你好,我也遇到这种问题了,开启了多集群管理模式,然后pod一直 启不来,困扰好几天了,请问解决了吗?
1 client_config.go:615] Neither –kubeconfig nor –master was specified. Using the inClusterConfig. This might not work.
I0804 02:47:49.610058 1 controller-manager.go:428] starting metrics server path /metrics
I0804 02:47:49.660695 1 controller-manager.go:225] Cannot retrieve KubeFedConfig “kube-federation-system/kubefed”: kubefedconfigs.core.kubefed.io “kubefed” not found. Default options will be used.
I0804 02:47:49.660721 1 controller-manager.go:328] Creating KubeFedConfig “kube-federation-system/kubefed” with default values
F0804 02:47:49.676414 1 controller-manager.go:299] Error creating KubeFedConfig “kube-federation-system/kubefed”: Internal error occurred: failed calling webhook “kubefedconfigs.core.kubefed.io”: Post “https://kubefed-admission-webhook.kube-federation-system.svc:443/validate-kubefedconfig?timeout=10s”: x509: certificate signed by unknown authority (possibly because of “crypto/rsa: verification error” while trying to verify candidate authority certificate “kubefed-admission-webhook-ca”)
goroutine 1 [running]:
