Forest-L 刚看到Configmap已经创建成功了,可以kubectl edit configmap
# Please edit the object below. Lines beginning with a '#' will be ignored,
# and an empty file will abort the edit. If an error occurs while saving this file will be
# reopened with the relevant failures.
data:
ks-config.yaml: |
persistence:
storageClass: ""
monitoring: False
endpointIps: 192.168.0.7,192.168.0.8,192.168.0.9
port: 2379
tlsEnable: True
common:
mysqlVolumeSize: 20Gi
minioVolumeSize: 20Gi
etcdVolumeSize: 20Gi
openldapVolumeSize: 2Gi
redisVolumSize: 2Gi
metrics_server:
enabled: False
console:
enableMultiLogin: False # enable/disable multi login
port: 30880
monitoring:
prometheusReplicas: 1
prometheusMemoryRequest: 400Mi
prometheusVolumeSize: 20Gi
grafana:
enabled: False
logging:
enabled: False
elasticsearchMasterReplicas: 1
elasticsearchDataReplicas: 1
logsidecarReplicas: 2
elasticsearchMasterVolumeSize: 4Gi
logMaxAge: 7
elkPrefix: logstash
containersLogMountedPath: ""
kibana:
enabled: False
openpitrix:
enabled: False
devops:
enabled: False
jenkinsMemoryLim: 2Gi
jenkinsMemoryReq: 1500Mi
jenkinsVolumeSize: 8Gi
jenkinsJavaOpts_Xms: 512m
jenkinsJavaOpts_Xmx: 512m
jenkinsJavaOpts_MaxRAM: 2g
sonarqube:
enabled: False
postgresqlVolumeSize: 8Gi
servicemesh:
enabled: False
notification:
enabled: False
alerting:
enabled: False
kind: ConfigMap
annotations:
kubectl.kubernetes.io/last-applied-configuration: |
{"apiVersion":"v1","data":{"ks-config.yaml":"---\n\npersistence:\n storageClass: \"\"\n\netcd:\n monitoring: False\n endpointIps: 192.168.0.7,192.168.0.8,192.168.0.9\n port: 2379\n tlsEnable: True\n\ncommon:\n mysqlVolumeSize: 20Gi\n minioVolumeSize: 20Gi\n etcdVolumeSize: 20Gi\n openldapVolumeSize: 2Gi\n redisVolumSize: 2Gi\n\nmetrics_server:\n enabled: False\n\nconsole:\n enableMultiLogin: False # enable/disable multi login\n port: 30880\n\nmonitoring:\n prometheusReplicas: 1\n prometheusMemoryRequest: 400Mi\n prometheusVolumeSize: 20Gi\n grafana:\n enabled: False\n\nlogging:\n enabled: False\n elasticsearchMasterReplicas: 1\n elasticsearchDataReplicas: 1\n logsidecarReplicas: 2\n elasticsearchMasterVolumeSize: 4Gi\n elasticsearchDataVolumeSize: 20Gi\n logMaxAge: 7\n elkPrefix: logstash\n containersLogMountedPath: \"\"\n kibana:\n enabled: False\n\nopenpitrix:\n enabled: False\n\ndevops:\n enabled: False\n jenkinsMemoryLim: 2Gi\n jenkinsMemoryReq: 1500Mi\n jenkinsVolumeSize: 8Gi\n jenkinsJavaOpts_Xms: 512m\n jenkinsJavaOpts_Xmx: 512m\n jenkinsJavaOpts_MaxRAM: 2g\n sonarqube:\n enabled: False\n postgresqlVolumeSize: 8Gi\n\nservicemesh:\n enabled: False\n\nnotification:\n enabled: False\n\nalerting:\n enabled: False\n"},"kind":"ConfigMap","metadata":{"annotations":{},"name":"ks-installer","namespace":"kubesphere-system"}}
creationTimestamp: "2020-08-31T04:00:42Z"
namespace: kubesphere-system
resourceVersion: "2438"
selfLink: /api/v1/namespaces/kubesphere-system/configmaps/ks-installer
uid: ea13f435-1f8f-4e64-ae81-959b3ecbefd7
