方便在环境上执行一下这个命令, 然后把这个t.yaml文件传上来么, 应该比较大, 传附件
kubectl get helmrepos.application.kubesphere.io -o yaml > t.yaml
redscholar 那好像只是个告警,并不会对ks-apiserver有影响,我也升级到k8s 到1.23,但还是报错提示Observed a panic: “invalid memory address or nil pointer dereference” (runtime error: invalid memory address or nil pointer dereference)
redscholar 我的报错没有这个 v2
访问不了, 文件不存在
kinghu88 我的报错和你这个基本一致,无法启动怎么办?
文件下载到了, 我调试看下,
临时解决办法, 可以把
kubectl delete helmrepos.application.kubesphere.io xxx(
bitnami源的名称)
试一下
W0808 16:59:24.533011 1 client_config.go:618] Neither --kubeconfig nor --master was specifie
W0808 16:59:24.533903 1 client_config.go:618] Neither --kubeconfig nor --master was specifie
W0808 16:59:24.540581 1 metricsserver.go:238] Metrics API not available.
I0808 16:59:24.543659 1 interface.go:50] start helm repo informer
I0808 16:59:24.779808 1 apiserver.go:428] Start cache objects
E0808 16:59:26.480827 1 runtime.go:79] Observed a panic: "invalid memory address or nil poin
goroutine 936 [running]:
k8s.io/apimachinery/pkg/util/runtime.logPanic({0x3919e80?, 0x6c18e40})
/workspace/vendor/k8s.io/apimachinery/pkg/util/runtime/runtime.go:75 +0x99
k8s.io/apimachinery/pkg/util/runtime.HandleCrash({0x0, 0x0, 0xc0002a8690?})
/workspace/vendor/k8s.io/apimachinery/pkg/util/runtime/runtime.go:49 +0x75
panic({0x3919e80, 0x6c18e40})
/usr/local/go/src/runtime/panic.go:884 +0x212
kubesphere.io/kubesphere/pkg/simple/client/openpitrix/helmrepoindex.HelmVersionWrapper.GetName(...
/workspace/pkg/simple/client/openpitrix/helmrepoindex/load_package.go:48
kubesphere.io/kubesphere/pkg/utils/reposcache.(*cachedRepos).addRepo(0xc0002a8690, 0xc001d40a28, 0
/workspace/pkg/utils/reposcache/repo_cahes.go:272 +0xbcb
kubesphere.io/kubesphere/pkg/utils/reposcache.(*cachedRepos).AddRepo(0xc0002a8690, 0xc0001685a0?)
/workspace/pkg/utils/reposcache/repo_cahes.go:194 +0x7c
kubesphere.io/kubesphere/pkg/models/openpitrix.NewOpenpitrixOperator.func1({0x3eebf00?, 0xc001d40a
/workspace/pkg/models/openpitrix/interface.go:56 +0x3b
k8s.io/client-go/tools/cache.ResourceEventHandlerFuncs.OnAdd(...)
/workspace/vendor/k8s.io/client-go/tools/cache/controller.go:232
k8s.io/client-go/tools/cache.(*processorListener).run.func1()
/workspace/vendor/k8s.io/client-go/tools/cache/shared_informer.go:911 +0x134
k8s.io/apimachinery/pkg/util/wait.BackoffUntil.func1(0x0?)
/workspace/vendor/k8s.io/apimachinery/pkg/util/wait/wait.go:157 +0x3e
k8s.io/apimachinery/pkg/util/wait.BackoffUntil(0xc003329f38?, {0x476a2a0, 0xc002d84c00}, 0x1, 0xc0
/workspace/vendor/k8s.io/apimachinery/pkg/util/wait/wait.go:158 +0xb6
k8s.io/apimachinery/pkg/util/wait.JitterUntil(0x65726f632e676e69?, 0x3b9aca00, 0x0, 0x71?, 0xc0033
/workspace/vendor/k8s.io/apimachinery/pkg/util/wait/wait.go:135 +0x89
k8s.io/apimachinery/pkg/util/wait.Until(...)
/workspace/vendor/k8s.io/apimachinery/pkg/util/wait/wait.go:92
k8s.io/client-go/tools/cache.(*processorListener).run(0xc0003a5d80?)
/workspace/vendor/k8s.io/client-go/tools/cache/shared_informer.go:905 +0x6b
k8s.io/apimachinery/pkg/util/wait.(*Group).Start.func1()
/workspace/vendor/k8s.io/apimachinery/pkg/util/wait/wait.go:75 +0x5a
created by k8s.io/apimachinery/pkg/util/wait.(*Group).Start
/workspace/vendor/k8s.io/apimachinery/pkg/util/wait/wait.go:73 +0x85
panic: runtime error: invalid memory address or nil pointer dereference [recovered]
[signal SIGSEGV: segmentation violation code=0x1 addr=0x0 pc=0x21ea58b]
/workspace/vendor/k8s.io/apimachinery/pkg/util/runtime/runtime.go:56 +0xd7
能不能帮忙看看,因为这个东西是开放的,不太确定是否因为同事进行了那种操作导致的.现在无法启动ks-apiserver
NAME NAME WORKSPACE URL STATE AGE
repo-17114xo13qyk4y charts.bitnami.com xrkj-workspace https://charts.bitnami.com/bitnami failed 323d
repo-3k11vx00kk8w4z mysql.github.io base-workspace https://mysql.github.io/mysql-operator successful 283d
repo-41q15v9l948y9r helm.elastic.co xrkj-workspace https://helm.elastic.co successful 322d
repo-44xlnmzyq6zm9r helm.goharbor.io xrkj-workspace https://helm.goharbor.io successful 303d
repo-5y225jy5lnon6j charts.gitlab.io xrkj-workspace http://charts.gitlab.io failed 323d
repo-9m7r8yk81lon6j sonatype.github.io xrkj-workspace https://sonatype.github.io/helm3-charts successful 323d
repo-jkmx23jn3j8w4y mysql.github.io xrkj-workspace https://mysql.github.io/mysql-operator successful 283d
repo-mowwwrm863v96l harbor.us168168.com xrkj-workspace https://harbor.us168168.com/chartrepo/library failed 322d
repo-mpolxyrpj9v96l mirror.azure.cn/kubernetes/charts xrkj-workspace http://mirror.azure.cn/kubernetes/charts successful 323d
repo-mqxl06roo5vy93 charts.bitnami.com sugn-workspace https://charts.bitnami.com/bitnami successful 258d
repo-r73wv5j99z0k7k a-nexus.wetok168.com xrkj-workspace https://a-nexus.wetok168.com/repository/helm-hosted successful 289d
只需要删除bitnami就可以嘛
suguangnan
删除试一下
是否还需要其他的操作,比如重启什么服务?
重建一下ks-apiserver的pod
谢谢大哥,可以了,是否解释一下为什么呢?是否以后添加bitnami还是会出现这种情况呢
bitnami源里有脏数据, 一个chart包光有元信息,没有实际内容, 导致出错了
后续 bitnami源把数据修正, 或者ks出一个补丁跳过这种异常数据
suguangnan
可以尝试再添加一下, 我新加bitnami源没有复现, 可能是他某次加了个空包, 然后你们的环境就缓存了这个空包, 后面他又修复删除了
