3.4.1外接ES,启动报错
DehaoChengK零S
这类出现这个报错是因为你同时开启了opensearch以及es,所以会报这个错误
- 已编辑
DehaoCheng
如果开启opensearch,就是把日志传到opensearch
如果开启es,就是把日志传到es,
这两者只能二选一,
安装成功后其实都是可以在kubesphere里面查询审计、容器等日志,是这个意思吗?
DehaoChengK零S
sword913 是的,当然传输日志可以都发送到es或者opensearch,但是查询只能在一个收集端里查询(opensearch或者es),所以只能二选一。无论opensearch或者es,只要安装了一个都可以在里面查询日志信息
- 已编辑
- 已编辑
- 已编辑
- 已编辑
- 已编辑
DehaoChengK零S
你是外置es?https://kubesphere.io/zh/blogs/kubesphere-elasticsearch/ 参考一下这个。另外你把kubesphere-config这个configmap以及clusterconfigration发一下,敏感信息打码
DehaoChengK零S
至于fluentbit的警告,你可以将output的buffer改大一点
- 已编辑
ClusterConfiguration的配置如下:
kind: ClusterConfiguration
annotations:
kubectl.kubernetes.io/last-applied-configuration: >
{"apiVersion":"installer.kubesphere.io/v1alpha1","kind":"ClusterConfiguration","metadata":{"annotations":{},"labels":{"version":"v3.4.1"},"name":"ks-installer","namespace":"kubesphere-system"},"spec":{"alerting":{"enabled":true},"auditing":{"enabled":true},"authentication":{"jwtSecret":""},"common":{"core":{"console":{"enableMultiLogin":true,"port":30880,"type":"NodePort"}},"es":{"basicAuth":{"enabled":false,"password":"","username":""},"elkPrefix":"dev","enabled":true,"externalElasticsearchHost":"10.203.98.104","externalElasticsearchPort":"9200","logMaxAge":7},"gpu":{"kinds":[{"default":true,"resourceName":"nvidia.com/gpu","resourceType":"GPU"}]},"minio":{"volumeSize":"20Gi"},"monitoring":{"GPUMonitoring":{"enabled":false},"endpoint":"http://prometheus-operated.kubesphere-monitoring-system.svc:9090"},"openldap":{"enabled":false,"volumeSize":"2Gi"},"opensearch":{"basicAuth":{"enabled":true,"password":"admin","username":"admin"},"dashboard":{"enabled":false},"enabled":false,"externalOpensearchHost":"","externalOpensearchPort":"","logMaxAge":7,"opensearchPrefix":"whizard"},"redis":{"enableHA":false,"enabled":false,"volumeSize":"2Gi"}},"devops":{"enabled":true,"jenkinsCpuLim":1,"jenkinsCpuReq":0.5,"jenkinsMemoryLim":"4Gi","jenkinsMemoryReq":"4Gi","jenkinsVolumeSize":"16Gi"},"edgeruntime":{"enabled":false,"kubeedge":{"cloudCore":{"cloudHub":{"advertiseAddress":[""]},"service":{"cloudhubHttpsNodePort":"30002","cloudhubNodePort":"30000","cloudhubQuicNodePort":"30001","cloudstreamNodePort":"30003","tunnelNodePort":"30004"}},"enabled":false,"iptables-manager":{"enabled":true,"mode":"external"}}},"etcd":{"endpointIps":"10.203.99.101,10.203.99.102,10.203.99.103","monitoring":true,"port":2379,"tlsEnable":true},"events":{"enabled":true,"ruler":{"enabled":true,"replicas":2}},"gatekeeper":{"enabled":false},"logging":{"containerruntime":"containerd","enabled":true,"logsidecar":{"enabled":true,"replicas":2}},"metrics_server":{"enabled":true},"monitoring":{"gpu":{"nvidia_dcgm_exporter":{"enabled":false}},"node_exporter":{"port":9100},"storageClass":""},"multicluster":{"clusterRole":"none"},"network":{"ippool":{"type":"calico"},"networkpolicy":{"enabled":true},"topology":{"type":"weave-scope"}},"openpitrix":{"store":{"enabled":false}},"persistence":{"storageClass":""},"servicemesh":{"enabled":true,"istio":{"components":{"cni":{"enabled":false},"ingressGateways":[{"enabled":false,"name":"istio-ingressgateway"}]}}},"terminal":{"timeout":600}}}
version: v3.4.1
namespace: kubesphere-system
alerting:
enabled: true
auditing:
enabled: true
authentication:
jwtSecret: ''
common:
core:
console:
enableMultiLogin: true
port: 30880
type: NodePort
es:
