_6_70: Starting
bird: Mesh_172_16_6_70: State changed to start
bird: Graceful restart started
bird: Started
bird: device1: State changed to up
bird: direct1: State changed to up
bird: Graceful restart done
bird: Started
bird: Mesh_172_16_6_70: Connected to table master
bird: Mesh_172_16_6_70: State changed to wait
bird: Reconfiguration requested by SIGHUP
bird: Reconfiguring
bird: device1: Reconfigured
bird: direct1: Reconfigured
bird: Reconfigured
bird: Reconfiguring
bird: Reconfigured
bird: Reconfiguring
bird: Reconfigured
bird: Reconfiguring
bird: Mesh_172_16_1_93: Reconfigured
bird: Mesh_172_16_6_70: Reconfigured
bird: Reconfigured
2020-05-13 08:49:04.639 [WARNING][45] int_dataplane.go 384: Failed to cleanup preexisting XDP state error=failed to load XDP program (/tmp/felix-xdp-182611776): stat /sys/fs/bpf/calico/xdp/prefilter_v1_calico_tmp_A: no such file or directory
libbpf: Error in bpf_object__probe_name():Invalid argument(22). Couldn't load basic 'r0 = 0' BPF program.
libbpf: failed to load object '/tmp/felix-xdp-182611776'
Error: failed to load object file
2020-05-13 08:49:04.774 [WARNING][45] ipip_mgr.go 112: Failed to add IPIP tunnel device error=exit status 1
2020-05-13 08:49:04.774 [WARNING][45] ipip_mgr.go 89: Failed configure IPIP tunnel device, retrying... error=exit status 1
bird: Mesh_172_16_1_93: Connected to table master
bird: Mesh_172_16_1_93: State changed to wait
bird: Mesh_172_16_1_93: State changed to feed
bird: Mesh_172_16_6_70: State changed to feed
bird: Mesh_172_16_1_93: State changed to up
bird: Mesh_172_16_6_70: State changed to up
xiaosageK零S
[root@ykj-prod-common-kubesphere-master1 tmp]# kubectl logs -n kube-system calico-node-m8ckx |grep -v INFO
2020-05-13 06:41:45.153 [ERROR][47] resource.go 288: Error from checkcmd: "Hangup\n"
2020-05-13 06:41:45.355 [WARNING][44] int_dataplane.go 354: Failed to query VXLAN device error=Link not found
2020-05-13 06:41:45.355 [WARNING][44] int_dataplane.go 366: Can't enable XDP acceleration. error=kernel is too old (have: 3.10.0 but want at least: 4.16.0)
bird: Started
bird: Mesh_172_16_6_69: Initializing
bird: Mesh_172_16_6_69: Starting
bird: Mesh_172_16_6_69: State changed to start
bird: Started
... dropped 59 logs ...
bird: Mesh_172_16_6_69: Connected to table master
bird: Mesh_172_16_6_69: State changed to feed
bird: Mesh_172_16_6_69: State changed to up
2020-05-13 08:46:30.573 [ERROR][47] watcher.go 115: Watch channel error error=etcdserver: mvcc: required revision has been compacted
2020-05-13 08:46:54.614 [ERROR][44] watcher.go 115: Watch channel error error=etcdserver: mvcc: required revision has been compacted
2020-05-13 08:46:54.615 [ERROR][44] watcher.go 115: Watch channel error error=etcdserver: mvcc: required revision has been compacted
xiaosageK零S
2020-05-13 06:40:42.167 [ERROR][48] resource.go 288: Error from checkcmd: "Hangup\n"
2020-05-13 06:40:42.370 [WARNING][50] int_dataplane.go 354: Failed to query VXLAN device error=Link not found
2020-05-13 06:40:42.370 [WARNING][50] int_dataplane.go 366: Can't enable XDP acceleration. error=kernel is too old (have: 3.10.0 but want at least: 4.16.0)
2020-05-13 06:40:42.498 [WARNING][50] int_dataplane.go 384: Failed to cleanup preexisting XDP state error=failed to load XDP program (/tmp/felix-xdp-000481355): stat /sys/fs/bpf/calico/xdp/prefilter_v1_calico_tmp_A: no such file or directory
libbpf: failed to load object '/tmp/felix-xdp-000481355'
... dropped 7 logs ...
bird: Started
bird: Started
... dropped 4 logs ...
2020-05-13 06:40:59.715 [WARNING][50] table.go 508: Detected out-of-sync inserts, marking for resync actualRuleIDs=[]string{"", "tVnHkvAo15HuiPy0", "", ""} chainName="OUTPUT" expectedRuleIDs=[]string{"tVnHkvAo15HuiPy0", "", "", ""} ipVersion=0x4 table="filter"
2020-05-13 06:40:59.715 [WARNING][50] table.go 508: Detected out-of-sync inserts, marking for resync actualRuleIDs=[]string{"", "Cz_u1IQiXIMmKD4c", "", ""} chainName="INPUT" expectedRuleIDs=[]string{"Cz_u1IQiXIMmKD4c", "", "", ""} ipVersion=0x4 table="filter"
2020-05-13 08:46:30.573 [ERROR][48] watcher.go 115: Watch channel error error=etcdserver: mvcc: required revision has been compacted
2020-05-13 08:46:54.614 [ERROR][50] watcher.go 115: Watch channel error error=etcdserver: mvcc: required revision has been compacted
2020-05-13 08:46:54.615 [ERROR][50] watcher.go 115: Watch channel error error=etcdserver: mvcc: required revision has been compacted
WwanjunleiK零S
- 最佳回复由 xiaosage 选择
把calico-node重启下试试
WwanjunleiK零S
还是一样的错误?
klj890K零S
https://github.com/easzlab/kubeasz/issues/66
希望这个对你有帮助。
7 个月 后
3344089386K零S
一样的问题,楼主解决了吗 xiaosage
2 年 后
一样的问题,没有删 lease,搭建好就不行
