5个虚拟机,3个master + 2个woker。
master:Centos7.9,10C/16G
woker:Centos7.9,20C/32G
Client Version: version.Info{Major:“1”, Minor:“21”, GitVersion:“v1.21.14”, GitCommit:“0f77da5bd4809927e15d1658fb4aa8f13ad890a5”, GitTreeState:“clean”, BuildDate:“2022-06-15T14:17:29Z”, GoVersion:“go1.16.15”, Compiler:“gc”, Platform:“linux/amd64”}
Server Version: version.Info{Major:“1”, Minor:“21”, GitVersion:“v1.21.14”, GitCommit:“0f77da5bd4809927e15d1658fb4aa8f13ad890a5”, GitTreeState:“clean”, BuildDate:“2022-06-15T14:11:36Z”, GoVersion:“go1.16.15”, Compiler:“gc”, Platform:“linux/amd64”}
Version: 20.10.2
API version: 1.41
Go version: go1.13.15
Git commit: 2291f61
Built: Mon Dec 28 16:17:48 2020
Experimental: true
Version: 20.10.2
Git commit: 8891c58
Built: Mon Dec 28 16:16:13 2020
Version: 1.6.21
GitCommit: 3dce8eb055cbb6872793272b4f20ed16117344f8
Version: 1.1.7
GitCommit: v1.1.7-0-g860f061
Version: 0.19.0
GitCommit: de40ad0
v3.3.2 在线安装,在已有K8s上安装。
安装devops插件时,devops-jenins容器报以下错误:
Events:
Type Reason Age From Message
Normal Scheduled 4m2s default-scheduler Successfully assigned kubesphere-devops-system/devops-jenkins-7456b84c-wcj75 to k8s-node1
Normal Pulled 4m32s kubelet Container image “kubesphere/ks-jenkins:v3.3.0-2.319.1” already present on machine
Normal Created 4m30s kubelet Created container copy-default-config
Normal Started 4m28s kubelet Started container copy-default-config
Normal Pulled 4m21s kubelet Container image “kubesphere/ks-jenkins:v3.3.0-2.319.1” already present on machine
Normal Created 4m19s kubelet Created container devops-jenkins
Normal Started 4m18s kubelet Started container devops-jenkins
Warning Unhealthy 3m4s (x19 over 3m40s) kubelet Readiness probe failed: Get “http://10.244.36.124:8080/login”: dial tcp 10.244.36.124:8080: connect: connection refused
