• DevOps
  • AWS的ESK启用插件kubesphere Devops异常 namespaces "kubesphere-devops-worker" not found
laozhou333 KubeSphere 是什么版本的 ?执行下 helm ls -A 看下 DevOps release 有没有安装?
hi,请问我该如何解决这个问题,期望得到回复
    laozhou333 从上面截图发现 DevOps release 没有安装;可以参考 26楼 ,再尝试删掉 status.devops ,然后修改下 devops 下的任意配置触发下 DevOps 安装试试 ;
    已经尝试很多次了,如果不手动创建namespace会报错 kubesphere-devops-worker not found,手动创建的情况下安装完成,但devops导航栏为空,实际并未安装
      laozhou333 执行下面命令 kubectl -n kubesphere-system exec -it $(kubectl get pod -n kubesphere-system -l app=ks-installer -o jsonpath='{.items[0].metadata.name}') -- sh
      进入 ks-installer 容器,然后进到目录 /kubesphere/results/devops/devops/job_events ,看下这里的 json 文件能不能找到原因,比如:cat 140-ad4ba4a6-7c1e-4fb3-b9a7-7eb558882df4.json | jq
      是ks-install版本问题吗?我cp 2.1版本后是有两个tgz的包,曾怀疑是0.2.1的包未生效,尝试删除0.1.19但对0.1.19也有依赖
      -rw-r–r– 1 root root 66841 May 25 2023 ks-devops-0.1.19.tgz
      -rw-r–r– 1 501 dialout 71149 Mar 24 14:26 ks-devops-0.2.1.tgz
        cat 140-364142e0-4652-4c30-ae36-addf046cffbd.json |jq
        “uuid”: “364142e0-4652-4c30-ae36-addf046cffbd”,
        “counter”: 140,
        “stdout”: "",
        “start_line”: 170,
        “end_line”: 170,
        “runner_ident”: “devops”,
        “event”: “runner_on_start”,
        “pid”: 30139,
        “created”: “2024-03-25T03:57:49.481470”,
        “parent_uuid”: “2eb11b1e-62d8-f385-6410-000000000042”,
        “event_data”: {
        "playbook": "/kubesphere/playbooks/devops.yaml",
        "playbook_uuid": "49c7852d-3774-498c-8c07-bd2a93617d4b",
        "play": "localhost",
        "play_uuid": "2eb11b1e-62d8-f385-6410-000000000005",
        "play_pattern": "localhost",
        "task": "ks-devops | Upgrading or installing ks-devops",
        "task_uuid": "2eb11b1e-62d8-f385-6410-000000000042",
        "task_action": "shell",
        "resolved_action": "shell",
        "task_args": "",
        "task_path": "/kubesphere/installer/roles/ks-devops/tasks/main.yaml:191",
        "role": "ks-devops",
        "host": "localhost",
        "uuid": "364142e0-4652-4c30-ae36-addf046cffbd"
        查找了/kubesphere/results/devops/devops/job_events目录下所有包含"error"的文件,如图,只有Error from server (NotFound): namespaces \“kubesphere-devops-system\” not found"
        升级kubesphere版本可以解决吗?
        laozhou333 是的,你的怀疑是对的,ks 3.3.2 用的 0.1.19 版本的 ks-devops ; ks 3.4.0 用的 0.2.1 版本的;
        你的环境是 ks 3.3.2 ,所以应该用 0.1.19 版本的:ks-devops-0.1.19.tgz
        用这个 0.1.19 版本的应该就可以了。
