• 安装部署
  • 在 aws eks 安装v4.1.3 后主集群显示未就绪
例如:AWS EC2 4核8G*2 Linux
containerd://1.7.26+bottlerocket
v4.1.3
执行完
helm upgrade --install -n kubesphere-system \
--set global.imageRegistry=swr.cn-southwest-2.myhuaweicloud.com/ks \
--set extension.imageRegistry=swr.cn-southwest-2.myhuaweicloud.com/ks \
--create-namespace ks-core https://charts.kubesphere.com.cn/main/ks-core-1.1.4.tgz --debug --wai
集群状态
未就绪
状态: False
原因: Ready
消息: the server is currently unable to handle the request (get services http:ks-apiserver:80)
k logs ks-apiserver-85d7c8888f-9zqqp -n kubesphere-system
I0403 12:42:27.319912 1 filters.go:96] 172.31.68.147 - “GET /apis/kubesphere.io/v1alpha1/extensions HTTP/1.1” 403 322 0ms
I0403 12:42:27.325355 1 filters.go:96] 172.31.68.147 - “GET /apis/extensions.kubesphere.io/v1alpha1/extensionentries HTTP/1.1” 403 373 0ms
I0403 12:42:27.326001 1 filters.go:96] 172.31.68.147 - “GET /apis/extensions.kubesphere.io/v1alpha1/jsbundles HTTP/1.1” 403 352 0ms
I0403 12:42:27.345211 1 filters.go:96] 172.31.68.147 - “GET /apis/kubesphere.io/v1alpha1/extensions HTTP/1.1” 403 322 0ms
I0403 12:42:27.350472 1 filters.go:96] 172.31.68.147 - “GET /apis/extensions.kubesphere.io/v1alpha1/extensionentries HTTP/1.1” 403 373 0ms
I0403 12:42:27.351137 1 filters.go:96] 172.31.68.147 - “GET /apis/extensions.kubesphere.io/v1alpha1/jsbundles HTTP/1.1” 403 352 0ms
k logs ks-controller-manager-69d79cfc5d-lfw6b -n kubesphere-system
E0403 12:40:58.303967 1 controller.go:316] “Reconciler error” err="Operation cannot be fulfilled on roles.iam.kubesphere.io \“operator\”: the object has been modified; please apply your changes to the latest version and try again" controller=“role” controllerGroup=“iam.kubesphere.io” controllerKind=“Role” Role=“kubesphere-controls-system/operator” namespace=“kubesphere-controls-system” name=“operator” reconcileID=“b0a02040-bfb5-408a-bdf7-31f75d772c44”
E0403 12:40:58.323635 1 controller.go:316] “Reconciler error” err="Operation cannot be fulfilled on roles.iam.kubesphere.io \“operator\”: the object has been modified; please apply your changes to the latest version and try again" controller=“role” controllerGroup=“iam.kubesphere.io” controllerKind=“Role” Role=“kubesphere-controls-system/operator” namespace=“kubesphere-controls-system” name=“operator” reconcileID=“c251b2d5-9082-4491-be1d-3032d673cda4”
E0403 12:40:58.358805 1 controller.go:316] “Reconciler error” err="Operation cannot be fulfilled on roles.iam.kubesphere.io \“operator\”: the object has been modified; please apply your changes to the latest version and try again" controller=“roletemplate” controllerGroup=“iam.kubesphere.io” controllerKind=“RoleTemplate” RoleTemplate=“namespace-create-app-releases” namespace="" name=“namespace-create-app-releases” reconcileID=“a3e6d45f-1df5-407c-a5d0-51d579b96f27”
k get events
13m Normal Synced workspacerole/system-workspace-viewer Aggregating roleTemplates successfully
13m Warning SyncFailed workspacerole/system-workspace-viewer cluster not ready: host
13m Warning SyncFailed workspacetemplate/system-workspace cluster not ready: host
13m Normal Synced workspacetemplate/system-workspace Synced successfully
13m Normal Synced role/viewer Aggregating roleTemplates
    15 天 后
    遇到了一样的问题, 楼主是怎么解决的,求助,sos
    日志显示是ks-apiserver服务未就绪。
    你提供的ks-apiserver没有错误日志,看有没有更多的日志信息。
    也看看ks-apiserver容器对应的事件。
      redscholar kubectl logs -n kubesphere-system -l app=ks-apiserver
      E0418 08:21:03.915657 1 authentication.go:64] Request authentication failed: jwt: token is expired by 3m50.915644833s
      W0418 08:21:03.915660 1 jwt.go:47] jwt: token is expired by 3m50.91565589s
      I0418 08:21:03.915662 1 filters.go:96] undefined - “GET /api/v1/nodes HTTP/1.1” 401 157 0ms
      W0418 08:21:03.915571 1 jwt.go:47] jwt: token is expired by 3m50.915568721s
      I0418 08:21:03.915675 1 filters.go:96] undefined - “GET /apis/extensions.kubesphere.io/v1alpha1/jsbundles HTTP/1.1” 401 156 0ms
      E0418 08:21:03.915668 1 authentication.go:64] Request authentication failed: jwt: token is expired by 3m50.91565589s
      I0418 08:21:03.915692 1 filters.go:96] undefined - “GET /kapis/tenant.kubesphere.io/v1beta1/clusters HTTP/1.1” 401 157 0ms
      E0418 08:21:03.915677 1 authentication.go:64] Request authentication failed: jwt: token is expired by 3m50.915568721s
      I0418 08:21:03.915709 1 filters.go:96] undefined - “GET /apis/extensions.kubesphere.io/v1alpha1/extensionentries HTTP/1.1” 401 156 0ms
      I0418 08:21:03.915722 1 filters.go:96] undefined - “GET /kapis/version HTTP/1.1” 401 157 0ms
      12 天 后
      +1,这要怎么解决啊,,,
      5 天 后
      检查集群就绪的访问链路为:ks-controller-managerkube-apiserverks-apiserver
      在该链路中,任一节点之间的网络连接若受到限制,均可能导致该问题的出现。常见原因包括:防火墙规则或云平台安全组配置阻止了某一段链路上的通信(例如,从 ks-controller-managerkube-apiserver,或从 kube-apiserverks-apiserver 的流量被拦截)。
      7 天 后
      我新建个 eks 集群就好了,之前 eks 的创建通过 terraform 创建的
