• DevOps
  • 集群部署的kubepehere使用devops的流水线卡住
例如:虚拟机,Centos7.9,4C/16G三台
Client Version: version.Info{Major:"1", Minor:"22", GitVersion:"v1.22.12", GitCommit:"b058e1760c79f46a834ba59bd7a3486ecf28237d", GitTreeState:"clean", BuildDate:"2022-07-13T14:59:18Z", GoVersion:"go1.16.15", Compiler:"gc", Platform:"linux/amd64"}
Server Version: version.Info{Major:"1", Minor:"22", GitVersion:"v1.22.12", GitCommit:"b058e1760c79f46a834ba59bd7a3486ecf28237d", GitTreeState:"clean", BuildDate:"2022-07-13T14:53:39Z", GoVersion:"go1.16.15", Compiler:"gc", Platform:"linux/amd64"}
Client:
Version: 24.0.6
API version: 1.43
Go version: go1.20.7
Git commit: ed223bc
Built: Mon Sep 4 12:30:51 2023
Version: 24.0.6
API version: 1.43 (minimum version 1.12)
Git commit: 1a79695
Built: Mon Sep 4 12:32:17 2023
Version: v1.7.3
GitCommit: 7880925980b188f4c97b462f709d0db8e8962aff
Version: 1.1.9
GitCommit: v1.1.9-0-gccaecfc
Version: 0.19.0
GitCommit: de40ad0
v3.4.1。在线安装。使用kk安装。
devops流水线无法启动
Started by user admin
[Pipeline] Start of Pipeline
[Pipeline] echo
[WARNING] containerTemplate option is deprecated, use yaml syntax to define containers.
[Pipeline] podTemplate
[Pipeline] {
[Pipeline] node
Created Pod: kubernetes kubesphere-devops-worker/testhwcvv-s-1-75l5l-fmq9h-52z6h
[Warning][kubesphere-devops-worker/testhwcvv-s-1-75l5l-fmq9h-52z6h][FailedScheduling] 0/3 nodes are available: 1 node(s) had taint {node-role.kubernetes.io/master: }, that the pod didn't tolerate, 2 Insufficient cpu.
Still waiting to schedule task
‘testhwcvv-s-1-75l5l-fmq9h-52z6h’ is offline
jenkins截图
流水线是用maven模板创建的
pipeline {
agent {
kubernetes {
inheritFrom 'maven'
containerTemplate {
name 'maven'
image 'maven:3.8.4-jdk-11'
stages {
stage('Clone repository') {
steps {
checkout([$class: 'GitSCM', branches: [[name: 'master']],
extensions: [[$class: 'CloneOption', depth: 1, shallow: true]], userRemoteConfigs: [[url: 'https://github.com/kubesphere-sigs/demo-java']]
stage('Run compile') {
steps {
container('maven') {
sh 'mvn compile'
stage('Run test') {
steps {
sh 'mvn clean test'
stage('Run build') {
steps {
sh 'mvn package'
stage('Archive artifacts') {
steps {
archiveArtifacts(artifacts: 'target/*.jar', followSymlinks: false)
之前allinone部署是可以的,这次换集群部署jenkins就出问题了
    mayadebi 日志里面提示了啊[Warning][kubesphere-devops-worker/testhwcvv-s-1-75l5l-fmq9h-52z6h][FailedScheduling] ↉ nodes are available: 1 node(s) had taint {node-role.kubernetes.io/master: }, that the pod didn’t tolerate, 2 Insufficient cpu.
    主节点设置了不能调度,其它两个节点cpu资源不足,pod调度不了
    mayadebi 运行流水线时,jenkins 会创建一个 agent pod 来运行,上面的报错提示:master 节点禁止调度,worker 节点的 CPU 不足导致无法创建 agent pod ;可以尝试增加 worker 节点的资源配置来解决此问题;
