minghaoye
[Pipeline] kubernetesDeploy
Starting Kubernetes deployment
Loading configuration: /home/jenkins/agent/workspace/agent-wanggang/deploy.yml
ERROR: ERROR: java.lang.RuntimeException: io.kubernetes.client.ApiException: java.net.UnknownHostException: apiserver.cluster.local: Name or service not known
hudson.remoting.ProxyException: java.lang.RuntimeException: io.kubernetes.client.ApiException: java.net.UnknownHostException: apiserver.cluster.local: Name or service not known
at com.microsoft.jenkins.kubernetes.wrapper.ResourceManager.handleApiExceptionExceptNotFound(ResourceManager.java:180)
at com.microsoft.jenkins.kubernetes.wrapper.V1ResourceManager$DeploymentUpdater.getCurrentResource(V1ResourceManager.java:205)
at com.microsoft.jenkins.kubernetes.wrapper.V1ResourceManager$DeploymentUpdater.getCurrentResource(V1ResourceManager.java:193)
at com.microsoft.jenkins.kubernetes.wrapper.ResourceManager$ResourceUpdater.createOrApply(ResourceManager.java:93)
at com.microsoft.jenkins.kubernetes.wrapper.KubernetesClientWrapper.handleResource(KubernetesClientWrapper.java:289)
at com.microsoft.jenkins.kubernetes.wrapper.KubernetesClientWrapper.apply(KubernetesClientWrapper.java:256)
at com.microsoft.jenkins.kubernetes.command.DeploymentCommand$DeploymentTask.doCall(DeploymentCommand.java:172)
at com.microsoft.jenkins.kubernetes.command.DeploymentCommand$DeploymentTask.call(DeploymentCommand.java:124)
at com.microsoft.jenkins.kubernetes.command.DeploymentCommand$DeploymentTask.call(DeploymentCommand.java:106)
at hudson.remoting.UserRequest.perform(UserRequest.java:211)
at hudson.remoting.UserRequest.perform(UserRequest.java:54)
at hudson.remoting.Request$2.run(Request.java:369)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at hudson.remoting.Engine$1.lambda$newThread$0(Engine.java:97)
at java.lang.Thread.run(Thread.java:748)
Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to JNLP4-connect connection from 10.32.3.56/10.32.3.56:53484
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1743)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
at hudson.remoting.Channel.call(Channel.java:957)
at hudson.FilePath.act(FilePath.java:1162)
at com.microsoft.jenkins.kubernetes.command.DeploymentCommand.execute(DeploymentCommand.java:68)
at com.microsoft.jenkins.kubernetes.command.DeploymentCommand.execute(DeploymentCommand.java:45)
at com.microsoft.jenkins.azurecommons.command.CommandService.runCommand(CommandService.java:88)
at com.microsoft.jenkins.azurecommons.command.CommandService.execute(CommandService.java:96)
at com.microsoft.jenkins.azurecommons.command.CommandService.executeCommands(CommandService.java:75)
at com.microsoft.jenkins.azurecommons.command.BaseCommandContext.executeCommands(BaseCommandContext.java:77)
at com.microsoft.jenkins.kubernetes.KubernetesDeploy.perform(KubernetesDeploy.java:42)
at com.microsoft.jenkins.azurecommons.command.SimpleBuildStepExecution.run(SimpleBuildStepExecution.java:54)
at com.microsoft.jenkins.azurecommons.command.SimpleBuildStepExecution.run(SimpleBuildStepExecution.java:35)
at org.jenkinsci.plugins.workflow.steps.SynchronousNonBlockingStepExecution.lambda$start$0(SynchronousNonBlockingStepExecution.java:47)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
… 1 more
Caused by: hudson.remoting.ProxyException: io.kubernetes.client.ApiException: java.net.UnknownHostException: apiserver.cluster.local: Name or service not known
at io.kubernetes.client.ApiClient.execute(ApiClient.java:805)
at io.kubernetes.client.apis.AppsV1Api.readNamespacedDeploymentWithHttpInfo(AppsV1Api.java:6940)
at io.kubernetes.client.apis.AppsV1Api.readNamespacedDeployment(AppsV1Api.java:6922)
at com.microsoft.jenkins.kubernetes.wrapper.V1ResourceManager$DeploymentUpdater.getCurrentResource(V1ResourceManager.java:202)
… 16 more
Caused by: hudson.remoting.ProxyException: java.net.UnknownHostException: apiserver.cluster.local: Name or service not known
at java.net.Inet4AddressImpl.lookupAllHostAddr(Native Method)
at java.net.InetAddress$2.lookupAllHostAddr(InetAddress.java:929)
at java.net.InetAddress.getAddressesFromNameService(InetAddress.java:1324)
at java.net.InetAddress.getAllByName0(InetAddress.java:1277)
at java.net.InetAddress.getAllByName(InetAddress.java:1193)
at java.net.InetAddress.getAllByName(InetAddress.java:1127)
at com.squareup.okhttp.Dns$1.lookup(Dns.java:39)
at com.squareup.okhttp.internal.http.RouteSelector.resetNextInetSocketAddress(RouteSelector.java:175)
at com.squareup.okhttp.internal.http.RouteSelector.nextProxy(RouteSelector.java:141)
at com.squareup.okhttp.internal.http.RouteSelector.next(RouteSelector.java:83)
at com.squareup.okhttp.internal.http.StreamAllocation.findConnection(StreamAllocation.java:174)
at com.squareup.okhttp.internal.http.StreamAllocation.findHealthyConnection(StreamAllocation.java:126)
at com.squareup.okhttp.internal.http.StreamAllocation.newStream(StreamAllocation.java:95)
at com.squareup.okhttp.internal.http.HttpEngine.connect(HttpEngine.java:281)
at com.squareup.okhttp.internal.http.HttpEngine.sendRequest(HttpEngine.java:224)
at com.squareup.okhttp.Call.getResponse(Call.java:286)
at com.squareup.okhttp.Call$ApplicationInterceptorChain.proceed(Call.java:243)
at com.squareup.okhttp.Call.getResponseWithInterceptorChain(Call.java:205)
at com.squareup.okhttp.Call.execute(Call.java:80)
at io.kubernetes.client.ApiClient.execute(ApiClient.java:801)
… 19 more
Api call failed with code 0, detailed message: null
[Pipeline] }
[Pipeline] // container
[Pipeline] }
[Pipeline] // stage
[Pipeline] }
[Pipeline] // node
[Pipeline] }
[Pipeline] // podTemplate
[Pipeline] End of Pipeline
ERROR: Kubernetes deployment ended with HasError
Finished: FAILURE 现在报这个错
