2020-06-24 17:58:36.380: FATAL [cluster_block_exception] blocked by: [FORBIDDEN/12/index read-only / allow delete (api)]; :: {“path”:“/.kibana_1”,“query”:{“include_type_name”:true},“body”:"{\“mappings\”:{\“doc\”:{\“dynamic\”:\“strict\”,\“properties\”:{\“config\”:{\“dynamic\”:\“true\”,\“properties\”:{\“buildNum\”:{\“type\”:\“keyword\”}}},\“migrationVersion\”:{\“dynamic\”:\“true\”,\“type\”:\“object\”},\“type\”:{\“type\”:\“keyword\”},\“namespace\”:{\“type\”:\“keyword\”},\“updated_at\”:{\“type\”:\“date\”},\“index-pattern\”:{\“properties\”:{\“fieldFormatMap\”:{\“type\”:\“text\”},\“fields\”:{\“type\”:\“text\”},\“intervalName\”:{\“type\”:\“keyword\”},\“notExpandable\”:{\“type\”:\“boolean\”},\“sourceFilters\”:{\“type\”:\“text\”},\“timeFieldName\”:{\“type\”:\“keyword\”},\“title\”:{\“type\”:\“text\”},\“type\”:{\“type\”:\“keyword\”},\“typeMeta\”:{\“type\”:\“keyword\”}}},\“visualization\”:{\“properties\”:{\“description\”:{\“type\”:\“text\”},\“kibanaSavedObjectMeta\”:{\“properties\”:{\“searchSourceJSON\”:{\“type\”:\“text\”}}},\“savedSearchId\”:{\“type\”:\“keyword\”},\“title\”:{\“type\”:\“text\”},\“uiStateJSON\”:{\“type\”:\“text\”},\“version\”:{\“type\”:\“integer\”},\“visState\”:{\“type\”:\“text\”}}},\“search\”:{\“properties\”:{\“columns\”:{\“type\”:\“keyword\”},\“description\”:{\“type\”:\“text\”},\“hits\”:{\“type\”:\“integer\”},\“kibanaSavedObjectMeta\”:{\“properties\”:{\“searchSourceJSON\”:{\“type\”:\“text\”}}},\“sort\”:{\“type\”:\“keyword\”},\“title\”:{\“type\”:\“text\”},\“version\”:{\“type\”:\“integer\”}}},\“dashboard\”:{\“properties\”:{\“description\”:{\“type\”:\“text\”},\“hits\”:{\“type\”:\“integer\”},\“kibanaSavedObjectMeta\”:{\“properties\”:{\“searchSourceJSON\”:{\“type\”:\“text\”}}},\“optionsJSON\”:{\“type\”:\“text\”},\“panelsJSON\”:{\“type\”:\“text\”},\“refreshInterval\”:{\“properties\”:{\“display\”:{\“type\”:\“keyword\”},\“pause\”:{\“type\”:\“boolean\”},\“section\”:{\“type\”:\“integer\”},\“value\”:{\“type\”:\“integer\”}}},\“timeFrom\”:{\“type\”:\“keyword\”},\“timeRestore\”:{\“type\”:\“boolean\”},\“timeTo\”:{\“type\”:\“keyword\”},\“title\”:{\“type\”:\“text\”},\“uiStateJSON\”:{\“type\”:\“text\”},\“version\”:{\“type\”:\“integer\”}}},\“url\”:{\“properties\”:{\“accessCount\”:{\“type\”:\“long\”},\“accessDate\”:{\“type\”:\“date\”},\“createDate\”:{\“type\”:\“date\”},\“url\”:{\“type\”:\“text\”,\“fields\”:{\“keyword\”:{\“type\”:\“keyword\”,\“ignore_above\”:2048}}}}},\“server\”:{\“properties\”:{\“uuid\”:{\“type\”:\“keyword\”}}},\“kql-telemetry\”:{\“properties\”:{\“optInCount\”:{\“type\”:\“long\”},\“optOutCount\”:{\“type\”:\“long\”}}},\“timelion-sheet\”:{\“properties\”:{\“description\”:{\“type\”:\“text\”},\“hits\”:{\“type\”:\“integer\”},\“kibanaSavedObjectMeta\”:{\“properties\”:{\“searchSourceJSON\”:{\“type\”:\“text\”}}},\“timelion_chart_height\”:{\“type\”:\“integer\”},\“timelion_columns\”:{\“type\”:\“integer\”},\“timelion_interval\”:{\“type\”:\“keyword\”},\“timelion_other_interval\”:{\“type\”:\“keyword\”},\“timelion_rows\”:{\“type\”:\“integer\”},\“timelion_sheet\”:{\“type\”:\“text\”},\“title\”:{\“type\”:\“text\”},\“version\”:{\“type\”:\“integer\”}}}}}},\“settings\”:{\“number_of_shards\”:1,\“auto_expand_replicas\”:\“0-1\”}}",“statusCode”:403,“response”:"{\“error\”:{\“root_cause\”:[{\“type\”:\“cluster_block_exception\”,\“reason\”:\“blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];\”}],\“type\”:\“cluster_block_exception\”,\“reason\”:\“blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];\”},\“status\”:403}"}
2020-06-24 17:58:36.376:
