本人英文还可以,希望参与3.0文档的翻译撰写,如何加入,什么流程?
Awesome KubeSphere | KubeSphere 3.0 快速安装入门必读清单
FeynmanK零SK贰SK壹S
cnopens 您加入 KubeSphere 的 Slack 或微信群上详细沟通吧,官网上有入口 https://kubesphere.io/
3.0能继续使用域控吗,升级到3.0后ks-account这个服务就没有了。无法使用,有新的教程或者文档吗?
https://kubesphere.com.cn/docs/installing-on-linux/public-cloud/install-kubesphere-on-ali-ecs/
这个基于阿里云安装的集群节点需要配置nat或者公网IP才可以正常安装是吗?
freemankevinK零S
kubesphere-monitoring-system prometheus-k8s-0 0/3 ContainerCreating 0 12m <none> node2 <none> <none>
kubesphere-monitoring-system prometheus-k8s-1 0/3 ContainerCreating 0 12m <none> node1 <none> <none>
freemankevinK零S
freemankevin 这个地方能将镜像先导入再执行安装吗?prometheus 的镜像名叫什么
FeynmanK零SK贰SK壹S
freemankevin 可以,你去参考 3.0 的离线安装文档,里面也有镜像列表。https://kubesphere.com.cn/en/docs/installing-on-linux/introduction/air-gapped-installation/
freemankevinK零S
Feynman已经导入了,原有的已经删除了,状态还是停留在 ‘ContainerCreating’ ,还有什么其他办法完成这个pod启动过程吗?
freemankevinK零S
Events:
Type Reason Age From Message
Warning FailedMount 58m (x3 over 88m) kubelet, node2 Unable to attach or mount volumes: unmounted volumes=[secret-kube-etcd-client-certs], unattached volumes=[tls-assets prometheus-k8s-db prometheus-k8s-rulefiles-0 secret-kube-etcd-client-certs prometheus-k8s-token-j9qsv config config-out]: timed out waiting for the condition
Warning FailedMount 38m (x7 over 90m) kubelet, node2 Unable to attach or mount volumes: unmounted volumes=[secret-kube-etcd-client-certs], unattached volumes=[prometheus-k8s-token-j9qsv config config-out tls-assets prometheus-k8s-db prometheus-k8s-rulefiles-0 secret-kube-etcd-client-certs]: timed out waiting for the condition
Warning FailedMount 18m (x5 over 79m) kubelet, node2 Unable to attach or mount volumes: unmounted volumes=[secret-kube-etcd-client-certs], unattached volumes=[prometheus-k8s-db prometheus-k8s-rulefiles-0 secret-kube-etcd-client-certs prometheus-k8s-token-j9qsv config config-out tls-assets]: timed out waiting for the condition
Warning FailedMount 9m10s (x8 over 97m) kubelet, node2 Unable to attach or mount volumes: unmounted volumes=[secret-kube-etcd-client-certs], unattached volumes=[config-out tls-assets prometheus-k8s-db prometheus-k8s-rulefiles-0 secret-kube-etcd-client-certs prometheus-k8s-token-j9qsv config]: timed out waiting for the condition
Warning FailedMount 3m48s (x55 over 99m) kubelet, node2 MountVolume.SetUp failed for volume “secret-kube-etcd-client-certs” : secret “kube-etcd-client-certs” not found
JeffK零SK壹S
freemankevin 先检查下报错信息里说的secret configmap 是否存在,如果都存在的话,把当前的pod重启下试试
freemankevinK零S
Jeff 正常都是自动创建的吧??17.9还需要手动创建吗?
JeffK零SK壹S
freemankevin 如果是使用kk安装的kubernetes,会自动创建,如果在已有的k8s集群上安装kubesphere,则需要手动创建
freemankevinK零S
Jeff 还是kk好
FeynmanK零SK贰SK壹S
中文文档目前社区已经完成了 95%,最新的文档请参考 kubesphere.com.cn/docs
