云主机
将 kubectl version
命令执行结果贴在下方
Client Version: version.Info{Major:“1”, Minor:“23”, GitVersion:“v1.23.17”, GitCommit:“953be8927218ec8067e1af2641e540238ffd7576”, GitTreeState:“clean”, BuildDate:“2023-02-22T13:34:27Z”, GoVersion:“go1.19.6”, Compiler:“gc”, Platform:“linux/amd64”}
Server Version: version.Info{Major:“1”, Minor:“23”, GitVersion:“v1.23.17”, GitCommit:“953be8927218ec8067e1af2641e540238ffd7576”, GitTreeState:“clean”, BuildDate:“2023-02-22T13:27:46Z”, GoVersion:“go1.19.6”, Compiler:“gc”, Platform:“linux/amd64”}
将 docker version
/ crictl version
/ nerdctl version
结果贴在下方
Client:
Version: 20.10.8
API version: 1.41
Go version: go1.16.6
Git commit: 3967b7d
Experimental: true
Version: 20.10.8
Git commit: 75249d8
Version: v1.4.9
Version: 1.0.1
GitCommit: v1.0.1-0-g4144b638
Version: 0.19.0
GitCommit: de40ad0
kk安装3.4
因为项目环境需要开启本机防火墙
关闭防火墙后可以访问30880 打开防火墙后 允许访问30880端口 但还是访问不了
[root@ks-master-01 ~]# curl 192.168.72.36:30880
Redirecting to <a href=“/login”>/login</a>.[root@ks-master-01 ~]# curl 192.168.72.36:30880
curl: (7) Failed connect to 192.168.72.36:30880; No route to host
关闭防火墙后就可以 是还需要开放什么端口吗
求大佬来看看解答一下