basicAuth:
enabled: false
password: ''
username: ''
elkPrefix: dev
enabled: true
externalElasticsearchHost: 10.203.98.104
externalElasticsearchPort: '9200'
logMaxAge: 7
gpu:
kinds:
- default: true
resourceName: nvidia.com/gpu
resourceType: GPU
minio:
volumeSize: 20Gi
monitoring:
GPUMonitoring:
enabled: false
endpoint: 'http://prometheus-operated.kubesphere-monitoring-system.svc:9090'
openldap:
enabled: false
volumeSize: 2Gi
opensearch:
basicAuth:
enabled: true
password: admin
username: admin
dashboard:
enabled: false
enabled: false
externalOpensearchHost: ''
externalOpensearchPort: ''
logMaxAge: 7
opensearchPrefix: whizard
redis:
enableHA: false
enabled: false
volumeSize: 2Gi
devops:
enabled: true
jenkinsCpuLim: 1
jenkinsCpuReq: 0.5
jenkinsMemoryLim: 4Gi
jenkinsMemoryReq: 4Gi
jenkinsVolumeSize: 16Gi
edgeruntime:
enabled: false
kubeedge:
cloudCore:
cloudHub:
advertiseAddress:
service:
cloudhubHttpsNodePort: '30002'
cloudhubNodePort: '30000'
cloudhubQuicNodePort: '30001'
cloudstreamNodePort: '30003'
tunnelNodePort: '30004'
enabled: false
iptables-manager:
enabled: true
mode: external
endpointIps: '10.203.99.101,10.203.99.102,10.203.99.103'
monitoring: true
port: 2379
tlsEnable: true
events:
enabled: true
ruler:
enabled: true
replicas: 2
gatekeeper:
enabled: false
logging:
containerruntime: containerd
enabled: true
logsidecar:
enabled: true
replicas: 2
metrics_server:
enabled: true
monitoring:
gpu:
nvidia_dcgm_exporter:
enabled: false
node_exporter:
port: 9100
storageClass: ''
multicluster:
clusterRole: none
network:
ippool:
type: calico
networkpolicy:
enabled: true
topology:
type: weave-scope
openpitrix:
store:
enabled: false
persistence:
storageClass: ''
servicemesh:
enabled: true
istio:
components:
cni:
enabled: false
ingressGateways:
- enabled: false
terminal:
timeout: 600
status:
alerting:
enabledTime: '2023-12-26T14:55:05CST'
status: enabled
auditing:
enabledTime: '2023-12-26T14:42:15CST'
status: enabled
clusterId: 9563212c-01b3-48a0-8aec-74b230735b61-1703573825
core:
enabledTime: '2023-12-26T14:41:44CST'
status: enabled
version: v3.4.1
events:
enabledTime: '2023-12-26T14:42:19CST'
ruler:
enabledTime: '2023-12-26T14:42:20CST'
status: enabled
status: enabled
fluentbit:
enabledTime: '2023-12-26T14:40:31CST'
status: enabled
logging:
status: enabled
metricsServer:
enabledTime: '2023-12-26T14:38:28CST'
status: enabled
minio:
enabledTime: '2023-12-26T14:40:18CST'
status: enabled
monitoring:
enabledTime: '2023-12-26T14:54:59CST'
status: enabled
network:
topology:
enabledTime: '2023-12-26T14:41:58CST'
status: enabled
openldap:
enabledTime: '2023-12-26T14:38:59CST'
status: enabled
servicemesh:
enabledTime: '2023-12-26T14:43:12CST'
status: enabled
- 已编辑
kubesphere-v3.4.1.yaml的配置如下
kind: Cluster
hosts:
- {name: k8s-master01, address: 10.203.99.101, internalAddress: 10.203.99.101, user: root, password: "yoening@123"}
- {name: k8s-master02, address: 10.203.99.102, internalAddress: 10.203.99.102, user: root, password: "yoening@123"}
- {name: k8s-master03, address: 10.203.99.103, internalAddress: 10.203.99.103, user: root, password: "yoening@123"}
- {name: k8s-node01, address: 10.203.99.104, internalAddress: 10.203.99.104, user: root, password: "yoening@123"}
- {name: k8s-node02, address: 10.203.99.105, internalAddress: 10.203.99.105, user: root, password: "yoening@123"}
- {name: k8s-node03, address: 10.203.99.106, internalAddress: 10.203.99.106, user: root, password: "yoening@123"}
roleGroups:
- k8s-master01
- k8s-master02
- k8s-master03
control-plane:
- k8s-master01
- k8s-master02
- k8s-master03
worker:
- k8s-node01
- k8s-node02
- k8s-node03
controlPlaneEndpoint:
## internalLoadbalancer: haproxy
domain: lb.kubesphere.local
address: 10.203.99.107
port: 16443
kubernetes:
version: v1.26.5
clusterName: cluster.local
autoRenewCerts: true
containerManager: containerd
type: kubekey
network:
plugin: calico
kubePodsCIDR: 172.17.64.0/18
kubeServiceCIDR: 172.17.0.0/18
multusCNI:
enabled: false
registry:
privateRegistry: ""
namespaceOverride: ""
registryMirrors: []
insecureRegistries: []
addons: []
version: v3.4.1
persistence:
storageClass: ""
authentication:
jwtSecret: ""
local_registry: ""
# dev_tag: ""
monitoring: true
endpointIps: localhost
port: 2379
tlsEnable: true
common:
core:
console:
port: 30880
type: NodePort
# apiserver:
# resources: {}
# controllerManager:
# resources: {}
redis:
enabled: false
enableHA: false
volumeSize: 2Gi
openldap:
enabled: false
volumeSize: 2Gi
minio:
volumeSize: 20Gi
monitoring:
# type: external
GPUMonitoring:
enabled: false
gpu:
kinds:
- resourceName: "nvidia.com/gpu"
resourceType: "GPU"
default: true
es:
# master:
# volumeSize: 4Gi
# replicas: 1
# resources: {}
# data:
# volumeSize: 20Gi
# replicas: 1
# resources: {}
enabled: true
logMaxAge: 7
elkPrefix: dev
basicAuth:
enabled: false
username: ""
password: ""
externalElasticsearchHost: "10.203.98.104"
externalElasticsearchPort: "9200"
opensearch:
# master:
# volumeSize: 4Gi
# replicas: 1
# resources: {}
# data:
# volumeSize: 20Gi
# replicas: 1
# resources: {}
enabled: false
logMaxAge: 7
basicAuth:
enabled: true
username: "admin"
password: "admin"
externalOpensearchHost: ""
externalOpensearchPort: ""
dashboard:
enabled: false
alerting:
enabled: true
# thanosruler:
# replicas: 1
# resources: {}
auditing:
enabled: true
# operator:
# resources: {}
# webhook:
# resources: {}
devops:
enabled: true
jenkinsCpuReq: 0.5
jenkinsCpuLim: 1
events:
enabled: true
# operator:
# resources: {}
# exporter:
# resources: {}
ruler:
enabled: true
replicas: 2
# resources: {}
logging:
enabled: true
logsidecar:
enabled: true
replicas: 2
# resources: {}
metrics_server:
enabled: true
monitoring:
storageClass: ""
node_exporter:
port: 9100
# resources: {}
# kube_rbac_proxy:
# resources: {}
# kube_state_metrics:
# resources: {}
# prometheus:
# replicas: 1
# volumeSize: 20Gi
# resources: {}
# operator:
# resources: {}
# alertmanager:
# replicas: 1
# resources: {}
# notification_manager:
# resources: {}
# operator:
# resources: {}
# proxy:
# resources: {}
gpu:
enabled: false
# resources: {}
multicluster:
clusterRole: none
network:
networkpolicy:
enabled: true
ippool:
type: calico
topology:
type: weave-scope
openpitrix:
store:
enabled: false
servicemesh:
enabled: true
istio:
components:
ingressGateways:
- name: istio-ingressgateway
enabled: false
cni:
enabled: false
edgeruntime:
enabled: false
kubeedge:
enabled: false
cloudCore:
cloudHub:
advertiseAddress:
service:
cloudhubNodePort: "30000"
cloudhubQuicNodePort: "30001"
cloudstreamNodePort: "30003"
tunnelNodePort: "30004"
# resources: {}
# hostNetWork: false
iptables-manager:
enabled: true
mode: "external"
# resources: {}
# edgeService:
# resources: {}
gatekeeper:
enabled: false
# controller_manager:
# resources: {}
# audit:
# resources: {}
terminal:
timeout: 600
config 配置如下:
[root@k8s-master01 kubekey]# kubectl get configmap kubesphere-config -n kubesphere-system -o yaml
data:
kubesphere.yaml: |
authentication:
authenticateRateLimiterMaxTries: 10
authenticateRateLimiterDuration: 10m0s
loginHistoryRetentionPeriod: 168h
maximumClockSkew: 10s
multipleLogin: True
kubectlImage: kubesphere/kubectl:v1.22.0
jwtSecret: "1W9EADsHAmqMJ8szthOeXPiTQ51KfHfh"
oauthOptions:
clients:
- name: kubesphere
secret: kubesphere
redirectURIs:
ldap:
host: openldap.kubesphere-system.svc:389
managerDN: cn=admin,dc=kubesphere,dc=io
managerPassword: admin
userSearchBase: ou=Users,dc=kubesphere,dc=io
groupSearchBase: ou=Groups,dc=kubesphere,dc=io
s3:
endpoint: http://minio.kubesphere-system.svc:9000
region: us-east-1
disableSSL: True
forcePathStyle: True
accessKeyID: openpitrixminioaccesskey
secretAccessKey: openpitrixminiosecretkey
bucket: s2i-binaries
network:
enableNetworkPolicy: true
ippoolType: calico
weaveScopeHost: weave-scope-app.weave
devops:
host: http://devops-jenkins.kubesphere-devops-system.svc/
username: admin
password: eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJlbWFpbCI6ImFkbWluQGt1YmVzcGhlcmUuaW8iLCJ1c2VybmFtZSI6ImFkbWluIiwidG9rZW5fdHlwZSI6InN0YXRpY190b2tlbiJ9.AVHKZgFyYk_DQAV2rgPybZqnXJBs5EyVgQuNrg5SxWI
maxConnections: 100
endpoint: http://devops-apiserver.kubesphere-devops-system:9090
servicemesh:
istioPilotHost: http://istiod.istio-system.svc:8080/version
jaegerQueryHost: http://jaeger-query.istio-system.svc:16686
servicemeshPrometheusHost: http://prometheus-k8s.kubesphere-monitoring-system.svc:9090
kialiQueryHost: http://kiali.istio-system:20001
multicluster:
clusterRole: none
monitoring:
enableGPUMonitoring: false
gpu:
kinds:
- resourceName: nvidia.com/gpu
resourceType: GPU
default: True
notification:
endpoint: http://notification-manager-svc.kubesphere-monitoring-system.svc:19093
logging:
host: http://10.203.98.104:9200
basicAuth: True
username: "admin"
password: "admin"
indexPrefix: ks-whizard-logging
events:
basicAuth: True
username: "admin"
password: "admin"
indexPrefix: ks-whizard-events
auditing:
enable: true
webhookURL: https://kube-auditing-webhook-svc.kubesphere-logging-system.svc:6443/audit/webhook/event
basicAuth: True
username: "admin"
password: "admin"
indexPrefix: ks-whizard-auditing
alerting:
prometheusEndpoint: http://prometheus-operated.kubesphere-monitoring-system.svc:9090
thanosRulerEndpoint: http://thanos-ruler-operated.kubesphere-monitoring-system.svc:10902
thanosRuleResourceLabels: thanos-ruler=kubesphere,role=alert-rules
terminal:
image: alpine:3.14
timeout: 600
gateway:
watchesPath: /var/helm-charts/watches.yaml
repository: kubesphere/nginx-ingress-controller
tag: v1.3.1
namespace: kubesphere-controls-system
kind: ConfigMap
annotations:
kubectl.kubernetes.io/last-applied-configuration: |
