,Centos7.5 8C/64G
containerd 1.6
v4.1.2。在已有K8s上安装还是使用kk安装。
**安装告警扩展插件异常*
2025-02-22T23:31:17.456242718+08:00 WARNING: Kubernetes configuration file is group-readable. This is insecure. Location: kube.config
2025-02-22T23:31:17.456311115+08:00 WARNING: Kubernetes configuration file is world-readable. This is insecure. Location: kube.config
2025-02-22T23:31:17.479330068+08:00 history.go:56: [debug] getting history for release whizard-alerting
2025-02-22T23:31:17.552546567+08:00 Release “whizard-alerting” does not exist. Installing it now.
2025-02-22T23:31:17.552649712+08:00 install.go:214: [debug] Original chart version: ""
2025-02-22T23:31:17.572147897+08:00 install.go:231: [debug] CHART PATH: /tmp/helm-executor/repository/whizard-alerting-1.0.3.tgz
2025-02-22T23:31:17.572187541+08:00
2025-02-22T23:31:17.959538787+08:00 client.go:142: [debug] creating 1 resource(s)
2025-02-22T23:31:18.260181603+08:00 client.go:142: [debug] creating 1 resource(s)
2025-02-22T23:31:18.558595141+08:00 client.go:142: [debug] creating 1 resource(s)
2025-02-22T23:31:18.647896057+08:00 wait.go:48: [debug] beginning wait for 3 resources with timeout of 1m0s
2025-02-22T23:31:18.771917970+08:00 install.go:205: [debug] Clearing REST mapper cache
2025-02-22T23:31:34.953298014+08:00 Error: unable to build kubernetes objects from release manifest: resource mapping not found for name: “whizard-alerting” namespace: “extension-whizard-alerting” from "": no matches for kind “Ruler” in version “monitoring.whizard.io/v1alpha1”
2025-02-22T23:31:34.953404491+08:00 ensure CRDs are installed first
2025-02-22T23:31:34.954097964+08:00 helm.go:84: [debug] resource mapping not found for name: “whizard-alerting” namespace: “extension-whizard-alerting” from "": no matches for kind “Ruler” in version “monitoring.whizard.io/v1alpha1”
2025-02-22T23:31:34.954161635+08:00 ensure CRDs are installed first
2025-02-22T23:31:34.954182544+08:00 unable to build kubernetes objects from release manifest
2025-02-22T23:31:34.954196584+08:00 helm.sh/helm/v3/pkg/action.(Install).RunWithContext
2025-02-22T23:31:34.954208897+08:00 helm.sh/helm/v3/pkg/action/install.go:322
2025-02-22T23:31:34.954220832+08:00 main.runInstall
2025-02-22T23:31:34.954233959+08:00 helm.sh/helm/v3/cmd/helm/install.go:306
2025-02-22T23:31:34.954246678+08:00 main.newUpgradeCmd.func2
2025-02-22T23:31:34.954258528+08:00 helm.sh/helm/v3/cmd/helm/upgrade.go:146
2025-02-22T23:31:34.954270489+08:00 github.com/spf13/cobra.(
Command).execute
2025-02-22T23:31:34.954284543+08:00 github.com/spf13/cobra@v1.8.0/command.go:983
2025-02-22T23:31:34.954296013+08:00 github.com/spf13/cobra.(Command).ExecuteC
2025-02-22T23:31:34.954307712+08:00 github.com/spf13/cobra@v1.8.0/command.go:1115
2025-02-22T23:31:34.954320006+08:00 github.com/spf13/cobra.(
Command).Execute
2025-02-22T23:31:34.954331573+08:00 github.com/spf13/cobra@v1.8.0/command.go:1039
2025-02-22T23:31:34.954344267+08:00 main.main
2025-02-22T23:31:34.954357093+08:00 helm.sh/helm/v3/cmd/helm/helm.go:83
2025-02-22T23:31:34.954369433+08:00 runtime.main
2025-02-22T23:31:34.954382017+08:00 runtime/proc.go:267
2025-02-22T23:31:34.954393894+08:00 runtime.goexit
2025-02-22T23:31:34.954405286+08:00 runtime/asm_amd64.s:1650
  • XxulaiK零S
    请确认安装 WhizardTelemetry 监控 扩展时启用可观测中心是否进行了完整配置:
    有修改的,是按照文档上的操作步骤修改的配置
    前两个操作都是没有异常就到了修改告警组件的时候就报错了,今天又操作了一次,告警组件修改更新的还是一样的异常 。
    修改后查看平台组件配置如:
    监控组件配置如:
    看你贴的错误信息,好像是缺少crd
    rulers.monitoring.whizard.io
    检查一下 是否有这个crd,看看 前置的三个组件 安装,运行是否正常
    WhizardTelemetry 平台服务WhizardTelemetry 监控以及 WhizardTelemetry 告警
