- 已编辑
Ubuntu20.04,4C/8G
Client Version: v1.31.0
Kustomize Version: v5.4.2
将 docker version
/ crictl version
/ nerdctl version
结果贴在下方
v4.1.2。在线安装,使用kk安装。
在添加EKS集群时,点击创建以后无反应,在网页的控制台上查看错误信息为:
Get “https://DA11ED6DEE5E65501CC969D43CC12F59.gr7.us-west-2.eks.amazonaws.com/api/v1/namespaces/kube-system?timeout=10s”: getting credentials: exec: executable aws not found
It looks like you are trying to use a client-go credential plugin that is not installed.
To learn more about this feature, consult the documentation available at:
https://kubernetes.io/docs/reference/access-authn-authz/authentication/#client-go-credential-plugins
执行下面命令 kubectl logs -n kubesphere-system ks-apiserver-686ddff57b-b99p4
得到的输出如下:
I0311 10:33:58.757629 1 filters.go:96] undefined - “GET /apis/cluster.kubesphere.io/v1alpha1/clusters/e HTTP/1.1” 404 232 3ms
I0311 10:33:59.190569 1 filters.go:96] undefined - “GET /apis/cluster.kubesphere.io/v1alpha1/clusters/eks HTTP/1.1” 404 236 3ms
I0311 10:34:01.698486 1 filters.go:96] undefined - “GET /apis/cluster.kubesphere.io/v1alpha1/clusters/eks HTTP/1.1” 404 236 3ms
E0311 10:34:36.135942 1 utils.go:65] /workspace/pkg/kapis/cluster/v1alpha1/handler.go:155 Get “https://56E7C1D89789B8E362CEE8E2094B0372.gr7.us-west-2.eks.amazonaws.com/api/v1/namespaces/kube-system?timeout=10s”: getting credentials: exec: executable aws not found