{"apiVersion":"v1","data":{"kubesphere.yaml":"authentication:\n authenticateRateLimiterMaxTries: 10\n authenticateRateLimiterDuration: 10m0s\n loginHistoryRetentionPeriod: 168h\n maximumClockSkew: 10s\n multipleLogin: True\n kubectlImage: kubesphere/kubectl:v1.22.0\n jwtSecret: \"1W9EADsHAmqMJ8szthOeXPiTQ51KfHfh\"\n oauthOptions:\n clients:\n - name: kubesphere\n secret: kubesphere\n redirectURIs:\n - '*'\nldap:\n host: openldap.kubesphere-system.svc:389\n managerDN: cn=admin,dc=kubesphere,dc=io\n managerPassword: admin\n userSearchBase: ou=Users,dc=kubesphere,dc=io\n groupSearchBase: ou=Groups,dc=kubesphere,dc=io\ns3:\n endpoint: http://minio.kubesphere-system.svc:9000\n region: us-east-1\n disableSSL: True\n forcePathStyle: True\n accessKeyID: openpitrixminioaccesskey\n secretAccessKey: openpitrixminiosecretkey\n bucket: s2i-binaries\nnetwork:\n enableNetworkPolicy: true\n ippoolType: calico\n weaveScopeHost: weave-scope-app.weave\ndevops:\n host: http://devops-jenkins.kubesphere-devops-system.svc/\n username: admin\n password: eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJlbWFpbCI6ImFkbWluQGt1YmVzcGhlcmUuaW8iLCJ1c2VybmFtZSI6ImFkbWluIiwidG9rZW5fdHlwZSI6InN0YXRpY190b2tlbiJ9.AVHKZgFyYk_DQAV2rgPybZqnXJBs5EyVgQuNrg5SxWI\n maxConnections: 100\n endpoint: http://devops-apiserver.kubesphere-devops-system:9090\nservicemesh:\n istioPilotHost: http://istiod.istio-system.svc:8080/version\n jaegerQueryHost: http://jaeger-query.istio-system.svc:16686\n servicemeshPrometheusHost: http://prometheus-k8s.kubesphere-monitoring-system.svc:9090\n kialiQueryHost: http://kiali.istio-system:20001\nmulticluster:\n clusterRole: none\nmonitoring:\n endpoint: http://prometheus-operated.kubesphere-monitoring-system.svc:9090\n enableGPUMonitoring: false\ngpu:\n kinds:\n - resourceName: nvidia.com/gpu\n resourceType: GPU\n default: True\nnotification:\n endpoint: http://notification-manager-svc.kubesphere-monitoring-system.svc:19093\nlogging:\n host: http://10.203.98.104:9200\n basicAuth: True\n username: \"admin\"\n password: \"admin\"\n indexPrefix: ks-whizard-logging\nevents:\n host: http://10.203.98.104:9200\n basicAuth: True\n username: \"admin\"\n password: \"admin\"\n indexPrefix: ks-whizard-events\nauditing:\n enable: true\n webhookURL: https://kube-auditing-webhook-svc.kubesphere-logging-system.svc:6443/audit/webhook/event\n host: http://10.203.98.104:9200\n basicAuth: True\n username: \"admin\"\n password: \"admin\"\n indexPrefix: ks-whizard-auditing\nalerting:\n prometheusEndpoint: http://prometheus-operated.kubesphere-monitoring-system.svc:9090\n thanosRulerEndpoint: http://thanos-ruler-operated.kubesphere-monitoring-system.svc:10902\n thanosRuleResourceLabels: thanos-ruler=kubesphere,role=alert-rules\n\n\nterminal:\n image: alpine:3.14\n timeout: 600\ngateway:\n watchesPath: /var/helm-charts/watches.yaml\n repository: kubesphere/nginx-ingress-controller\n tag: v1.3.1\n namespace: kubesphere-controls-system\n"},"kind":"ConfigMap","metadata":{"annotations":{},"name":"kubesphere-config","namespace":"kubesphere-system"}}
creationTimestamp: "2023-12-26T06:55:17Z"
resourceVersion: "7586"
uid: 0c183d51-ae2e-4e2c-bc71-75878a08b2e9
另外我的外部ES是没有设置账号密码的,可以直接使用9200免密码登录
DehaoChengK零S
logging:
basicAuth: True
username: "admin"
password: "admin"
events:
basicAuth: True
username: "admin"
password: "admin"
auditing:
enable: true
basicAuth: True
username: "admin"
password: "admin"
你把kubesphere-config中的这些配置删除一下,这里默认引用了opensearch的配置,没有加载进es的配置。改成类似
events:
host: http://xxx:9200
indexPrefix: ks-dev-events
就可以了,其余修改类似,然后重启ks-apiserver。
DehaoChengK零S
然后看看自定义资源定义里的output,看一下配置,如果有也需要删除相应字段,如果你拿不准,可以发出来看看
- 已编辑
也使用 kubectl -n kubesphere-system rollout restart deploy ks-apiserver
重启后多了个es的pod:如下图:
但是ES里面没有新创建索引(我在config里面换了个indexPrefix名字),同样kubesphere也没有日志
盼回复
